06-07-2020, 06:02 PM | #1 |
Rock Stacker Join Date: Jun 2011 Location: Wenatchee, WA
| Hobbywing 1080 problems
Hey everyone, I'm having an issue with my recently purchased HE 1080. It worked great for one battery. Went to swap in a new one and esc will beep, flash led and motor will surge forward half a tire rotation and then shut off. Issue continues no matter what battery I use. Any advice is welcome. Thanks. |
06-07-2020, 06:09 PM | #2 |
| Re: Hobbywing 1080 problems
What truck is this in? What radio are you using the HW1080 with? 2S or 3s? A bit more information would be very helpful in order for someone to help you.
06-07-2020, 06:15 PM | #3 |
My bad. Custom C2 Capra axles, 3s , hh 550 crawl master pro 12t, hi-tec d954sw, flysky gt3b, flysky gr3e. |
06-07-2020, 06:38 PM | #4 |
Newbie Join Date: Apr 2020 Location: Newfoundland, Canada
What MAH and C rating are your batteries? Also, what setting do you have punch set on?
06-07-2020, 06:43 PM | #5 |
800mah, 40c, punch is max Update now only to light on the on switch works. Can't rebound or recalibrate. |
06-07-2020, 06:55 PM | #6 |
| Re: Hobbywing 1080 problems There's your problem. Your batteries are only rated to output 32A. Turn your punch way down and it should work until you start heavy crawling. You need 80-100 C batteries at 800mah to have enough amperage to power the ESC/motor.
06-07-2020, 07:00 PM | #7 |
Not to sound aggressive. Then why did it work fine and then nothing? Would programming it that way really damage the esc? If anything it was under powered correct? Ran plenty of 40-50c batteries in the past on other esc with no issue. |
06-07-2020, 07:06 PM | #8 |
| Re: Hobbywing 1080 problems The motor draws the amperage and the ESC pushes the voltage. So if the motor suddenly gets the full 12.5V from a fully charged 3S, it could try to draw upwards of 120 amps temporarily. The ESC trys to give it but fails as it's starved for power. I'm guessing the ESC or Battery could be damaged from this.
06-07-2020, 07:10 PM | #9 |
| Re: Hobbywing 1080 problems Punch is the issue. That's the whole purpose of it, to limit the direct immediate power the motor is going to use. A lower setting means less amps starting it up and it lets it spin up over so many milliseconds instead of instantly.
06-07-2020, 07:10 PM | #10 |
That makes sense. Thanks for the explanation
Hobbywing 1080 problems - Similar Threads | ||||
Hobbywing 1080 quicrun problems | Ridge runner | Electronics | 9 | 06-01-2020 11:55 PM |
Hobbywing 1080 | mr_alister | Electronics | 3 | 05-23-2020 10:42 AM |
Hobbywing 1080 SOS! | ChrisSandstorm | Traxxas TRX-4 | 8 | 04-30-2020 09:56 PM |
Hobbywing 1080 no reverse? | davis53 | Electronics | 10 | 08-02-2019 07:27 PM |
Hobbywing 1080 | krazee | Traxxas TRX-4 | 2 | 12-21-2017 09:03 PM |
