01-19-2014, 12:58 PM | #1 |
Quarry Creeper Join Date: Oct 2013 Location: Nanaimo
| The first real weak link!
Well today i was doing some preventative maintenance and noticed i had quit a bit of rotational play in each individual tire. So i decided to yank my diffs out and found that the wear in the axle slots on the locker are almost completely worn out and are on the verge of stripping out. So i guess the suspicious cast diff gears really are as weak as they look. Also where the ring and pinion teeth make contact they are worn and mushroomed s bit. On the plus side the axles show no wear at all. Ive had my truck for about a month but run it every second or third day. Cant wait till someone comes out with hardened steel ring and pinion. |
01-19-2014, 01:04 PM | #2 |
Quarry Creeper Join Date: Jan 2012 Location: Newmarket, Canada
| Re: The first real weak link!
Ahh, I noticed some locker play in my rear axle as well. might have to take a look!
01-19-2014, 02:52 PM | #3 |
It happens with gmade axles when running with moderate to lots of power. I would also check the inner axle bearings and holders to see if they are ok. If the inner bearings are failing, it causes wobble and accelerates the wear on the locker and gears. Good luck with waiting for hardened steel parts. I have been waiting a long time for my R1 to have a vendor make HD gears. |
01-19-2014, 03:11 PM | #4 |
Pebble Pounder Join Date: Sep 2012 Location: Ljubljana, Slovenia
the sawback seems to be quite popular , so the chances are higher for HD gears i guess
01-19-2014, 03:38 PM | #5 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Re: The first real weak link! |
01-19-2014, 05:28 PM | #6 |
RCC Addict Join Date: Feb 2012 Location: Ca.
Thanks for the heads up
01-19-2014, 11:41 PM | #7 | |
Are the r1 ring and pinions the same a as the sawback? If so then i can actually order some to have as spares. At least its only a 10 min trail fix IF i can find some fir my trail med kit. | |
01-19-2014, 11:50 PM | #8 |
It shows different part numbers and the sawback set is 32/14 and r1 set is 32/17 so if you have time to check if the rings are the same and the 17t pinion works in the sawback housing. If so we have the makings of an overdrive gearset for the sawback
01-20-2014, 10:44 AM | #9 |
Rock Crawler Join Date: Jan 2007 Location: monson
Reaxion911, I am currently building my new kit and will consider your experience with the wear. maybe you could drill and tap a hole into the flat side of the spool and set screw the axles in? |
01-21-2014, 08:18 AM | #10 |
Newbie Join Date: Feb 2011 Location: Vancouver Island
I'm thinking the Titan 12 turn and swamper XL's prematurely wore your diffs out too , for what this rig is I think it's great but it's no competition scale crawler
01-21-2014, 08:34 AM | #11 |
| Re: The first real weak link! Actually... it could easily be a competitive scaler. Mine's mucked a few lines my scx10's couldn't, and a friend of mine nearly crapped his pants when I was doing all the lines with my Sawback that he was doing with his $1k+ Wraith. Stronger gears would be nothing but a plus though, sometimes you do need a little extra wheelspeed (just not 3s on a racer/basher motor )
01-21-2014, 01:08 PM | #12 |
Ive run a mamba max pro with 17.5 novak on my axial scx10 with weighted 2.2s for the last 8 months and the lockers are over 3 years old and dont show nearly this much wear. My sawback is extremely capable and would definatly run any line my axial would (now with the chassis setup im running). Im just saying that the steel used to cast the diff gears is of poor quality and far too soft. An option part of hardened steel gears for those of us who bought the truck to run and not look at on the shelf is needed. And with recommended suspension settings for up to 20 turn motors i would expect the truck not to wear out in a month. Just sayin
01-21-2014, 01:11 PM | #13 |
Quarry Creeper Join Date: Jun 2011 Location: Walnut Grove
i would deff get a set of steel gears if they were available regardless of the condition of my stock stuff
01-21-2014, 01:12 PM | #14 |
Not saying that a titan is not overkill and did not contribute to the worn locker. i am now running a 45turn at least until parts are available
01-21-2014, 06:33 PM | #15 |
Hey man, sorry I wasn't trying to bash you, I was just trying to say your previous set up May have caused some premature wear, but there's no way that should have happened after only a month of use. Hopefully they come out with some hardened gears soon |
01-21-2014, 09:50 PM | #16 | |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
| Re: The first real weak link! Quote:
I'd be very surprised if someone did not come out with steel gears, eventually. Of course that takes time and there has to be a pretty high demand, so we'll see if enough people buy this rig and drive it hard enough to justify the heavy duty stuff. (My son just said, "heheh....heavy duty." In the mean time, try to drive it like a crawler and hope someone parts out a new kit on Ebay soon so you can snag another set of the stock gears until steel is available. duty | |
01-21-2014, 11:01 PM | #17 |
My eyes are open! The last two runs i have been backpacking my axial in case it lets go! Id much rather be backpacking a gearset to swap out on the trail but until that time ill be avoiding bindy bindy. Lol usually end up at least an hour from the car so i will do everything possible to avoid sulking out with a broken truck.
01-21-2014, 11:05 PM | #18 |
Im still interested in knowing if the r1 gearset will work. Anyone? Beuller?!
The first real weak link! - Similar Threads | ||||
Weak lower link | bigjoe623 | Redcat Crawlers | 6 | 03-28-2012 06:30 PM |
Kits Weak Link | snohiker | Axial Wraith | 9 | 11-17-2011 06:29 PM |
weak link | NickGood | Newbie General | 12 | 02-01-2011 10:22 AM |
Found a weak link | Lizard XJ | Nebraska | 1 | 06-15-2008 05:58 PM |
Going brushless, need a weak link | teamtom | Newbie General | 5 | 10-18-2006 08:39 PM |
