07-02-2007, 10:14 AM | #41 | |
I wanna be Dave Join Date: Nov 2005 Location: Here
The Front Servo is plugged into one female. The battery (RX or Main Cells?) is in the other. What does that do for it then? I am not understanding. | |
07-02-2007, 10:20 AM | #42 |
The male end of the y harness plus into the channel for you servo not the battery port. It isolates the power drain away from the receiver. The receiver sees no voltage drop so the Spektrum will not shut down. |
07-02-2007, 10:25 AM | #43 | |
So may questions...thanks for the patience. | |
07-02-2007, 10:29 AM | #44 |
Yes plug a receiver pack into the other end. Not sure about using the regulator, I just fried my 3rd one, I have bad luck with them. I run 2 battery packs for my servos, one for each one. You could split it and use one pack. |
07-02-2007, 10:42 AM | #45 | |
RCC Addict Join Date: Apr 2004 Location: 5280
I think 666 maybe on to what has been causing the issues in your TXT. If I remember correctly your truck has been shutting down during big steering loads. I would think running a RX pack to each servo may sovle the issues. I may do this on my truck just to make sure I have plenty of power to both servos. | |
07-02-2007, 11:06 AM | #46 | |
JRH, If you are on here...Can I "Y" harness the output side of the regulator to go to the servo "Y"s that 666 is talking about for the two servos? | |
07-02-2007, 11:12 AM | #47 | |
Those RX packs you had in your box o' stuff didn't have that much weight, and I would place one on each axle, given you are already biased heavily to the front. I would have to layout a single line drawing, but I think, if you do it right, you could "Y" the regulator. Also, before you fight it that much, try a different radio first! Make sure it really is the Spectrum being sensitive. Also, if you have the time, go through and layout your wiring. That will help make everything make sense and you should be able to find points to check voltages (both now and later) to make sure everthing is working right. On a side note...were those rx packs in good shape you had in your box?? | |
07-02-2007, 11:14 AM | #48 |
07-02-2007, 11:17 AM | #49 |
07-02-2007, 11:26 AM | #50 |
07-02-2007, 11:37 AM | #51 | |
I think you have a secret desire to be a stripper and love having cash handed to you, dreaming you were off to a champange room only to realize that you just sold off the parts needed for me to stay #1 in the points chase! Hahaha! If you need your crack money sooner just let me know, I am sure AB-C John will hold it, not sure what his cut would be... | |
07-02-2007, 11:41 AM | #52 | |
I thought this was a tech thread. Back to business Ordered the HD Adjustable Reg from JRH. Will try that will a "Y" and bypass the receiver. In the mean time, I will hook up those two RX packs that Busted thinks that he is going to get a deal on, and see how they work. Busted, Remember, never cross the Club Prez or the crack dealer... | |
07-02-2007, 12:41 PM | #53 | |
On topic, I think that HD regulator should help you out. I still vote for laying out your wiring on paper just to make sure that everything is in order. But, I am also the guy that bought my truck because the builder was couldnt figure out why it wouldnt run...a loose pinion on a motor will kill ya! Off topic, I would like to try before I buy on the RX packs as I am not sure if it would make a huge difference to me at this point. The tab is big enough, and I am just not sure, with still being brushed, if I will see a huge increase. I just dont have any batteries with the correct connector to tryout first. | |
07-02-2007, 01:52 PM | #54 | ||
Plugged the RX Pack in the Receiver and the rig came alive. I will make the "Y" connectors and get this thing running. Thanks to everyone for your suggestions. I will keep you in the loop. Thanks, John Quote:
I bought a RC18T that way...lose wire on the motor. Quote:
07-09-2007, 03:06 PM | #55 |
Well guys, Check this out and give me your thoughts. This is very rough but the best I can do, being a salesman Thanks, John PS. There are yellow lines there...they are hard to see. |
07-09-2007, 03:19 PM | #56 |
Looks good to me, however the black wires shown should be plugged in that end off the regulator and where it goes into the receiver, I may not be right though I'm not a regulator guy though.
07-09-2007, 03:45 PM | #57 |
Just looked at it again and there is a problem. I need the Female to Males off the Regulator. Then two Female to Male and Female to link to the Servo and the Receiver. I should just stay will selling. |
07-09-2007, 03:56 PM | #58 |
Revised... |
07-09-2007, 04:15 PM | #59 |
JRH, Running the new Reg you sent...what should I set the Output Voltage at? I am running the 5955mg on front and a 945 on back. Can I push the voltage without frying a servo? I believe, without looking, the Digitals can handle up to 10V. By the way, thanks for the help with the Reg issue. |
07-09-2007, 04:18 PM | #60 | |
I would start at 6v and test the temps on the servos, keep them under 130 or 140 on the case for safety. You can always increase the voltage and get more power, but you can't unfry a servo if you overvolt it. | |
