04-09-2008, 07:42 AM | #141 |
Rock Stacker Join Date: Mar 2008 Location: Canada
"The unit requires a Castle link to be reprogrammed..." How exacly do i reprogram it ? I have the Castle link v3.0 for the Mamba max.... |
04-09-2008, 09:06 AM | #142 |
Newbie Join Date: Feb 2008 Location: Nakusp
Just read this thread and good thing I ordered a castle bec and had it programed to the batteries I was ordering as well now I understand it more and will have to get the castle link to reprogram it down to about 6v you don't need a bec programed to 8.4 just because you have 8.4 batteries Really makes my newbie name stick
04-09-2008, 09:08 AM | #143 |
you have to geta castle link programmer for the bec the castle link in the mamba max will not program a bec the program link is about 20$ This is what I found on another thread
04-09-2008, 09:12 AM | #144 | ||
| One should cut it, but some Wa guys have been shutting the CC BEC down with just two servos. Goes to show that some guys just don't have the terrain or driving style to push parts as hard as others. Quote:
I am pretty sure I set yours to 6v, I knew what you were saying. If you have a multimeter you can check the output of the BEC. | ||
04-09-2008, 09:15 AM | #145 |
Thanks JR I will check it when I get it after reading this thread it sort of made me feel like an idiot
04-20-2008, 02:53 PM | #146 |
Quarry Creeper Join Date: May 2005 Location: Between rocks and hard places
Will I be safe running a Airtronics 358 at 6.2-6.4V w/out any risk? or is it pushing it just going over 6.0 with 1 servo?
04-22-2008, 09:56 AM | #147 |
Newbie Join Date: Apr 2008 Location: Langley
I ordered the bec from TowerHobbies but need to know what the stock voltage setting is. I will be running a TCS 7-cell split pack with an HS-645MG on the front and the stock Axial servo on the back. If I need to change the voltage I guess I'll have to get the link adapter. My ESC is the Tekin FX-R. Anyone know what voltage setting I should use on the BEC? I may upgrade the rear servo soon as well. Thanks! |
04-22-2008, 10:29 AM | #148 |
It's 5.1V out of the box.
04-23-2008, 12:29 AM | #149 |
Rock Crawler Join Date: Nov 2007 Location: San Marcos
| hey jrh
I have a problem. My cc bec set at 6v hooked up to a mamba 25 pwering a Ko Propopds2368ids with juice from a 6cellelite1500 was glitching bad while throttle was engaged then power shut of completly and i could not connect to casltelink, whats going on?Thanks |
04-27-2008, 08:57 AM | #150 |
Newbie Join Date: Apr 2008 Location: Lewisville
RC Crawler forums rock!! So much info available and the advance search is sweet. John, you seem to be the guy with the answers re the CC Bec, so I figured this is the place to ask mine. I just purchased a CC Bec to install on my 2.2 OCM crawler. Here is a list of my current components Mamba Max esc 2c lipo 7.4 Hitec steering servo 5955 2- 55t brushed motors Battle Switch for my dig (plugged into my aux channel) Spectrum DX3R radio and reciever (link to battle switch) http://www.robotmarketplace.com/prod...-BATTLSW1.html So, my question. I am going to test drive the bec to see if I will have a problem with the 'bind' issue with the radio first. I want to go ahead and temp wire it in with-out cutting the red lead from my esc. Will I notice a difference in the performance of my steering servo using the stock 5.1v setting on the bec vs what the mamba max is putting out. (what is that voltage?). And will I notice a difference if I were to have the bec re-programed to 6v instead of the stock 5.1v. (note, am really miffed that CC does not include the small adapter with the ubc when you buy a momba max, having to spend another $20 grrrr) And if it works ok in the test mode, I can then cut the red lead from the esc. Thanks for the help Cliff |
04-27-2008, 09:06 AM | #151 |
Note: I am a newb' into rock crawl and all the elec components and how they work. So I ask alot of questions and take the advice of those that seem to know. So far it's working great.
04-27-2008, 09:10 AM | #152 |
ooops... forgot to ask in my previous request. Do I plug the BEC into the batt/bind chennel on my receiver? |
04-29-2008, 08:03 PM | #153 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
All the "glitching" prob going on, I talked to Thomas at Castle (he's a tech there) Monday. He said there might be a bad batch of BEC's out now.....There guys in the lab are checking on it now. Also anyone running a Spektrum setup with 2 servos can buy a Spektrum Voltage Capacitor part # SPM1600 for $6 and fix the "Shutting down, and Glitching". I got this from the guys at Castle and Spektrum this week. I called only because alot of us have been having trouble with our CC BEC's. John, IM me and I can give you the rundown on what all is going on and what all the tech's at Castle and Spektrum, and now Novak have said. |
04-29-2008, 08:23 PM | #154 | ||
You will notice a difference with 5.1v to 6v, your servos will be faster with more power. The stock MM puts out 5.1v. You will need to remove the red wire from the MM for the system to work properly. | ||
04-29-2008, 08:32 PM | #155 |
| You don't need to cut the wire, just use a hobby knife to pry up gently on the "latch" that holds the wire in the plug, and slide the red wire out. Then tape it up. That way, if you need it plugged in again, you can. |
04-29-2008, 08:35 PM | #156 |
Thanks for the reply John. It all works fine in the stock set-up. I disconnected the red wire from the MM and turned it on.. no smoke escaped from any of my electronics I've ordered the adapter wire from CC so I will be able to up the voltage to 6v. I did talk to Castle and they confirmed the bec in the MM puts out 5.4v. Now I just have to wait for the big brown truck to arrive. |
04-29-2008, 08:37 PM | #157 |
Not sure if I wrote the info down wrong on the MM bec voltage. I wrote down 5.4, but my chicken scratch may have been a 5.1 LOL slight disclaimer :-P |
04-30-2008, 11:58 AM | #158 |
Pebble Pounder Join Date: Oct 2007 Location: San Diego
OOPS....my bad. I should have paid more attention, this is a Tech Thread..
12-17-2008, 05:24 AM | #159 |
Quarry Creeper Join Date: Jun 2008 Location: Sykesville MD
Old thread but good teck. Thanks for sharing. |
12-24-2008, 07:27 AM | #160 |
So I've never used an external BEC, but I think I need to now. Going to buy one of these from HH but I'm not sure what voltage output to get. I have a digital Ultra hi Torqe Hobbico servo on front and a MG645 on the dig. I run 6 and 7 cell 2/3A packs and 2s lipos if this cures my glitch. Will my 7.2 volts handle a 6 volt output continuously? Thanks!! |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/electronics/77466-castle-bec-review-tech-thread.html | ||||
Holmes Hobbies LLC | This thread | Refback | 02-15-2013 08:30 AM | |
Better BEC - Oregon R/C Rock Crawlers | This thread | Refback | 10-04-2011 05:47 PM | |
Holmes Hobbies LLC / Holmes Bikes :: Servos accessory/ Voltage regs :: Castle BEC | This thread | Refback | 10-04-2011 04:06 PM |
