02-06-2013, 04:30 PM | #21 |
Newbie Join Date: Feb 2011 Location: Australia
| Re: Asso V3
wow looks great no more little grub screws coming loose on those universals |
02-07-2013, 03:24 AM | #22 |
Rock Stacker Join Date: Apr 2009 Location: ITALIA
| Re: Asso V3
Rear carriageway 280mm Front 290/291mm |
02-13-2013, 06:48 PM | #23 |
| Re: Asso V3 |
03-19-2013, 04:41 PM | #24 |
| Re: Asso V3
work continues As for spool and drive shafts I finally finished Spool to its final place That's the most important change, the last piece of the bridge / delrin tube which acts as my door pillow a 9x6x3 alone in the tube could not be there Weight in grams Here's the next step Wheels and weights I'm looking for a way to get the offset that the inner channel variable depending on the occasion Internal channel 20 mm and 25 mm Even the offset will be of different sizes The inner rings will also be delrin or ergal Last edited by rockclimber; 03-19-2013 at 04:45 PM. |
03-24-2013, 08:05 AM | #25 |
| Re: Asso V3
wheel mounted |
03-25-2013, 02:53 AM | #26 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: Asso V3
Love the creative work. Deffently some great ideas in this build. These new wheels look so good |
04-02-2013, 03:35 AM | #27 |
Newbie Join Date: Apr 2013 Location: France
| Re: Asso V3 what amazing job on your steering I have a berg V3 too, with a frame "Dahu". I also find that the steering angle is too short What is the reference for your Steering Knuckles, and C-Hub? Is it for an axial? And your axle shafts is a CVD for a berg V1? Nice work, I admire your job, Francky Last edited by bouky; 04-02-2013 at 03:55 AM. |
04-12-2013, 12:29 AM | #28 |
| Re: Asso V3
hello use for the modification AX30780 AR60 OCP Universal Axle Set then pipe steel 6mm x 4mm internal |
04-14-2013, 05:11 PM | #29 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
| Re: Asso V3
keep up the great work! looking forward to see the running video
04-18-2013, 02:55 AM | #30 |
| Re: Asso V3
Thank's Francky |
03-26-2014, 10:52 PM | #31 | |
Newbie Join Date: Mar 2014 Location: Fort Lauderdale
| Re: Asso V3 Quote:
Please tell me where you got your Dahu. Can they still be purchased? Thanks for your help! | |
Asso V3 - Similar Threads | ||||
Little Review - Asso LRP Crawler ESC with X11 17.5T Motor | Uli | Electronics | 8 | 09-14-2009 08:19 AM |
