09-28-2013, 09:16 PM | #541 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
The clip is what stops against the bearing and keeps the axle from coming out. In short, yes. |
09-29-2013, 12:16 PM | #542 |
| Re: RcBros Weight Watcher Program
Bergm@N Axle set is complete |
09-29-2013, 09:51 PM | #543 |
Stacked a set of minis this evening for a customer. Figured I'd make a little rough how-to on the process for those not so confident on the process. Holmes BR Mini Stacking How-To |
09-30-2013, 04:56 PM | #544 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
Do your front tubes allow for a 7980?
09-30-2013, 05:20 PM | #545 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
Looking at mine Ted I'd say no. A 9380(same dimensions as 7950s) is extremely tight.
09-30-2013, 05:36 PM | #546 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
| Re: RcBros Weight Watcher Program The tubes don't really change the clearance. If you were running a 7980 before, it should still fit. It really depends on what pinion you're running. Worst case you grind the tube down so the axle shaft is exposed, and make a slightly bigger servo mount. Last edited by sourdojack; 09-30-2013 at 05:43 PM. |
09-30-2013, 05:38 PM | #547 |
Correction, the tube will allow it, the servo mount we have is not wide enough. I was originally going to make one for it, but you are only the second to ask. I can re-check tonight to see how easy it would be to modify the current one.
09-30-2013, 05:45 PM | #548 |
I don't doubt what Tom is saying. He surely has seen more of the tubes than I have but it would be a really tight go. My tube are machine all the the way through and a 7950 is still scrunched in there with 14t pinions and a full diameter motor. |
11-08-2013, 11:03 PM | #549 |
Rock Stacker Join Date: Dec 2011 Location: canada
any chance you still have a chassis ?
11-09-2013, 02:16 PM | #550 |
| Re: RcBros Weight Watcher Program |
RcBros Weight Watcher Program - Similar Threads | ||||
Wheel weight / axle weight advice | JeffK11 | RC4WD Bully | 6 | 03-15-2012 03:30 PM |
Wheel weight Vs Axle weight. | Simon.O. | General Crawlers | 33 | 02-15-2010 07:01 PM |
Wheel weight vs. chassis weight ratio OR spung/unsprung bias | solomon7 | Tires and Wheels | 15 | 08-02-2008 06:26 PM |
