02-29-2020, 10:11 AM | #161 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: A new Element uncovered? IFS Conversion for Enduro and SCX10 |
02-29-2020, 12:21 PM | #162 |
Newbie Join Date: Feb 2020 Location: Miami
Does anyone know what are these? I just cleaned all my table and found this 2 pieces that came with the ISF kit, but I'm looking at the manual and there is nothing about them. |
02-29-2020, 12:23 PM | #163 |
Look like servo mount posts
02-29-2020, 03:34 PM | #164 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
For a winch servo on top of the IFS bulkhead.
02-29-2020, 06:46 PM | #165 |
| Re: A new Element uncovered? IFS Conversion for Enduro and SCX10 Oh good. I was looking at the photos trying to figure out where they all went. I'm glad it's just two plastic balls.
03-01-2020, 07:13 AM | #166 |
I’ll be putting my IFS kit on an Axial chassis since there are many of them sitting around here. So I decided to print up the compatible servo mount while waiting. |
03-01-2020, 06:33 PM | #167 |
Just got mine finished, took nearly 3 hours to sort it all out. Finally got it how I wanted it with max travel up front, and somewhat limited travel out back to match. Very cool kit, can't wait to get it out on the trail. |
03-02-2020, 07:06 AM | #168 |
I got my kit and have been messing with it for a little bit and already can tell the Axial compatible wording should have a huge asterisk on it. - The skidplate that runs from the bulkhead to the center skid doesn't fit an Axial skidplate correctly. The spacing on the lower link pockets are about 1.5 mm more narrow on the Element so the IFS skidplate mounting tabs get bent pretty badly if you force it on the Axial skid. This either requires grinding material off the Axial skid, grinding material off the IFS skid, or using an Element skid (which is not included in the IFS kit). -Should you decided to use the Element skid with an Axial chassis, the 4 outer holes of the skid do not line up with the holes in the chassis. You can drill them out to match the chassis but it is super annoying that for all the cross compatibility designed into the Element, they made the skid holes 1.5 mm off. -Speaking of off, trying to bolt an Axial trans to an Element skid takes more effort than it should. The 2 inner holes line up fine but the 2 outer holes do not. You can force it enough to get all 4 screws in but this is bad since it was designed for cross compatibility. I'll see how things go from here but just scratching the surface of the kit makes it clear that buying an Element chassis would be the way to go if you want the IFS conversion to go smoothly. |
03-02-2020, 07:27 AM | #169 | ||
| Re: A new Element uncovered? IFS Conversion for Enduro and SCX10 Quote:
I'm having second thoughts. Maybe I'll sell mine. I'd buy an Enduro kit if their pumpkins weren't square. I have a major hangup there. | ||
03-02-2020, 08:38 AM | #170 | ||
Rock Crawler Join Date: Dec 2005 Location: Marietta
03-02-2020, 08:52 AM | #171 | |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
The only STL files they provide are the servo mount, and left and right shock mounts. Those parts alone don't address all the issues svt pointed out. | |
03-03-2020, 11:01 PM | #172 |
If you wanted to IFS and 1.9 a bomber with the Element Kit, it would be super easy. You would lose some ground clearance but just sayin’. A drill, drill bit and some 3mm screws. Provided lower skid looks almost perfect to mount up to the bomber skid. Even the angle of the front of the chassis adds a bit of caster. Rear wouldn’t be tough with some simple tools as well. I was going to build this IFRS but have changed my mind. |
03-04-2020, 05:27 AM | #173 |
Quarry Creeper Join Date: Dec 2014 Location: Tulsa
Where's the damn like button!
03-04-2020, 07:05 AM | #174 | |
03-04-2020, 01:24 PM | #175 |
This was my original plan, build up an IFRS bomber but I have decided to build a full tube chassis setup. But yah, it dang near bolts up to the Bomber chassis up front. Literally a drill, drill bit and some screws you could have it probably bolted up in 30 minutes or less.
A new Element uncovered? IFS Conversion for Enduro and SCX10 - Similar Threads | ||||
Another element uncovered | lilws6 | Element RC 1/10 Enduro Trail Truck Sendero | 56 | 03-29-2020 10:49 PM |
Element enduro kit | Supermotovinny | Element RC 1/10 Enduro Trail Truck Sendero | 2 | 12-28-2019 01:48 PM |
Looking for RS4/3 suspension for IFS/IRS SCX10 conversion.... | ToTheMAXXcrawler | General Crawlers | 5 | 03-05-2013 07:12 PM |
