08-20-2008, 08:33 AM | #41 |
varcor.org Join Date: Aug 2005 Location: 757
| I had the same problem Mark. I ended up loctite them in.
08-20-2008, 08:36 AM | #42 | |
Rock Crawler Join Date: Sep 2006 Location: Esco.
So far I have bent 3 stock stubs, 1 axial stub and broken two alu servo horns. | |
08-20-2008, 10:03 AM | #43 | |
Rock Crawler Join Date: Jun 2007 Location: Hopewell
08-21-2008, 08:22 AM | #44 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Add 1 broken axle stub o RXCrawler's truck. |
08-21-2008, 08:50 AM | #45 |
Rock Crawler Join Date: Apr 2008 Location: Albany
08-21-2008, 11:20 AM | #46 |
This thread is one rediculous testament to the Berg/OCM's strength. Can you imagine what this thread would have looked like in the Axial section after a few months....... I replaced all the stubs before mine hit the ground. Replaced the knuckle bearings with rubber shielded units due to the failure I had heard of from the SERCRC guys. So far all I have done is broke other none axle related parts due to the axles being SOOOO strong. |
08-21-2008, 09:47 PM | #47 |
Rock Crawler Join Date: Jan 2006 Location: PNW!!!
Yes it's true these axle are tough. The only reason I busted the pins off the dog bone was because the pins slid out of the cup will I was on the course. This binded me up so that I was unable to steer. I was trying to shear the pins off so I could get to the finish line. Busted the pins too late in the game. |
08-21-2008, 09:51 PM | #48 |
Moderator Join Date: Apr 2004 Location: In my head
08-21-2008, 10:00 PM | #49 |
08-23-2008, 06:27 PM | #50 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
I broke my buddy's spirit after he saw how well my rig crawled.
08-23-2008, 07:09 PM | #51 |
i bent two of the stock stubs today. im gonna have to replace them with axials before they start breaking.
08-23-2008, 07:17 PM | #52 |
RCC Addict Join Date: Jun 2006 Location: Sin City
08-23-2008, 07:34 PM | #53 |
08-23-2008, 07:37 PM | #54 |
Adilynsdad too! Join Date: May 2004 Location: G ville
I retired my Berg...
08-23-2008, 07:50 PM | #55 |
Rock Crawler Join Date: Apr 2006 Location: Pineville Ky
08-24-2008, 01:50 PM | #56 |
Rock Crawler Join Date: Nov 2007 Location: San Marcos
I broke a shortside dogbone! 2 bent stubs 2 aluminum servo horns |
08-31-2008, 04:20 PM | #57 |
Rock Crawler Join Date: Apr 2008 Location: Boise, Idaho
I bent a stub at yesterday's comp. Replaced it with AX one.
09-11-2008, 06:43 PM | #58 |
Pebble Pounder Join Date: Aug 2008 Location: Marysville
Anyone have issues with the axle stubs sliding out of the drive gear? In otherwords, one wheel losing drive and free wheeling? There does not seem to be anything but friction holding them in place, but then my Berg is 2nd hand and maybe I am missing parts?
09-11-2008, 06:53 PM | #59 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
| Check to make sure there are still 1-2 (originally white) o-rings stuffed into the cups of the outer stubs. These o-rings limit the moment of the inner shafts, not allowing them to pull out of the final gear. If you received it second hand, the outers may have been swapped out with AX-10s, and the original owner may have forgotten to put the o-rings in.
09-11-2008, 08:15 PM | #60 |
You can use the Blue spare rubber O-rings from Traxxas Shocks I've used these O-rings on my stub axles after doing my quick axle shaft replacement mod on my TLT axles. These O-rings are identical to that of the Berg O-rings. |
