07-09-2007, 04:22 PM | #61 | |
I wanna be Dave Join Date: Nov 2005 Location: Here
I will hook it up tonight. I will let everyone know. Thanks | |
07-09-2007, 08:13 PM | #62 |
I run 7.2 packs to my 5955's, and they hover around 120 degrees while bashing.
07-13-2007, 08:06 PM | #63 |
Just to keep everyone up to date. I finished the wiring and did a test run on the wife's rock garden The Regulator is pushing out 6.05V with 8cells. At first everything was working great. After about 3 mins, the rear servo (HS-945MG) started getting weak. It would not turn or it would not hold center when turning front only. Took a temp reading...hear is what I found: Regulator = 94* Front HS-5955TG = 118* Rear HS-945MG = 148* That is the problem...these things are heating up and then failing. They work great when at ambient temp. Soon as they get above 120* they are useless. What could be causing it to heat up that high? Is my option only to go to another digital servo? I have a comp on Sunday...Panic has set in... Let me know. Thanks, John |
07-13-2007, 08:14 PM | #64 |
Pebble Pounder Join Date: Sep 2006 Location: clune
I run two 5595 with my super and novak reg and specktrum .No problems now at all.Like a gtg
07-13-2007, 08:34 PM | #65 |
That is what I am thinking...It took me a long time but I think I nailed it. Now I just need to find a 5955 or the like before Sunday. |
07-13-2007, 09:10 PM | #66 |
RCC Addict Join Date: Nov 2005 Location: Saving for Nationals!!
| 5955's are great servos, but if you can't find one and are running a radio with EPA, you can also run HS-5995TG servos, same 333 oz at 6.0 volts, but 180^ rotation instead of 90^. The other advantage of the 5995, is if you up the voltage to 7.2 volts you'll get 417 oz of torque! |
07-13-2007, 09:12 PM | #67 | |
07-13-2007, 09:20 PM | #68 |
You know what I did on the back of Rocktapus to make it quit frying servos?
07-13-2007, 09:24 PM | #69 |
07-13-2007, 09:28 PM | #70 |
Lol! Thats a key thing, this was much easier and cheaper! |
07-14-2007, 06:37 AM | #71 |
07-16-2007, 04:54 AM | #72 |
Well guys...I think I am locked in. At the comp yesterday, no shut downs, lost steering and a class win!!! I want to thank all of you for the help...it was a long grulling journey (not to mention expensive) but it all came out. Thanks again, John By the way, JRH...that Crawlmaster is just Sick... |
07-16-2007, 06:03 AM | #73 |
Congrats on the win man , good to hear you solved your electronics issues |
07-16-2007, 08:20 AM | #74 |
Yes, congrats! Happy to hear you got everything running smoothly after all.
