03-21-2012, 04:45 PM | #101 | |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
| Re: My new FOFF build Quote: | |
04-07-2012, 01:53 AM | #102 |
Rock Crawler Join Date: Oct 2011 Location: Co,Cork..Ireland
Just a up-date guys to keep this thread alive... A few parts still to sort out , like axle tubes... Not doing much on this build at the moment , as the Paragliding season has started so I'm off flying most weekends... Sean. .. |
04-08-2012, 06:45 PM | #103 |
Quarry Creeper Join Date: Feb 2012 Location: Adams, MA and Florida, MA
Wow cool build keep up the good work. that body fits perfectly so it looks very scale. I like it
04-09-2012, 01:26 AM | #104 |
| Re: My new FOFF build |
04-09-2012, 03:51 PM | #105 |
Great looking rig. Good job. |
04-22-2012, 06:27 AM | #106 |
Axle Tubes arrived the other day , Thanks Calvin Fitted the shorter(47mm) tubes to the front axle .. These are not a copy and are different to the "Beeftubes as sold by a vendor on this forum" you dont need to hack up the plastic axle houseing for them to fit.. Sean . Last edited by West Cork Basher; 04-22-2012 at 06:30 AM. |
04-22-2012, 11:06 AM | #107 |
Fitted the longer 55mm length tubes to the rear axle.. Had the ground out the axle housing to get these tubes to fit.. Drilled and taped a 3m thread into the tubes.. Rear axle all finished and ready to be re-fitted.. Sean. .. Last edited by West Cork Basher; 04-27-2012 at 04:17 AM. |
04-22-2012, 11:20 AM | #108 |
RCC Addict Join Date: Nov 2010 Location: England
| Re: My new FOFF build you wont be breaking those anytime.. |
04-22-2012, 12:13 PM | #109 |
04-22-2012, 05:09 PM | #110 |
Complete parts list.. Axial SCX Chassis. Axial SCX/AX-10 Gearbox with HR steel Gears , Robinson Racing OutDrive. Axial Spur gear cover (AX8007. Axial SCX/AX-10 Axles. Axial Over Drive 63t/14t Gears (AX30401) Front/Rear. Axial SCX Ride Height Ajusters . Axial Rockster Rims and Beadlock Rings . Pro Line Sand Paws Tires. Traxxas Revo/Slayer Pro Alloy GTR Shocks (5460x). Traxxas Jato Shock springs GTR (0.9 Yellow) (5427). Turnigy 2200mAh 3s 25c Li-Po. Mtroniks Plasma45 6.5t (4400kv/rpm) Motor. Turnigy TrackStar 1/10th Scale 60amp ESC. Ansmann Racing 14t Pinion 32pitch. Traxxas 54t Spur Gear 32pitch. JunFac Universal Drive Shafts (J90026) for Gmade R1 (140mm max lenght). Steering servo (BMS-660DMG+HS 14.2kg/.17sec) from Hobbyking. Traxxas T-Max Alloy Servo Guard. ST Racing Axial SCX/AX10 4 link plate (front and rear). STRC Alloy C Hubs carriers. STRC Alloy Steering knuckles. Landrover D90 shell. Axle Tubes. 47mm front/55mm rear. Custom made links. Shock hoop braces= 2x 75mm Front= Upper 86mm Axial Rod ends , Lower 100mm Axial Rod end. Rear= Upper 91mm Axial Rod ends , Lower 106mm Traxxas Rod ends. Sean Last edited by West Cork Basher; 04-23-2012 at 12:52 AM. |
04-22-2012, 11:25 PM | #111 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Good work with my tubes I never used Now go out and drive it |
04-23-2012, 12:51 AM | #112 | |
Thanks again Calvin.... The Shoter 47mm ones are the way to go if you don't want to grind down the axle housing.... Just got to put it all back together now... Will give you a test report soon... Sean . | |
04-25-2012, 08:05 PM | #113 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
very nice build!
04-26-2012, 12:40 AM | #114 |
05-01-2012, 06:27 AM | #115 |
Well it all back together again and ready to run.. Removed all the scale parts and the lights.. D90 Shell trimmed and lowered.. Alloy rear bumper.. Sean. . |
05-02-2012, 01:27 AM | #116 |
Looks good Sean. hope it runs good too
05-04-2012, 05:02 PM | #117 |
Newbie Join Date: Apr 2012 Location: Duluth
| Re: My new FOFF build Looks great
05-04-2012, 05:06 PM | #118 |
Nice rig
05-26-2012, 07:54 AM | #119 |
Newbie Join Date: Feb 2012 Location: Ridgewood
Is it better to have long or short travel shocks?
05-26-2012, 08:28 AM | #120 |
My new FOFF build - Similar Threads | ||||
where the Foff am I gonna foff build | ctrwannabe | Formula Offroad | 8 | 11-30-2012 07:37 PM |
brianw's - I don't know what it's going to be - FOFF build | brianw | Formula Offroad | 50 | 03-15-2012 02:56 PM |
Need help finding foff build | phxguy | Formula Offroad | 10 | 11-08-2011 01:19 PM |
I want to build a FOFF ( Ax-10 ) | West Cork Basher | Formula Offroad | 4 | 10-14-2011 03:09 PM |
Going to build foff need help | Motomeyhem | Formula Offroad | 2 | 08-03-2011 12:39 AM |
