07-19-2014, 12:52 PM | #1 |
Rock Stacker Join Date: Jul 2014 Location: Abu Dhabi, UAE
| Axial Yeti - Formula Offroad Upgrades Build
. As I live in the desert and lots of sand dunes to climb and jump i come to ask some questions. Can you experienced FOFF gurus throw some suggestions of mods or upgrades to the Axial Yeti that should be considered to get more enjoyment from Formula Offroading? . |
07-20-2014, 08:06 AM | #2 |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| Re: Axial Yeti - Formula Offroad Upgrades Build
Paddles, gearing and MORE POWER !!!!!! The first time I saw the Yeti all I could think of was FOFF !
07-20-2014, 08:22 AM | #3 |
Now we are talking' Ok Paddles for sure,,,, on order below Rear: Pro Line Sling Shot 2.2 Front: Pro Line Sand Paw 2.2 So for gearing on the Yeti,,, what ratio gets NASA launch capabilities with some 3S packs ? Then the juicy part,,, yum yum,,,, more power,,, motor and anything else to go with a new motor,,,, recommendations to a good fit for the Yeti ? . |
07-20-2014, 11:08 AM | #4 | |
RCC Addict Join Date: Jun 2007 Location: Finland
| Re: Axial Yeti - Formula Offroad Upgrades Build Quote:
07-20-2014, 11:59 AM | #5 |
Some Castle Power eh ? .... How about a Castle Mamba Max Pro - ESC ??? . .... and what kV motor would be perfect for FOFF, compatible with the Yeti and can take the hot climate and sand environment here in the United Arab Emirates desert.... ? . I want this Yeti to fly off the tops of dune crests ! Last edited by SilicaStorm; 07-20-2014 at 12:14 PM. |
07-20-2014, 12:19 PM | #6 | |
07-20-2014, 12:23 PM | #7 |
Thanks Zarizi,, Yes definitely when the outside ambient temps are +35,,, its too damn hot for me to be out there too,,,, But I would hope early mornings when temps Sept - April are around 28 - 33 degrees celcius should be the same as the guys running in southern USA. will do some research on the 5700kV Castle and Mamba Max Pro,,, thanks again,,,, . |
08-09-2014, 11:16 AM | #8 |
. Anyone building a Yeti for FOFF ? . |
08-09-2014, 04:12 PM | #9 |
If I were to build an FOFF and still have a fun rig to bash around with a simple tire switch of course run sensored brushless. MMP + Tekin Pro4 HD 3500kv + probably a quick Savox servo coupled with a CC BEC. 32p gearing of course. Sensored brushless on 3s is ballistic. Just with the MMP was a tad smaller but the fan does a great job keeping the ESC cool. |
08-09-2014, 06:01 PM | #10 | ||
I am as you can see a noob to RCC and still trying to get my head around gearing. You mentioned 32p gearing. Quote:
Harley Sticky above has detail but looking at it I can not determine which ratio is applicable for FOFf and high speed dune bashing ? I have no intention of rock crawling as there are no rocks in the Arabian desert . Since I am waiting for my pre-order i would like to have all parts ordered and waiting to install on the Yeti arrival which looks like another month. (but thats not the topic) . Last edited by SilicaStorm; 08-09-2014 at 06:09 PM. | ||
08-10-2014, 07:34 AM | #11 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
It's not that easy to pick gear ratios, especially on a new vehicle. Trial and error will need to be applied. Your idea of perfect will be different then my idea of perfect, on anything. Heres my 2cents. If your not gunna go slow, there is no need for sensored motors, it will save you a little money that you can put towards a good range of gears. 32p is definitely the way to go. When I when this way I got a 54,56, and 58t spur gear from Robinson Racing. I also got a range of pinions. Look into 12 through 18t , all even tooth count pinions. No need to buy every pinion, just every other. This should give a cool to hot setup Another piece of info, keep a close eye on temps. If you don't already have an inferred temp gun then get one before you start running. If you get too hot too fast, you can burn up the motor and esc rather quickly. I've been there done that. Good luck on you build. |
08-10-2014, 07:37 AM | #12 |
Oh and if possible, get the 2.8" tires paddle tires. They will took much better then the 2.2". Look around this section for some pic's and see if you agree. |
08-10-2014, 10:56 AM | #13 | |
Some good advice there,,, I have purchased online a laser temp gun,,, what temps should i be weary of regarding the motor? Here in the Arabian desert during certain months can be an issue, but running early mornings can avoid high temps;but actually monitoring the motor temps i will be critical as you have pointed out ! cheers, Last edited by SilicaStorm; 08-10-2014 at 11:52 AM. | |
08-11-2014, 11:49 PM | #14 |
Pebble Pounder Join Date: Feb 2013 Location: Fresno
TTIUWP |
08-12-2014, 03:25 PM | #15 | |
Good luck. Last edited by stelerzman; 08-13-2014 at 03:33 PM. | |
08-19-2014, 04:07 PM | #16 |
I found little help from Harleys threads. 5700 kv for a rig slated for a super hot climate. If mine I'd probly fit a sensor ed 2650 kv motor in it and run a RX8 esc esc along with some 6s 1800-2200 batteries. Youl get about 15 minutes run time and be running efficient and cool probly close to out side air temp. I would invest in a good temp gun. I'd tune gearing so motor temp is running 10 degree over outside temp DrI ing style greatly influenced heat generated. What works for Harley is nor going to work for everyone. I come frome rc helis and planed where the pilot build and tunes each aircraft not to a sticky on website. Harleys guides are guides they are starting points. You may need to do no tuning from this starting point or you may need to tune from it a lot Last edited by evan03; 08-19-2014 at 04:10 PM. |
10-24-2014, 06:55 PM | #17 |
Newbie Join Date: Jul 2014 Location: Australia
From experience I can tell you that if you're gonna run 6S in a hot climate, don't run more than 2000kv with a long 550 sized motor (same as stock motor size). Due to the IMMENSE start up current required, 5,700kv is for 2S only. Castle and Tekin both advise its a bad idea ,running higher voltage at such high kv as you'll fry your electrics with high load running. The amount of esc's and motors ive killed running 4,000kv+ on 3S is testament to that, and I run everything from beaches, to grass, to gravel. If you want off-tap power then I suggest a PRO4-HD Tekin thats around 2000kv on 6S, or run a motor around 2600kv on 4S for longer run times. Tune to make use of the torque. As for gearing, just buy a bunch of different sized pinions that are larger than stock, and a a Robinson racing Steel spur gear that's a size smaller than stock, as with high power you're gonna need the stronger spur. Then tune it so motor temps don't exceed 170deg F. As long as the driveline holds up and has been modified to handle the power, it'll fly with the above setup. Last edited by BCK; 10-24-2014 at 07:00 PM. |
Axial Yeti - Formula Offroad Upgrades Build - Similar Threads | ||||
Brandon's Formula Offroad Build | Brandon | Formula Offroad | 95 | 02-14-2013 04:48 PM |
axial ax10 formula offroad truck | yel98vwgti | 1.9 Scale Rigs | 3 | 10-06-2010 11:54 AM |
Durga or Dark Impact for a Formula Offroad build(paddle tires) on 3-4s BL??? | TheHeadHunter | Formula Offroad | 2 | 05-15-2009 07:42 AM |
formula offroad build | rash_powder | Formula Offroad | 110 | 08-30-2008 08:05 AM |
