06-17-2021, 05:45 PM | #1 |
Rock Crawler Join Date: Aug 2007 Location: Dela-where?
| Re-wiring controller help needed!
I have an old cheapy pistol grip controller that I use for lighting rockets, firecrackers and our fire pit. I’d like to re-wire the trigger to be a push button. Here’s what I’ve got: This is the "trigger" that I want to swap out for a button Anyone know what button I need and what I need to do to make this work? Any and all help is appreciated! Last edited by j0e; 06-18-2021 at 06:11 AM. |
06-18-2021, 03:00 PM | #2 |
| Re: Re-wiring controller help needed!
this is just a guess but.... the trigger is just a variable resistor. you need to find the resistance at neutral and wire that value resister between the button spst button terminals. otherwise using just voltage in and signal out will go from full reverse to full forward. the signal out probably goes from like 0 to 5v or something like that. then you have 5v in and ground wires also. Last edited by Voodoobrew; 06-18-2021 at 03:04 PM. |
06-19-2021, 12:28 AM | #3 |
Think I’d be able to use the trim to get it to go neutral to full forward?
06-19-2021, 07:31 PM | #4 | |
| Re: Re-wiring controller help needed! Quote:
Just by how fast the car goes. Or how far a servo turns If you have an Arduino and a lcd you can read the signal. I use arduinos to test lots of pwm stuff. | |
Re-wiring controller help needed! - Similar Threads | ||||
Wiring help needed | Trufflehunter | RC4WD Bully | 1 | 06-05-2018 07:06 PM |
Servo wiring help needed | mrmotard | Electronics | 0 | 03-25-2018 12:22 AM |
Wiring advise needed | Abrown83 | Electronics | 3 | 11-09-2013 03:02 PM |
