03-22-2011, 12:05 PM | #81 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
Nice rig BENDER My friend but his rustler parts in his creeper,and we added the biggest pinion the creeper gerbox would eat http://www.youtube.com/watch?v=E0A2EysTLos I can see myself with a formula offroad ride too |
03-22-2011, 12:12 PM | #82 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
That location in the video looks perfect for these type of rigs. | |
03-22-2011, 12:33 PM | #83 |
Yeah we have no rocks but plenty of dirt and sand I havent seen any one riding ther FOFF on water ? A slightly upped e-maxx with paddles wont cut it lucky i insisted we tested that on shallow water first. |
03-22-2011, 04:08 PM | #84 |
| I haven't found any water in the areas I drive this rig yet. If I do, I will make sure it's shallow first too. |
03-22-2011, 05:07 PM | #87 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
How much does the suspension on your rig actually work Brad? Is there even enough weight in the chassis to make the shocks absorb bumps and jumps or do the tires do most of it?
03-22-2011, 05:18 PM | #88 | |
| Quote: It actually works more then I was expecting. I went with soft springs, and 30wt oil. But, my shock piston holes are small, so the oil feels thicker. It felt too stiff to me after I built them. But, feels great when driving. I definitely don't have a lot of travel, but it seems to me like I have enough. | |
03-23-2011, 05:01 AM | #89 |
| clearly we did not have what it took in the heavy e-maxx back then. i better forward that skimming video to my friend I assume we could mount the engine and a even bigger pinion and then assemble the rest of the gearbox around that to get more power and some heat on the motor + esc, witch by the way is pretty cold after 10-15 minutes with the current setup ( pinion same size as hole in creeper gearbox and 3S witch is all the esc can handle ) |
03-23-2011, 07:46 AM | #90 |
Pebble Pounder Join Date: Jan 2011 Location: Deltona Fl.
well....i almost get my bully together and i find this section of rcc.... guess ill be building one of these now! |
03-23-2011, 10:19 AM | #91 |
03-23-2011, 01:54 PM | #92 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
Great build, looks like tons of fun to drive! I already have a CC 4600kv brushless on my RTRunner build, now just need some paddles and a new body... That Axil spur gear cover looks like a trick part. I need to pick up a few of those but CKRC an Tower are out of stock, how do I get some? |
03-23-2011, 03:04 PM | #93 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
X2, when are the gear covers available.
03-23-2011, 03:09 PM | #94 | |
The spur gear cover is the ticket for sure. But, some motors will either require trimming the end of the pinion shaft, or drilling a hole in the cover, as the pinion shafts are too long. This cover is intended for standard 540 motors. I did the latter of the two, and covered it with a little electrical tape. I am going to use some styrene and shoo goo to make a permanent, more air tight fix though. The spur gear covers haven't hit the hobby shops yet, but they should soon. | |
03-23-2011, 04:49 PM | #96 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
my build just begun thanks for not keeping any money in my pocket
03-23-2011, 06:15 PM | #98 |
03-23-2011, 07:51 PM | #99 |
I joined the Band! Join Date: Apr 2007 Location: norfolk
Man we tried to get Formula Offroad going last summer seems to be getting pretty popular all of a sudden... What one Awesome ass Video from Bender can do..Must be the Music... |
03-23-2011, 09:00 PM | #100 |
RCC Addict Join Date: Mar 2008 Location: SSF
| Post #39 here has "My AFOR info" link to my FOFF. We called it AFOR for American Formula OffRoad but F'OFF has a nice ring to it. Mine is an OFNA Hyper 10, Novak HV4.5 Big Can, MMPro and Sand Paws and a Hyperion 4KmAh 4s. Before that video I ran across that water about a dozen times. The rig has complete steering control in the water as seen in the video, the last pass it veers to the right and I correct it left back to the water's center. This one was purposely built just to satisfy my hydro curiosity but it sadly smoked the ESC when it stopped in the video. I'm not too sure how and Axial tranny will handle this type of power without all aftermarket parts, including an Al trans case to keep the bearing from deviating. I'll have a thread on my Unlimited FOFF going up this weekend hopefully. This one is purposely build for water too, including internal buoyancy precautions (much deeper water crossings). A Platinum 4x4 Slash is the format. These toys are crazy fun for me and I'm glad it's finally interesting others. |
