10-25-2012, 11:38 AM | #1 |
Newbie Join Date: Oct 2012 Location: Richfield
| Berg: Newbie mounting motor ? This is my first crawler build so I am sure I am making a rookie mistake. Please help! Motor is tight against the servo I see no way to adjust pinion. Berg Axle Delux tubes & servo mount HiTech 7950 H&H 35T motor TorqueMaster Expert 540 I have read the Dlux instructions and only see it says motor is moved back and up. Is there a different pinion available? Again new so I am sure I am overlooking something simple or got a part that is not compatible. Thanks for the help! |
10-25-2012, 12:21 PM | #2 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
| Re: Berg: Newbie mounting motor ?
Hopefully these pics will help show you how it should be: |
10-25-2012, 12:54 PM | #3 |
I'm looking for some more pictures that show some more options. The way gunnar has his done is the cleanest way, but also offers no adjustment. The pinion you are using is fairly small also...I believe most run a 13t or larger in the front...I run 14t front and rear. Here are some jigs that were available a little while back that would help you with your issue...he might have one to loan or might be able to help you out somehow: Motor Clocking Jigs Here's some pics.. Last edited by ittybitty; 10-25-2012 at 01:09 PM. |
10-25-2012, 01:24 PM | #4 |
I did more of a hack job really, but it worked out OK. I made the upper hole 4mm for a tiny bit of adjustment. I have a pair of all the rob b jigs, Sphofer if you PM me with what pinion you plan on using I can mail you one. |
10-25-2012, 01:39 PM | #5 |
Thanks I am going to try to buy a set but if I can't ill take you on borrowing one. My plan was to run a 13t pinion. Steve |
Berg: Newbie mounting motor ? - Similar Threads | ||||
AX10 Motor Plate/Motor Mounting Problems | md7989 | Electronics | 8 | 11-25-2010 01:30 PM |
Another Newbie- New bright Lr3 mounting | LTL4life | Newbie General | 4 | 08-26-2009 05:38 PM |
AX Link and shock mounting, Vs Berg mounting locations. | BEELZEBOB | Axial AX-10 Scorpion | 4 | 06-09-2009 04:04 PM |
Mounting The battery in the Berg | toxic_mammoth | EnRoute Berg | 3 | 09-03-2008 06:32 AM |
