06-11-2023, 01:45 PM | #1 |
Newbie Join Date: May 2023 Location: Glendora
| Hobbywing 1080 G2
I’m currently running a bone stock Gatekeeper RTR and have a case of upgrade fever. Would I gain any driveability by upgrading the stock Reedy esc to the HW 1080, or would I ultimately be better off throwing in something like the Fusion SE 2-in-1? And while we’re at it, what’s gained, if anything, by upgrading the RTR radio?
06-11-2023, 02:18 PM | #2 | |
Rock Crawler Join Date: May 2021 Location: NorCal
| Re: Hobbywing 1080 G2 Quote:
06-11-2023, 03:30 PM | #3 |
Rock Stacker Join Date: Apr 2023 Location: Sheboygan
I have a gatekeeper RTR With the stock radio, the G2 added a bit more control, especially in reverse. It did improve crawling control in both directions. Adding a better radio, the adjustable braking (while not world changing) is indeed nice. This is with the stock motor. Next upgrade with be a Holmes Hobby 10T or 8T. If I was to do it all again, I’d probably do the fusion. But if you only have a little money to spend, the G2 is well worth it. Not sure what the stock ESC allows, but the G2 allows up to 8.4v output. This really helps with the steering servo. NOTE: The G2 does not come with the programming card. You could probably get one used for next to nothing, but a new one is pretty cheap as well. |
07-03-2023, 05:58 AM | #4 |
Rock Crawler Join Date: Jan 2011 Location: Groningen, The Netherlands
Consider the Hobbywing Fusion SE. It is pretty affordable, to say the least, It saves a lot of interior space and works like a charm. Comes in 1400Kv and 1800kv. Afa I am concerned, the Fusion system is as precicely controllable as any brushed option, even 5-slots. Added bonus : High efficiency. It runs way cooler and longer for the same amout of Kv’s, with less rpm loss under load. And the FOC system is amazing. ( FOC = keep the throttle at a certain point, and FOC will keep the speed constant, whatever the incline, decline or obstacles. Weird experience, but one gets alltoo easily used to it, making any other ESC/motor combi feel clunky ) Oh, and even better. It can be set with the older firmware 2.0 programming cards. Functions printed on the sticker don’t correlate with the àctual Fusion settings but keep the manual of the fusion at hand and just go from there. Last edited by Jay-Em; 07-03-2023 at 06:01 AM. |
08-07-2023, 01:53 PM | #5 |
Pebble Pounder Join Date: Nov 2009 Location: Newmanstown, PA
I have a Fusion Pro in an element builders kit. It's worth the cost. 1080's aren't bad either. |
Hobbywing 1080 G2 - Similar Threads | ||||
Hobbywing 1080 | mr_alister | Electronics | 3 | 05-23-2020 10:42 AM |
HobbyWing 1080 settings. | Oh How Original | Electronics | 3 | 04-04-2018 06:37 AM |
Hobbywing 1080 | krazee | Traxxas TRX-4 | 2 | 12-21-2017 09:03 PM |
