05-10-2010, 06:23 PM | #41 |
I wanna be Dave Join Date: May 2005 Location: CITY of CHAMPIONS!!
| first time using it today, it was great, i ran out of time before it ran out of juice, 20+ minutes, plenty of punch. i like it. they could have used lower gage "smaller" wire on them though..
05-10-2010, 07:04 PM | #42 |
got to run it a bit today with the 3.5" shocks, it did all the stuff i did with the 4" shocks on, had some difficulty breakovers, but it did do them with a little more work/wheel speed. the limited articulation was really difficult to get used to, in fact i still am not, seems like i needed to burp though/over some stuff that i could have crawled before with the 4" shocks. if i didnt the truck would teater and sometimes flop over.. i really couldn't notice much difference in side hilling. i really dont think i can get used to the 3.5" shocks, just doesn't feel right to me, truck feels more rigid, even burping up the vertical stuff it was bouncing more. shocks were bottoming out and casing truck to bounce all over the place. flexes smooth, but just doesn't seem like enough to keep truck stable. running the gold losi spings on the 3" and 90wght oil, same set up in the 4" shocks. will do some more testing tomorrow with the 3.5" shocks. |
05-10-2010, 07:30 PM | #43 | |
05-10-2010, 08:30 PM | #44 |
Rock Crawler Join Date: Mar 2006 Location: North Carolina
I use 15wt oil with gold springs, now that I'm use to it I love it. The added articulation from the 4" shocks just seemed to get me in more trouble then not. Once I committed to a more limited articulation I found it much easier to float over stuff instead of getting hung up in it, I also found it very easy to get out of trouble in V cracks. As far as limited breakover? I'm not sure what you mean, I could run 3 1/2"s of clearance if I wanted with the 3.5" shocks, if you like to run higher then that then 4" shocks might fit your style better. I run at 3 1/8" ground clearance and I know a lot of you think that's not enough, and it may not be for you. I like how stable it feels. At the end of the day you need to set your truck up the way that you feel it works best, remember that your own confidence is the best part of your rig! |
05-10-2010, 09:45 PM | #45 | |
05-10-2010, 09:51 PM | #46 |
They are right at 3.5 eye to eye with out the cap mod, I've also limited the rears by 1/8". I've thought about trying 3" shocks with the cap mod.
05-11-2010, 08:03 AM | #47 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
05-11-2010, 09:30 AM | #48 |
05-11-2010, 10:41 AM | #49 |
thanks guys for all the ideas, i will definitely be trying lots of different set ups, i agree with a lot of what your all saying, and it is true that the best thing to do is learn your rig no matter how it is set up, confidence/knowledge in what the rig can do is the greatest advantage in driving. running a thinner shock oil to me though seems like the shocks would bottom out faster than with the thicker oil, but i'll give it a try. i havent had a problem with the truck flexing too slow, just doesn't "seem" like it flexes enough for my liking, not saying thats goood or bad. and yeah trying a 3" shock is just plain crazy talk lol |
05-11-2010, 10:42 AM | #50 | |
05-12-2010, 12:25 PM | #51 |
i got another pack through with the 3.5" shocks, i didnt change the oil yet, but will try that later. the truck seems just as capable with the 3.5's and im getting more used to how i need to drive it, i tossed the 4" back on and i could really notice a substantial difference in stability with the 3.5" the truck seemed way more loose and floppy with the 4". amazing how running something even for a couple battery packs, makes you more comfortable with what ever current setup you have. lol at this point i am leaning towards the 3.5" but going back out to test 3.5" in the front and 4" in the rear. this gives me a little more flex like i wanted, and also it will hopefully make it more stable than 4" all around. after i decide what size shocks/combo i like, i will fool with the oil wt. thanks again for all the suggestions |
05-12-2010, 01:44 PM | #52 |
The lighter oil and faster shocks results in lifting tires less when you dont really want it to. And I think most people cut the springs down. If you don't, the preload would be crazy tight.
05-12-2010, 03:34 PM | #53 |
You do not have to cut the springs down. I have about a 1/4" preload on them as well. It is not to much preload but if it is for you take the preload out. If you push my rig down and let go, it will have just a bit of sag. (1/8" maybe) If you like more then that you may end up cut them down a bit.
05-12-2010, 04:03 PM | #54 | ||
i was able to run another pack through it today with the 4" shocks in the rear and 3.5" in the front and i have to say i think i really like it set up this way. much more stable than the 4" all around, and a bit more articulation like i like than the 3.5" all around. I was able to do all the lines i did previously with the other 2 shock combos. i will run another couple packs through it this way and then maybe start messing with oil weight. Last edited by rockbound; 05-12-2010 at 04:07 PM. | ||
05-12-2010, 07:39 PM | #55 |
| I'll just keep quiet. Forgot we are running different brands of shocks. Enjoy the truck |
05-12-2010, 08:26 PM | #56 |
05-12-2010, 08:57 PM | #57 |
I wanna be Dave Join Date: Oct 2005 Location: EvilCrawlerDesigns@comcast.net
Come on guys. Rockbound doesn't need any more help. I'm currently ahead of him in our local points series, and now I'm gonna have to work my ass off to keep it that way. Can you guys just give him one little piece of advice per month? |
05-13-2010, 06:23 AM | #58 |
05-13-2010, 07:16 AM | #59 |
05-13-2010, 08:12 AM | #60 | |
