10-31-2012, 09:14 AM | #241 | |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: Skaldiddog's "Progress" Quote:
Great to finally meet you as well. That sure was a blast. You guys were troopers running 48 hours without sleep. I would have crashed and burned big time. Hope to see you at the next one. Thanks for bringing your killer lockers to the market. They rock. J Fab'd a new skid last night. The old one was severely worn after a year or so and the chassis rails were taking a little too much abuse. The new one extends 0.050 below the rails for a little protection. | |
10-31-2012, 11:30 PM | #242 |
Looks good man. The machining on it is cool |
11-02-2012, 09:00 AM | #243 |
| Re: Skaldiddog's "Progress" Gracias Hittman. Some more cool for you. Many folks have commented on how short my rear uppers are so I figured I'd make some that are the same length as my rear lowers to see if there is a difference in performance. Just mocked it up with Ti links and will make the CF ones tonight. An immediate difference is that the chassis now does the "cradle rock" when you alternately torque the front and rear axle by hand. Not sure if this will mean anything on the rocks. Comments appreciated. The mount is a little heavier but meh...what's a gram when it looks that much better than my old rookie mount. I've always found that tapping 7075 in a #43 hole was tight the deeper the tap went. Turns out I'm not the only one. Some genius made vanadium coated taps especially shaped for tapping aluminum (top). Standard tap below for comparison. Man the difference the right tool makes. You gotta try them (McMaster). Next pic is just what it looks like after an evening of fun milling. Making a mess is half of the fun. Next is one of SDS's Super300 seconds with a press fit hardened steel pin ready for install. The gear/pin presses into the larger gear as well for no slop at all. Thanks again John. J |
11-02-2012, 09:28 AM | #244 |
What's the length difference between the old and new uppers?
11-02-2012, 09:34 AM | #245 |
Nice work on the new link mount Joel, I look forward to seeing it "finished". Do you plan to chamfer edges, polish it, or any other nice finishing touches? Chamfered edges will remove a little more weight and it looks like you could remove quite a bit without affecting the part strength for your application. being that is 7075. Very nice milling vise! |
11-02-2012, 10:00 AM | #246 | ||
11-02-2012, 01:02 PM | #247 |
Like that new tap you found. I don't know how many tips I have broke it the past.
11-02-2012, 01:32 PM | #248 |
Nice work. I like the hole in the center. It gives it 70s flair |
11-02-2012, 02:48 PM | #249 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
Congrats brutha...on....well YOU know |
11-02-2012, 03:07 PM | #250 |
| Re: Skaldiddog's "Progress" |
11-02-2012, 03:10 PM | #251 |
Regarding rear upper link lengths on a Berg axle... I noticed with too long a rear upper (especially with high clearance lowers) that the WB change during suspension cycle is pretty big. With the long uppers, as the suspension droops out, the axle will clock backwards, raising the motor and cause the rear axle to rotate under the lower ink mount, causing additional WB change. Conversely, too short of a rear upper will cause the motor to tip forward and down, resulting in less GC, and also a shorter wheelbase. Due to the immense vertical link seperation on the Berg axle, and how far forward the upper links mount on the case, I stil think you need uppers that are shorter than the lowers to keep the axle clock in check during suspension cycle. your custom link mount howeer, looks more vertical and rearward compared to the standard link mount, so you might be better off with closer to equal length links. |
11-02-2012, 03:42 PM | #252 | |
J | |
11-05-2012, 09:24 AM | #253 |
| Re: Skaldiddog's "Progress" Gracias fellas. I drove the new setup with longer rears for a pack or two...then the ESCs died after over a year of heavy use. Slapped the backup ESCs in but it was too dark to do any running. New ESCs on the way from my favorite Tower Hobbies and will call the gents at CC to see what can be done with the old ones. Will update on the links after a reasonable test session. In order to see how the fully integrated changes will work I went ahead and made CF upper rears with my standard fancy 7075 adapters. The adapters weigh half of what a steel grub screw does and the CF links fully assembled weigh half of what Ti ones do. Key to link assembly with two-part epoxy is the small vent hole in the CF tube. Use a pin vice and drill the smallest hole possible. I've noted no strength issues with such a hole. |
11-05-2012, 09:44 AM | #254 |
Those adapters are just plain sexy...very nice work Joel!
11-05-2012, 09:46 AM | #255 |
Ya got some SERIOUS machining skills...for a cholo that is Your rig & skills never cease to amaze me brutha. I dig that you push the boundaries & bring your own visions to fruition...with your own 2 paws. Nice works as always. J.D. |
11-05-2012, 12:03 PM | #256 | |
11-05-2012, 01:49 PM | #257 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
Very nice Joel, those inserts look like cleaning jags can you make thim in 17 cal |
11-05-2012, 02:05 PM | #258 |
Looks like the tinkerings of a weight weenie Nice work! Very shiny. I like shiny things. |
11-05-2012, 05:11 PM | #259 | |||
Damn weight weenies. We got nothing better to do than to blindly go lightweight. As usual any weight weenie exercises I do are offset by the pound under the front axles. Thanks Harvo. | |||
11-05-2012, 06:27 PM | #260 |
Quarry Creeper Join Date: Jul 2008 Location: Hesperia ca.
You have way too much time on your hands. I think you need another kid nice work Joel
