03-31-2019, 08:50 PM | #1 |
Newbie Join Date: Mar 2019 Location: Bessemer
| Electronics setup for TRX-4?
So, me and my father are building a TRX-4. It's going to be a crawler/trail, no comp or racing. 2 speed transmission. Oh and it's going to be running on a 2s lipo. Looking for high torque, lower wheelspeed. Not really going to be using it on pavement so don't need 20mph. With that said, being a 2 speed it wouldn't be bad if 2nd gear had a bit of speed for the trail. Aiming for around $100-125 or so for the motor/esc. So almost surely brushed. For the servo, looking at this. Right now I am thinking about the Hobbywing 1080 and a Crawlmaster 550 or Torquemaster 550. Not sure on machine vs hand wound. Also looking at the new Reedy 5 slot. Open to anything, though. Thanks! Last edited by mattbhm; 03-31-2019 at 08:57 PM. |
03-31-2019, 08:58 PM | #2 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Electronics setup for TRX-4? Quote:
Ernie | |
03-31-2019, 09:16 PM | #3 |
| Re: Electronics setup for TRX-4? |
03-31-2019, 10:08 PM | #4 | |
I think John only makes the pro 550 in 10 and 12, and they are $99, I think the sport line is $15 and more in your budget? I would go with a 21 or 27 turn. JMO Ernie | |
04-01-2019, 10:46 AM | #5 |
04-01-2019, 10:59 AM | #6 |
There is a machine wound 540 version of the Crawlmaster. I would say 12t CM pro 550 is a really good choice for your needs. Will be super smooth, really great on the rocks and trails. |
04-01-2019, 11:03 AM | #7 |
Are you going to go in water or mud? You can't go wrong with the HobbyWing 1080 ESC for brushed. |
04-01-2019, 11:19 AM | #8 | |
Not really going anywhere like that. Mostly dry, the worst will be wet leaves and a creek bed with some small puddles. | |
04-01-2019, 11:33 AM | #9 |
Should be fine, it's still quite a quick motor especially with the 2 speed. But 10t would be a little peppier on 2s.
04-01-2019, 11:34 AM | #10 |
| Re: Electronics setup for TRX-4? Then you'll be good with brushed or brushless. So listen to John. He knows motors because he sells motors. I can personally vouch for his motors and his customer service.
04-01-2019, 11:45 AM | #11 | ||
I'll probably stick with 12t then just in case I decide to up to 3s in the future. Your responses are appreciated! We were really having a hard time deciding between brushless and brushed, but now I think we have a decision. I'll be ordering the 12t CM Pro this evening. Quote:
Thanks! | ||
04-01-2019, 03:47 PM | #12 |
I run the trx4 with a 10t crawl master on 3s with a 9t pinion and I love it. I can assure you there is no need to use a slower motor. As the first gear is 80:1 with a 9t pinion.
04-01-2019, 04:25 PM | #13 |
| Re: Electronics setup for TRX-4? https://youtu.be/L5x0BXY4gdI my trx4 with a hobbywing 1080, 3s lipo, crawlmaster 10t, 9t pinion. Sorry vids not great cause I'm busy watching a baby.
04-01-2019, 08:51 PM | #14 | |
Appreciate the video! Sent you a PM about the setup. | |
Electronics setup for TRX-4? - Similar Threads | ||||
Bomber electronics setup | Yonzariq | Axial RR10 Bomber | 3 | 08-18-2017 06:34 AM |
Need help with electronics setup | 68_f100 | Electronics | 4 | 08-25-2014 09:38 PM |
Electronics Setup Help! | Jesterhead777 | Newbie General | 9 | 12-29-2013 08:40 PM |
SCX10 electronics setup | craddock35 | Axial SCX-10 | 43 | 02-22-2013 01:02 PM |
