03-21-2011, 09:19 AM | #61 | ||
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Honestly, I think it would be overkill. My VXL on 3S is a handful on the hills once it hits the power band. | ||
03-21-2011, 10:34 AM | #62 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
will the new losi sct buggy be a good start for a foff rig?
03-21-2011, 10:58 AM | #63 |
Newbie Join Date: Feb 2007 Location: Germany
Nope, the SCB is only 2WD. For real FOFF you need two powered axles, locked. FOFF is 4WD climbing that is grown extremer, first using offroad tires, then using paddles an special pattern designs. For climbing 4WD is essential, you have to pass gates like in rockcrawling, the rig must be able to navigate precisely on the steepest grounds!
03-21-2011, 11:47 AM | #64 |
I wanna be Dave Join Date: Nov 2008 Location: Too old to care
Well i'v seen enuff must start a build thed,i have enuff parts laying around. |
03-21-2011, 02:13 PM | #65 | ||
Nice!! | ||
03-21-2011, 02:15 PM | #66 |
Rock Crawler Join Date: Jan 2008 Location: Lincoln
Man, this is one cool rig. I'm curious, how is the tranny holding up? Are you running the stock gears? Is it an issue running these high rpm's ? I imagine running at high speed, as opposed to super low torque, would have a different set of "problems".
03-21-2011, 02:18 PM | #67 |
Have you thought of shortening the front wheelbase and stetching it in the rar for a better forward weight bias? I would figure that would make more sense and hellp keep the front end down on the vertical climbs, |
03-21-2011, 02:40 PM | #68 |
That's a good idea... what if you ran a pair of overdrive gears in the axles - would get you a noticeable bump in wheel speed? Dammit, now I've got to build one of these things ! |
03-21-2011, 02:54 PM | #69 |
| You might as wel; just gear up at the trans. it'd be easier. But i think overdriving the front would also help pull it up the hill.
03-21-2011, 03:01 PM | #70 |
Quarry Creeper Join Date: May 2010 Location: Plumas county
Lol I've got a mini desert trophy truck that's going to get foff'd up some |
03-21-2011, 03:24 PM | #71 | ||||
I am running the stock transmission and axles, no upgrades at all. So far, I haven't had any issues with the extra power breaking parts, and these axles were heavily used in my rock racer before I threw them in this rig. Quote:
Get some! | ||||
03-21-2011, 05:19 PM | #72 |
Great truck Brad, the brushless set up has some mean rooster tails on all four wheels. How much width did you take out of the body? |
03-21-2011, 05:46 PM | #73 | |
If I remember right I took just over an inch out. But, I cut this body in half a few years ago, so it's tough to recall. | |
03-21-2011, 08:59 PM | #74 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
What gearing did you finally settle on? Any wheel weight added? Do you know rtr weight? I'm thinking these are gona be pretty lite.......and with all the horse power |
03-21-2011, 09:11 PM | #75 |
| I am at 20/87 right now. Need to find some bigger hills to see for sure, but it seems good to me. No weight added to the wheels. I am not sure on total weight, but I will check after I finish repairs. It is pretty light though. |
03-21-2011, 10:41 PM | #76 |
Thx, I was thinking the lighter weight would help all around.
03-21-2011, 11:44 PM | #77 |
Newbie Join Date: Mar 2011 Location: Los Angeles
that is so cool man i have never seen a rc truck set up with paddle tires . if u dont mind me askin how much does a set up like ur cost?
03-22-2011, 08:57 AM | #78 | |
OG SCX10 kit - $215 MaxAmps 5250 3s - $150 Decent high torque servo - $100 VXL system - $170 Wheels, tires and body - $125 2.4 Radio - $150 That's just a rough estimate of the major components. | |
03-22-2011, 10:51 AM | #79 |
whats a good tire set up?i was thinking wide in the rear n narrow for the front.is the narrower the better for front?thanks
03-22-2011, 10:59 AM | #80 |
| I have been debating the same thing. I may try narrowing a set of wheels for the front axle and see. Panther paddles are the way to go, according to what I have been told. I just bought another set for the front of mine.
