03-29-2011, 07:49 PM | #41 |
Quarry Creeper Join Date: Mar 2010 Location: canada
im digging the rjspeed 80's body!! looking good. i run the rjspeed jeep looking body on mine. have you had it out for a test run since the upgrades? i have to take alot of flex out of mine to make it hook up better. hard to get traction to the ground with the tires bouncing around. |
03-30-2011, 11:13 AM | #42 |
Quarry Creeper Join Date: Feb 2006 Location: Sacramento
| Yours is one of my favorite builds so far. I really like the fact that the body sits as low as it does. With my layout (Jim’s FOFF) there is no way I can get the body any lower without a lot of reconfiguration. What time are you planning to be out at Folsom Lake this Saturday, I am not sure I am going to have rest of my parts by then and I will have my kids (wife’s out of town), but I would like to check it out anyway. |
03-30-2011, 11:15 AM | #43 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
your rig looks awesome |
03-30-2011, 11:19 AM | #44 | |
I wanna be Dave Join Date: Nov 2008 Location: Too old to care
03-30-2011, 11:52 AM | #45 |
Driveline shot |
03-30-2011, 01:07 PM | #46 |
It's looking sick with the body slammed like that |
03-30-2011, 11:29 PM | #47 |
Will be painting up another RJspeed body, 70s style they just fit my rig Last edited by MR.VERTICAL; 03-31-2011 at 08:07 AM. |
03-31-2011, 06:06 AM | #48 |
Pebble Pounder Join Date: Jan 2006 Location: Chattanooga
By far my favorite yet.Super low looks super.Great build!
03-31-2011, 11:37 AM | #49 |
Well got the body cut to fit now for some paint. |
03-31-2011, 01:33 PM | #50 |
| This profile is killer. The more I look at the Trail Ranger I was planning to use, the more i think I need a fender flareless body so the rear section won't look funny when trimmed. |
03-31-2011, 02:21 PM | #51 |
This profile is killer. The more I look at the Trail Ranger I was planning to use, the more i think I need a fender flareless body so the rear section won't look funny when trimmed. What nice is all 3 of rjspeed bodys fit really good but you do have to cut the frount fender off . Sould have the other back up body done today. |
03-31-2011, 05:33 PM | #52 |
Just a rattle can paint job so here it is RJspeed 70s modified |
03-31-2011, 07:11 PM | #53 |
That turned out really sick. Great job |
04-01-2011, 09:12 AM | #54 |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
| Looks great! Action shots now required! |
04-04-2011, 10:42 AM | #55 |
| Spec sheet Axial Scx10 modded Futaba 3mx Traxxas VXL system Panther paddles f&r, rims Vanquish Pro comp with 850,foams stock modded Axial axles front Stage 3 locker Vanquish highrise knuckles,overdrive .Rear stage 3 lockers Vanquish lockouts and overdrive. Axial trans all RRgears and alum trans housing, running gear is 22t,87t. Shocks Acc. 54mm or 2.5in Servo Hitec 5995 Body RJspeed |
04-04-2011, 10:46 AM | #56 |
Went to a alum trans because after 3hr. of driving this the plastic housing was deforming a little from the heat need to get the vanquish alum housing.
04-04-2011, 11:01 AM | #57 |
P.S.make sure you close off the holes on top of your axles this is just 3hr. of running. |
04-04-2011, 04:33 PM | #58 |
Quarry Creeper Join Date: Feb 2008 Location: port jefferson station
what is your wheelbase and what links did you use ' looks awesome...
04-04-2011, 05:55 PM | #59 |
RCC Addict Join Date: Mar 2008 Location: SSF
| I knew that would happen. I've seen Slash trans housings go to poop in high speed conditions. Same thing, bearing deflection and gears go capooy.
04-04-2011, 07:26 PM | #60 |
