Thread: pro scale light question
Old 09-03-2021, 03:33 PM   #1
Default pro scale light question
H
ey everyone, getting back into R/C trucks since I was a teenager and I to R/C crawling. I bought a trx4 bronco since I had a bronco when as my first truck. One of the first mods I did was lighting and went with the Traxxas pro scale since it was plug and play till I get my Witt's about me. Everything went well except the rear brake and turn signals don't work in any function or mode. I have the grey jumper installed in terminal f and the tail lights in terminal c. I just wanted to know if it was normal for this kit or I missed something. Thanks for the help.
ThatGuy8820 is offline   Reply With Quote
Old 09-03-2021, 09:06 PM   #2
Default Re: pro scale light question
Check for broken connections. All the low power led kits 3mm and 5mm I have seem to pull apart easily.
Sent from my SM-N986U using Tapatalk
Old 09-04-2021, 08:33 AM   #3
Awesome will check that out later thanks
Old 09-11-2021, 09:32 PM   #4
Did you figure it out? What was the fix?
KingRaptor is offline   Reply With Quote
pro scale light question - Similar Threads
trx4 pro scale light question. ThatGuy8820 Traxxas Crawlers 2 10-12-2021 05:36 AM
SSD pro scale or Pro Line Pro Spec shocks? Mr. Crawley EC Axial SCX10 II 6 06-18-2019 11:04 PM
Larry 8 LED Pocket Work Light as cheap scale light bar spoo76 General Scale Talk 8 12-15-2014 06:38 AM
Axial 5-light universal light bar wiring question... KillerBlackbird Axial Wraith 9 11-28-2012 06:18 PM
