01-29-2012, 04:43 PM | #61 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: UGC-FF4 Foff, SPEED DEMON
Team foof!!!! |
01-29-2012, 05:18 PM | #62 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Re: UGC-FF4 Foff, SPEED DEMON :l mao: That's Billj's private club. :l mao: |
01-29-2012, 09:26 PM | #63 |
| Re: UGC-FF4 Foff, SPEED DEMON I just cracked open the old trans case and found that the middle gear is still plastic,. Now i have to order that gear. Oh well plenty other things to work on till it comes in. |
01-29-2012, 09:51 PM | #64 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
Maybe just install the pastic gear and call it TEAM POOF. |
01-30-2012, 03:55 AM | #65 |
| Re: UGC-FF4 Foff, SPEED DEMON If we ain't foofin', we're poofin'!!! |
01-30-2012, 06:08 AM | #66 |
| Re: UGC-FF4 Foff, SPEED DEMON ! ! ! ! ! ! ! !
01-30-2012, 06:38 AM | #67 |
| Re: UGC-FF4 Foff, SPEED DEMON Thats a sure fire way to blow up a tranny. I'll order it today and start on the axles. |
01-30-2012, 04:56 PM | #68 |
I got the RR gears ordered, I'll get back to the trans when they come in. As for now, I'll be working on getting the axles built along with rebuilding and limiting the shocks..
01-31-2012, 08:22 PM | #69 |
Im in the process of tearing down both axles and rebuilding them with the cases I have. I will post some pics soon. |
01-31-2012, 09:27 PM | #70 |
I want pictures, I want to see those pretty axle housings with some grease in them. Wait, did that sound bad ? |
02-01-2012, 06:38 AM | #71 |
Not at all. Im also looking for pinion shims. Going by Ace hardware to see if I can find some thin washers that might work. I'll get some pics up soon. |
02-01-2012, 10:56 PM | #72 |
here are some pic's of the progress i have made on the build. Tranny pulled. front axle pulled and the beginning of the rebuild. All new bearings going in the front axles. I put 1 shim in the front axle behind the pinion. Lubed the gears with a moly fortified wheel bearing grease. The flash on my camera really shows off the new Boca Bearings i installed. Here is the axle case all together with the C-hubs installed. this is the knuckles with the BB installed. Sorry about the FUZZY pic. . Almost done. Ready for install.:flipo ff:. Thats right, behind the axle steering. Thats all the progress for now. Next up is the rear axle.. Stay tuned for more pic's and progress, Thanks for watching.. Last edited by stelerzman; 02-01-2012 at 11:00 PM. |
02-01-2012, 11:52 PM | #73 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
| Re: UGC-FF4 Foff, SPEED DEMON |
02-02-2012, 12:48 AM | #74 |
im envious of those axle housings still compensation is i have some wraith axles on the way. that means i can lower my body and chassis an inch or so. very nice build you are doing |
02-02-2012, 04:41 PM | #75 | |
| Re: UGC-FF4 Foff, SPEED DEMON Quote:
Thanks, i can't wait to see your build. | |
02-02-2012, 04:46 PM | #76 |
I started working on the rear axles when i found this problem. I have to grind a little material off the lockout for them to fit. I know i could have bought the GH lockouts but i didn't like the way they looked. These look sleeker so I'll modify them.. |
02-02-2012, 05:15 PM | #77 |
Rock Crawler Join Date: Oct 2011 Location: south of nowhere
WOW All those shiny new parts.......they look way to nice for some FOFF basher. You should shit can this whole project and send those my way, and I'll send you some experienced parts in return.... Just looking out for fellow member What do you say? |
02-02-2012, 05:28 PM | #78 |
| Re: UGC-FF4 Foff, SPEED DEMON well at least it will be a good fit. sometimes stuff like that can be too slack, especially if they come from different manufacturers.
02-02-2012, 09:36 PM | #79 |
| Re: UGC-FF4 Foff, SPEED DEMON Too funny. I'll let you know how my build works out and get back to ya..:mrgree n: |
02-02-2012, 09:37 PM | #80 |
UGC-FF4 Foff, SPEED DEMON - Similar Threads | ||||
Want to build a speed demon... have a few questions | mcho78 | Non Crawler RC's | 11 | 03-31-2012 09:57 PM |
UGC F4 or FF4 ? | bubbaskyjacker | Axial AX-10 Scorpion | 12 | 12-05-2010 08:40 AM |
