02-11-2012, 12:41 AM | #21 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
| Re: My new FOFF build
Good build, very different, the gearbox , are all the gears stock SCX10 ? Wouldn't have thought they'd have taken the beating from that brushless.
02-11-2012, 01:29 AM | #22 |
Rock Crawler Join Date: Oct 2011 Location: Co,Cork..Ireland
| Re: My new FOFF build |
02-11-2012, 06:07 AM | #23 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
Well their is no question what you are planning to do with this rig Sean. Looks like the mud bogs are in its future. |
02-11-2012, 08:03 AM | #24 | |
| Re: My new FOFF build Quote:
There's a idea.. Never thought about going to the Bogs with it... Here a bit of a up-date guys, not a lot But we all know these things take time... Refitted the Battery plate lower...Velco to help hold the Li-Po in place.. Test fit with 2200mAh Li-Po.. Found a Futaba Servo box in my Glider spares box , big enough to fit ESC and allow it the breath Still have to work out what to do about the postes, ( Im needing a High Lift post bar for the body I have) Side view will all leccy stuff fitted and ready to run.. Sean . .. Last edited by West Cork Basher; 02-11-2012 at 08:29 AM. | |
02-11-2012, 08:12 AM | #25 | |
WOW Sean ! This is looking amazing, I bet it would be better with some custom links . I know Calvin is working hard to get you running soon. It is my guess it will take longer for you to receive then for him to make. | |
02-11-2012, 08:37 AM | #26 | |
Custom links Calvin is mailing them to me next week then another week-ish for them to arrive.. Still have to sort out OD F/R and beeftubes Sean | |
02-11-2012, 11:37 AM | #27 | |
RCC Addict Join Date: Oct 2009 Location: San Francisco
On a different note, your really making me jealous man! At least I have a package or 2 for my secret build coming | |
02-11-2012, 01:19 PM | #28 | |
Yes you are Paddys Day is coming (17th March),,, I'll need a months worth of drinking money , just for that day.. Your Jealous I'd like to be let loose in your work shop for a day or three.. with the milling machine Sean | |
02-11-2012, 01:29 PM | #29 | |
Oh be jealous... be VERY jealous. I make to much crap in my shop... way to much. Helps my friend has his mill living in my shop for the moment as I computerize it if your ever around my area ill let you peek at my shop | |
02-11-2012, 01:31 PM | #30 | |
RCC Addict Join Date: Nov 2010 Location: England
Nice build Sean. i made some beef toobs out of stainless steel tube a while back as i stripped the threads on the aluminium ones i made. might be able to do some more sometime, will let you know. im short of money this month, so the wraith axles and stuff are on hold. planning a new chassis anyway Last edited by M1tch; 02-11-2012 at 01:34 PM. | |
02-11-2012, 01:44 PM | #31 | |
and if you ever over my way I'll buy you a Guinness | |
02-12-2012, 12:41 PM | #32 |
02-12-2012, 12:48 PM | #33 | |
Too much Guinness turns you poo black . . Yeah... it does taste better over here, it's something to do with Guinness don't travel well . . . .. | |
02-14-2012, 01:24 AM | #34 |
How I mounted my servo plate... Test fitting my steering linkage.. These photos are just the test fit... I may have to mess with my steering linkage once I get my custom lower/upper links.. Sean. Last edited by West Cork Basher; 02-15-2012 at 03:57 AM. |
02-14-2012, 06:12 AM | #35 | |
I know it is difficult to get parts, you may want to get a Lunsford drag link though. only for the purpose of its smaller diameter. You may have to either, space the existing drag link away from the pinion or put a small notch on the axle housing, to allow easy movement of the link. | |
02-14-2012, 07:43 AM | #36 | |
What are drag links ... got a photo... Sean . .. | |
02-14-2012, 08:10 AM | #37 |
| Re: My new FOFF build The drag link and or tie rod that goes from steering knuckle to steering knuckle. This is a Lunsford unit I run on my Foff. I will be running it soon on one of my crawlers " THE METAMORPHOSIS " Death of the Bodiless Sportsman it is On order. |
02-14-2012, 09:00 AM | #38 | |
Oh !!! I get you now... In my photo it looks like the stock drag link is rubbing on the axle bell housing,, it's not... I got the dremel out and sorted that when doing the test fit..there's just enough clearance for it... But a Lunsford drag link sounds good , where would I get one ? not in my local hobby shop thats for sure... Sean | |
02-14-2012, 09:00 AM | #39 |
Rock Stacker Join Date: Sep 2011 Location: Perth, Western Australian
Looking great mate !
02-14-2012, 09:05 AM | #40 | |
Lunsford New Titanium 4mm x 122mm Drag Link: AX10 LNS8531 | |
My new FOFF build - Similar Threads | ||||
where the Foff am I gonna foff build | ctrwannabe | Formula Offroad | 8 | 11-30-2012 07:37 PM |
brianw's - I don't know what it's going to be - FOFF build | brianw | Formula Offroad | 50 | 03-15-2012 02:56 PM |
Need help finding foff build | phxguy | Formula Offroad | 10 | 11-08-2011 01:19 PM |
I want to build a FOFF ( Ax-10 ) | West Cork Basher | Formula Offroad | 4 | 10-14-2011 03:09 PM |
Going to build foff need help | Motomeyhem | Formula Offroad | 2 | 08-03-2011 12:39 AM |
