03-04-2012, 02:52 PM | #81 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
| Re: My new FOFF build
Lookin good! One things Dan and I noticed when driving his SPEED DEMON was the lack of width on the car made it tricky to drive. Esp on pavement... oh well you ran it and had fun! Now if you can only get the dog to stop making your driving harder (LOL!) or is that a good thing? Last edited by Crawling Calvin; 03-04-2012 at 04:13 PM. |
03-04-2012, 03:47 PM | #82 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
Should i take offense? JK..
03-04-2012, 04:22 PM | #83 | |
Rock Crawler Join Date: Oct 2011 Location: Co,Cork..Ireland
| Re: My new FOFF build Quote:
Wider axles or some of your wheels would sort that out. Sean. .. | |
03-06-2012, 09:01 AM | #84 |
Just to keep this thread up-dated ... Parts List.. so far.. Axial SCX Chassis. Axial SCX/AX-10 Gearbox with HR steel Gears , Robinson Racing OutDrive. Axial Spur gear cover (AX8007. Axial SCX/AX-10 Axles. Axial Over Drive 63t/14t Gears (AX30401) Front/Rear. Axial SCX High Mount body post (AX80031). Axial SCX Ride Height Ajusters . Traxxas Revo/Slayer Pro Alloy GTR Shocks (5460x). Traxxas Jato Shock springs GTR (0.9 Yellow) (5427). Turnigy 2200mAh 3s 25c Li-Po. Mtroniks Plasma45 6.5t (4400kv/rpm) Motor. Turnigy TrackStar 1/10th Scale 60amp ESC. Ansmann Racing 14t Pinion 32pitch. Traxxas 54t Spur Gear 32pitch. JunFac Universal Drive Shafts (J90026) for Gmade R1 (140mm max lenght). Steering servo (BMS-660DMG+HS 14.2kg/.17sec) from Hobbyking. Traxxas T-Max Alloy Servo Guard. ST Racing Axial SCX/AX10 4 link plate (front and rear). ProLine Jeep shell. Custom made links. Shock hoop braces= 2x 75mm Front= Upper 86mm Axial Rod ends , Lower 100mm Axial Rod end. Rear= Upper 91mm Axial Rod ends , Lower 106mm Traxxas Rod ends. Axle tubes Alloy C Hubs and knuckles.. Sean Last edited by West Cork Basher; 04-22-2012 at 05:00 PM. |
03-06-2012, 10:28 PM | #85 |
| Re: My new FOFF build Axle tubes haven't shipped yet (my bad, ill explain in an email, i am slammed with... crap end of story ) but if you want a pair leme know.... im runnin low on the Delrin stuff but I think I got enough |
03-06-2012, 11:52 PM | #86 |
It's not the narrow width that makes it difficult, it's the lack of differentials. High traction and locked differs cause axle hop when turning, which tosses the rig upward & outward. Trust me. When I had "WHAT?!" running, that thing would flip over like crazy even with my low CG setup. Once I swapped out the lockers for open duffs (packed with the thickest grease I could find) that sucker became super stable. My plan is to run my super trick SCTE direct drive (which has a diff for torque split) and an open front & locked rear diff. The direct drive will be twic as fast with the same electronics package (no internal gear reduction) and it'll still have plenty traction to put power down.
03-07-2012, 01:36 AM | #87 |
RCC Addict Join Date: Nov 2010 Location: England
it can depend what surface is being driven on though. in sand, loose dirt, mud, my foff runs fine. any hard packed surface it handles like crap because of the locked diffs and overdrive/underdrive axles. i have an overdrive rear axle i can use, but its ok for trail driving, not too good on steep dunes. when i build my next foff, the one i have now will be a trail truck and i will experiment with open or lsd diffs. |
03-07-2012, 10:16 AM | #88 |
Fitted the longer links to the front... Link sizes now... Front Upper 88mm Axial Rod ends , Lower 106mm Traxxas Rod end. Rear Upper 91mm Axial Rod ends , Lower 106mm Traxxas Rod ends. But by doing the front links the steering servo/axle came forward .. So had to trim the shell as well.. Made some mud guards our of a old container ( Philadelphia cheese) This should help keeping the sand from getting to the fan on my ESC.. Sean.. . .. Last edited by West Cork Basher; 03-07-2012 at 10:19 AM. |
03-07-2012, 10:24 AM | #89 | |
When it comes to exceptional performance on all surfaces, think truggy with 3 differentials. | |
03-10-2012, 07:01 AM | #90 | |
I have a suggestion for the servo guard, Put a bumper on it. | |
03-13-2012, 04:44 AM | #91 | |
The Wheel wells work great at keeping the sand off my ESC.. As for the bumper it's a good idea as I have a few alloy T-Maxx ones that would fit, but the bumper would move with the axle and I think that would look odd... Mite try and mod the chassis and see how that works out.. Sean. .. | |
03-13-2012, 04:54 AM | #92 |
Alloy C hubs and Knuckles arrived today. Just got to fit them now Sean. .. |
03-20-2012, 06:58 AM | #93 |
Fitted my Alloy C hubs and Knuckles.. Swapped the shell over aswell for a Landrover D90,that I'd got with another scaler.. Sean. .. |
03-20-2012, 07:44 AM | #94 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
Hey Sean, Sorry it has been awhile since I posted. This thing is looking Awesome ! I really like the scaler look. When things work out and I can get the paint job I am wanting on mine. I will be headed in the same direction. Here you are all the way over their and your build is done before mine. |
03-20-2012, 08:08 AM | #95 | |
Thanks Daniel.. It's slowly geting there , but it's geting there..LOL.. Mite drop the shell lower by another hole or two on the posts, then have to trim the body.. just for the lowerd look Sean. .. | |
03-20-2012, 08:51 AM | #96 |
Without question it will look even meaner then. Also the lower center of Gravity will help on those hill climbs.
03-20-2012, 12:56 PM | #97 |
it looks good Sean. as has been said, lower the body a bit and it will look much better. also get rid of the shovels and stuff.. it looks like an expedition foff lo.... just imagining it flying across a desert somewhere, loaded up with fuel and water lol |
03-20-2012, 02:21 PM | #98 |
| Re: My new FOFF build |
03-20-2012, 03:17 PM | #99 |
ooooh owww! that hurt!! i like the look of those bowlers. nice build thread on ukrcrc UKRCRC :: View topic - 1/8 tuber bowler tomcat back on topic.. cant wait to see it run |
03-20-2012, 03:37 PM | #100 | |
Flying season has just started so I'm catching up with the Gliding.. Yeah... I'll remove the scaler stuff and the lights... I've another scale build starting soon , so I'll be using the first shell for that and the scale parts aswell.. Sean | |
My new FOFF build - Similar Threads | ||||
where the Foff am I gonna foff build | ctrwannabe | Formula Offroad | 8 | 11-30-2012 07:37 PM |
brianw's - I don't know what it's going to be - FOFF build | brianw | Formula Offroad | 50 | 03-15-2012 02:56 PM |
Need help finding foff build | phxguy | Formula Offroad | 10 | 11-08-2011 01:19 PM |
I want to build a FOFF ( Ax-10 ) | West Cork Basher | Formula Offroad | 4 | 10-14-2011 03:09 PM |
Going to build foff need help | Motomeyhem | Formula Offroad | 2 | 08-03-2011 12:39 AM |
