05-03-2011, 09:27 PM | #81 |
Rock Stacker Join Date: Jan 2005 Location: Kentucky
No problem man. Always better to have numbers instead of estimates, right? haha Keep us updated though, im anxious to see how this turns out. |
05-04-2011, 08:24 PM | #82 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
hey man, got a question for ya. i see you are gonna have the clutch bell on that motor. but i was wondering of you are running spools in the axles or not? i am not sure what type of driveline would be best for this type of rig and wanted to know your thoughts. in my mind of using brushless i wonder if the stock center TF tranny would work with the slipper with spools in both axles, or diffs, or a combo. what do you think? |
05-05-2011, 06:35 AM | #83 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
Got a shaft done. Now time for some links. Built some frame rails. This is how I will bolt the body to the chassis plate These are the hiems I will be using. Hope they hold up That's a Revo nevt to it And a mock link |
05-05-2011, 08:28 PM | #84 |
chassis look good man. its coming along nicely
05-06-2011, 06:16 AM | #85 |
Rock Crawler Join Date: Sep 2010 Location: Keego Harbor, MI.
Yes, Yes....... Very nice indeed I like the side Channel on the skid Very Cool Idea Keep Going V8 |
05-06-2011, 07:14 AM | #86 | |
05-06-2011, 03:21 PM | #87 |
I dont know how tough a stock twin force tranny is, but a single 1/8 scale brushless system will make the two 550's look like slugs. I had an E-Savage transmission in my monster GT with two 550's. I was hard on the tranny with the 550's, going from still rolling backwards, to WOT forward at time, etc... Put in a brushless motor and murdered the tranny gears on the 2nd run. lol Truck is looking great |
05-06-2011, 05:02 PM | #88 |
I've stalled out my 10t puller on 3S plenty of times and the trany was the last thing I was worried about. I know slow isn't as destructive as fast, but as long as the chain and the mounts are structurally sound I don't think there will be an issue. Unless you go 1/8 bl on 6S. Not sure any trany would hold up to that.
05-06-2011, 11:11 PM | #89 |
hey bart. thanks for answering that. i have been brainstorming and drawing pics of what i would do with a FOFF rig. going for a center diff would probably be easiest, and stringest. but i have that stock tranny laying around and would love to use it for something. i might go a bit thicker with that rear diff at some point too. all that spinning is bound to really make that diff work hard. buit if you can keep the front tires on the grip, it should be enough to keep the rear tires working well. |
05-06-2011, 11:31 PM | #90 | |
I completely forgot that it is just a chain drive setup. Id say that will hold up to darn near anything | |
05-08-2011, 07:06 AM | #91 | |
Sorry no updates. All the things that go with life interrupt progress | |
05-14-2011, 08:37 PM | #92 |
Itty bitty update. So many projects so little time Start of front radius arm suspension And got the ass installed Center spool installed and rear output for truggy shaft makes it exactly 18"WB Last edited by Bart bender; 05-14-2011 at 08:50 PM. |
05-15-2011, 06:49 AM | #93 |
Rock Stacker Join Date: Sep 2010 Location: Cedar Rapids
Watch out for the blue places on the cage, they be REAL hot! |
05-15-2011, 09:02 AM | #94 |
Rock Stacker Join Date: Mar 2011 Location: Dunlap
This thing is going to be amazing, i noticed you haven't set up a throttle linkage yet, i would look into one from a t-maxx or monster gt, either one should work great. Also where did you get the spool for the center diff?
05-15-2011, 06:50 PM | #95 |
They were damn hot weren't they Saundo Thanks That particular one is a CDW from way back. www.supershafty.com can fix you up with a new spool and anything else you might need for your Force axles |
05-17-2011, 05:12 PM | #96 |
wow man that is coming along really nicely. is that extended center drive shaft off the spool something you made? or did you have V8 hook you up? i like it either way!!!! seems like the suspension arms are gonna be short, comparatively, to a crawler suspension arm. is that helpful in the high speed of the FOFF's? can't wait to see this thing on wheels!!! |
05-17-2011, 05:48 PM | #97 |
The links are short cause there is half the travel that a crawler has. The mid shaft is something a buddy fabbed for me. Originally it was for inside a TF axle. I was playing around with the idea of some WIDE axles. It fits perfectly on this rig for an 18" wheelbase. The front end is mounted. Now for the track bar and the rear ladder bars to mount to the Super Shafty link mounts I gotta get some paddles ordered to really make this thing shine don't I |
06-01-2011, 06:15 PM | #98 |
Yah yah yah. It's takin awhile. That's the way I roll She's linked up. SuperShafty servo mount and SuperShafty beefy link mounts in the rear Just gotta finish up the track bars Last edited by Bart bender; 06-01-2011 at 06:18 PM. |
06-01-2011, 07:13 PM | #99 |
Pebble Pounder Join Date: May 2011 Location: Fort Bliss
Just curious what you use for making your bends. Do you bend them by hand or do you use a tubing bender?
06-01-2011, 08:22 PM | #100 |
Newbie Join Date: May 2009 Location: Loveland
love the idea of putting the motor in the front. great build
