07-13-2008, 01:50 AM | #21 | |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
2 stubs 2 servo horns (Alum.) 1 lower link bent (Stock OCM) 2 bent drive pins 4 rodends 1 grappler body it was a Badd day . :-P | |
07-21-2008, 07:24 PM | #22 |
Rock Crawler Join Date: Mar 2008 Location: Arizona
In one outing 3 bent stub axles and one trashed aftermarket chassis. |
08-02-2008, 11:26 AM | #23 |
One bent rear stub axle. It makes me wonder if the wider axle width is playing a roll in it. Some chromo or titanium outers may help.
08-02-2008, 11:38 AM | #24 |
08-02-2008, 11:56 AM | #25 |
RCC Addict Join Date: Feb 2007 Location: LRC
Blowed 7 bearings apart so far 2 sets of gears in front axle all 4 stock stubs in two battery packs |
08-02-2008, 05:08 PM | #26 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
I grenaded a stub today.
08-02-2008, 07:11 PM | #27 |
RCC Addict Join Date: May 2006 Location: China Grove, NC
- 3 front tires - pulled upper link out of the ball end - couple screws came loose |
08-02-2008, 11:35 PM | #28 |
It was the stockers on mine. Axials going in next.
08-03-2008, 11:33 AM | #29 |
I've been bending Axial stubs, all of em are bent actually. Like I'm driving a wobbly wheeled clown car or something.
08-03-2008, 05:42 PM | #30 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
08-03-2008, 07:29 PM | #31 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
| I think they are bending because he is tightening the wheel nut too tight. But I could be wrong! We talked about it last night. I run mine up tight, then back them off a half turn and have not broke or bent an axial stub yet.
08-04-2008, 01:57 PM | #32 |
08-19-2008, 08:07 PM | #33 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
I bent a lubed knuckle today while crawling. OK Last edited by 666; 08-19-2008 at 08:32 PM. Reason: you said.....! |
08-19-2008, 08:32 PM | #34 |
varcor.org Join Date: Aug 2005 Location: 757
after 2 practice runs and testing on an indoor comp course... 1) 2 bent steering links 2) bent aluminum servo arm 3) 2 torn panther tires 4) lower shock rod 5) 2 striped out rod ends |
08-19-2008, 09:15 PM | #35 |
I wanna be Dave Join Date: Oct 2005 Location: Under the 4444
08-19-2008, 09:20 PM | #36 |
Stripped the front gears, broken long shafts, the rest of the stock stubs. It was pure fun though!! Now where are my parts?:-( |
08-19-2008, 09:56 PM | #37 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I was doing some destructive testing on some prototype links and chassis today and I sheared the upper link mount off, and the resulting debris demolished my front gears. All the teeth are still there, but they are in a neat little pile....
08-20-2008, 01:38 AM | #38 |
Rock Crawler Join Date: Jan 2006 Location: PNW!!!
Sheared the pins off the long dog bone inner axle shaft. No one has any in stock. Guess its time to mod the stock shaft w/Axial CVDs. |
08-20-2008, 05:49 AM | #39 |
Pebble Pounder Join Date: Sep 2007 Location: Edison
How about pics of all this carnage
08-20-2008, 07:25 AM | #40 |
Rock Crawler Join Date: Jun 2007 Location: Hopewell
After 4 or 5 packs. Broke 1 stock stub, bent another. Broke 1 STRC knuckle Front gear lost one tooth. Anyone else had issues with the screws coming out of the knuckles? I didn't loctite them yet. Due to that I've lost a couple of the the bushings that the bolt goes through when attaching the knuckle. Where do you get those anyway? |
