01-23-2014, 07:03 AM | #21 |
Pebble Pounder Join Date: Feb 2011 Location: Cookeville
| Re: Chiefs Sawback Build - Spring-Under Susp
Here's an update y'all. I've got a flat belly now, and all my electronics are mounted. I'll solder my deans plug on the esc tonight and its ready to roll. The big news is I mounted new shoes on it. My buddy @ the LHS hooked me up with a set of 1.9 Mad Beasts!! They're sticky and soft. Here are the pics. |
01-23-2014, 07:05 AM | #22 |
| Re: Chiefs Sawback Build - Spring-Under Susp |
01-23-2014, 07:14 AM | #23 |
RCC Addict Join Date: Feb 2012 Location: Ca.
I really didn't realize how low your truck sat until I saw your last set of photo's. I now see your front fenders are missing and that you had to cut the body for the rear shock hoops, wow. Looking forward to your first test run report.
01-23-2014, 09:09 AM | #24 |
01-23-2014, 09:44 AM | #25 |
That is low. Mine measures 2.25" under the skid with the Proline TSL SX tires. |
01-23-2014, 10:03 AM | #26 |
Thats a great looking rig. I looked at the TSL xl's, but decided to try the mad beast out. The TSL's have always been my go to tire, in 1.9 or 2.2. I want to add an axe and shovel to the side, but also add some scale goodies in the back. I want a mix of military looks with scale mixed in, with better performance.
01-23-2014, 10:06 AM | #27 |
Thanks Chief. Yours should work very well with the low cog. |
01-23-2014, 12:50 PM | #28 |
Newbie Join Date: Apr 2012 Location: Oregon
Looks great! Question about the under spring setup. Obviously it gives lower COG but does it give you more articulation? I see you aren't running any shocks with the under spring setup. Looking forward to seeing how it performs. I've got all Axial trucks (Wraith and SCX10) but was looking to build my first spring suspension rig and have read a lot of great things about the Sawback. Thanks! Last edited by gforce; 01-23-2014 at 01:04 PM. Reason: add information |
01-23-2014, 02:18 PM | #29 |
Thanks gForce and raceeng. I don't believe SUA (spring-under) allows more articulation. Usually, atleast in 1:1, SOA (spring-over axle) allows more articulation because you can use a flat leaf-spring, allowing both compression and droop. With SUA, the leafs tend to have more of an arch, limiting some of the articulation. The Sawback flexes well running spring under because the leafs are pretty much flat at ride height. I am only running the one long leaf, with none of the helpers. I will be adding shocks tonight, but they are there just to keep the suspension from bouncing. Hope this helps, ask anything you want buddy. |
01-24-2014, 09:50 AM | #30 |
So Chief, how did it perform last night? Inquiring minds need to know.
01-24-2014, 10:49 AM | #31 |
Well, apart from the steering being reversed, it did great. I wheeled it about 5 mins outside (temps were about 7 deg). Tires gripped awesomely, rig flexed very well, and it was extremely stable. I plan on going to my usual crawling spot tomorrow and seeing how it does. I'll have pics of the run posted tomorrow afternoon for all inquiring minds! LOL
01-24-2014, 10:52 AM | #32 | |
| Re: Chiefs Sawback Build - Spring-Under Susp Quote:
01-26-2014, 08:00 PM | #33 |
The rig performed awesome on its maiden voyage. The spring-under setup is super stable, whether climbing, descending, or side-hilling. Having the flat-belly and taller tires made up for the low-stance. I ran every line that I've always ran, and climbed up everything. I was truely impressed with how well this thing crawls. Here are some pics I took, and a little video I recorded while driving. It's not the best, but it shows how stable the rig is. Enjoy! It walked right up this rock notch. I'll get videos of it next time. |
01-26-2014, 08:04 PM | #34 |
01-26-2014, 08:11 PM | #35 |
Great news Chief, I've been waiting to hear. |
01-26-2014, 08:30 PM | #36 |
LOL, thanks buddy. Unfortunately, I was alone, so no one to take videos and pics of the good stuff. I want to show how well this rig sticks to rocks and just climbs up pretty much anything I point it at. I'm going to work on trimming the u-bolts, and pushing the front bumper closer to the body. I'm also looking at stretching the w.b. in the front just a tad, to help with the approach angle. I'll keep this thread updated as I go. |
01-26-2014, 08:34 PM | #37 |
You can put your bumper on top of the frame rails to help with the approach angle. One of the guys here did that and it looks good.
01-27-2014, 07:08 AM | #38 |
The problem I see with the bumper is how far past the shackles it sticks out. I can move it back about an 1/8th, maybe a little more. Plus, with the w.b. stretch in the front, I should be good.
01-27-2014, 09:29 AM | #39 |
Quarry Creeper Join Date: Jan 2012 Location: Newmarket, Canada
01-27-2014, 11:58 AM | #40 |
Nice rig JP. What color is that? My old CJ7 (1:1) had the front cut like this, and the day I have my CJ2A, it'll be cut the same way. I feel as if the bumper just sits too far out ahead of the body. I want to trim the frame back as much as possible, and remount the bumper in the stock location. I'll start messing with it tonight and get some pics up. |
Chiefs Sawback Build - Spring-Under Susp - Similar Threads | ||||
Crawlorado719 GMade Sawback Build | Crawlorado719 | G-Made Sawback | 162 | 04-01-2014 10:08 PM |
twilights sawback build, back to scalers | twilight | G-Made Sawback | 10 | 01-24-2014 05:30 PM |
Wild Willy On A Sawback [Sawback Solo Run] | ifulg | G-Made Sawback | 1 | 12-24-2013 08:06 PM |
Chiefs JK Buggy | Chief | 2.2 Scale Rigs | 9 | 03-15-2012 06:58 AM |
