05-04-2014, 10:24 AM | #41 |
Quarry Creeper Join Date: Sep 2012 Location: Emmaus, Pa
| Re: Shape_Shifter Builds a Sawback |
05-05-2014, 09:15 AM | #42 |
Rock Crawler Join Date: Mar 2009 Location: Parker, CO
I mounted a 2 axis gimbal with a Gopro rig to my bumper. It works super sweet but does make the truck top heavy, even with all the lead in my wheels LOL. I used it at the Bayside Scale Adventure event yesterday. The event was awesome and I will post more about it somewhere else. I took gobs of video from my Sawback and I also got some aerial footage from a quadcopter. All of the video is going to the organizer of the event but here are a few still images. Notice that no matter how far the truck tips, the camera is always perfectly level. Gimbals are sweet! (The Sawback can go wherever an SCX can go, BTW) - Here is how i is mounted and short test video in front of my house. Since the camera is always level to earth, the more of the stickshifter you see - the steeper the climb. Inversely, the less of the windshield you see - the steeper the drop off. https://www.youtube.com/watch?v=CIWS...HPHAJyR1LkTzTg |
05-05-2014, 06:21 PM | #43 |
Quarry Creeper Join Date: Mar 2010 Location: Massachusetts
That's so awesome, I've mounted mine in the bed but you definately don't get the feeling of the angles your going up or down that the gimbal'd setup provides. Nice work!
05-05-2014, 06:40 PM | #44 | |
| Re: Shape_Shifter Builds a Sawback Quote:
Here is a short video segment from the adventure. I will have a few more clips that show the camera getting bonked by low bridges, scraped on rocks, and rolled in the dirt as soon as I can get them posted. | |
05-05-2014, 08:19 PM | #45 |
Pebble Pounder Join Date: Nov 2006 Location: Tennessee
That is pretty dang cool! Gives you a really neat point of view from inside. Sent from my Phoneamathingy |
05-06-2014, 10:38 PM | #46 |
Here's another segment. The camera and gimbal get bashed on this one. |
05-10-2014, 11:40 PM | #47 |
How to wrap your axles instructional video. |
05-11-2014, 04:49 AM | #48 |
Videos are great! Your driver kind of freaks me out though, looks like I robot a little lol
05-12-2014, 12:58 PM | #49 |
05-12-2014, 03:04 PM | #50 |
Yup
05-18-2014, 06:03 PM | #51 |
Made some sliders out of solid bar stock today. |
05-19-2014, 09:13 AM | #52 |
I'm thinking of making plastic sliders. Did you notice any performance improvement after the addition of the sliders? Sent from my SCH-I535 using Tapatalk |
05-19-2014, 09:55 AM | #53 |
| Re: Shape_Shifter Builds a Sawback I made these as low profile as possible but they actually reduce performance. Sliders reduce ground clearance and the outriggers get caught on stuff. I am going to add some flat tub like plates between the outriggers to keep rocks from getting caught between them.
05-19-2014, 12:28 PM | #54 | |
I do prefer plastic sliders over metal. Plastic seems to slide more easily over rocks than metal. | |
05-19-2014, 01:57 PM | #55 | |
As far as plastic sliding better than metal, I'm not sure I agree witht that. IMO, plastic can "catch" and gouge which means friction. Brass is fairly hard and will slide before it gouges. Nothing wrong with plastic ones though. You could put the SCX sliders on there.... | |
05-27-2014, 10:57 PM | #56 |
For people that think a Sawback cant keep up with an SCX10, watch my Sawback and a bunch of SCX10s take on the same obstacles in this video. It's all about choosing the right line... Its a long video and worth watching but my Sawback is featured at: 0:33 (1st gate) 3:44 (gets winched DOWN a sharp turn) 8:40 - 9:30 (I follow the truck that ultimately wins this event over a gate) 12:00 (I get through a tough crevasse and the SCX behind me dorks the gate) This is a fun and capable truck! |
06-07-2014, 10:00 PM | #57 |
I finally got around to making a functional anti axle wrap traction bar. This is the design that some full size jeeps and leaf sprung trucks use. I just cut up a block of aluminum and drilled and tapped two 3mm holes on one end and a 4mm hole in the other end to take a Traxxas Revo tie rod. I connected at the chassis with some spare Gmade frame spacers (the thin figure-8 shaped ones) and sandwiched them around the Traxxas ball end. No perfect but extremely functional. A much simpler way to fab this would have been to not use the two ball-ends at the axle and, instead, just make the aluminum block be as long as the ball-ends are now, then just drill a hole straight down through the block. Then just put the long vertical axle screw thew the block then the axle like it is now. Next time, that's what I'll do. |
06-09-2014, 04:58 PM | #58 |
Nice work. They don't bind the suspension at all? It seems like they would cause some bind.
06-09-2014, 05:43 PM | #59 |
Shape_Shifter Builds a Sawback - Similar Threads | ||||
Sawback | hotwheels000 | G-Made Sawback | 19 | 05-09-2015 05:32 PM |
how does every one like there sawback | digger48 | G-Made Sawback | 38 | 05-12-2014 06:05 PM |
Best-Looking Sawback | DWJL511 | Videos! | 3 | 01-20-2014 09:49 PM |
Wild Willy On A Sawback [Sawback Solo Run] | ifulg | G-Made Sawback | 1 | 12-24-2013 08:06 PM |
looking for prerunner builds. post builds here | wcdfmt510 | General Scale Talk | 19 | 06-27-2013 09:48 PM |
