Thread: Back wheel steering
Old 02-17-2012, 12:17 PM   #1
Default Back wheel steering
CAN SOMEONE EXPLAIN TO ME HOW TO SETUP REAR WHEEL STEERING
axialdude1 is offline   Reply With Quote
Old 02-17-2012, 12:31 PM   #2
Proverbial threadkiller
Trubble's Avatar
On what truck?
Which model?
What radio you got?
What issues are you having?
Trubble is offline   Reply With Quote
Old 02-17-2012, 03:03 PM   #3
Default Re: Back wheel steering
Well im running a scx10 my radio is a 2.4 ghz. My prob you asking well i just wanted to build a southern buggy and just wanted a cool upgrade. So really there is no problem.
Old 02-17-2012, 03:34 PM   #4
What Trubble was asking is what radio do you have it must be a 3 ch I believe and you make the rear look just like the front. So remove the rear lock outs and install C's and Knuckles get dog bones and outters or get some CVD's install servo plate on top of the axle and bolt up a servo.
Hook up your 3rd channel up to the servo set your end points and go.
O and I forgot make steering linkage.
jacobflyin is offline   Reply With Quote
Old 02-17-2012, 03:36 PM   #5
Yeah there is, not enough info on what electronics your running. A 2.4ghz is to general of an answer. What make/model is the radio?, what servo's you plan on useing?
transambill is offline   Reply With Quote
Old 02-17-2012, 07:06 PM   #6
do you stick with a rear axle or do you put a front axle on it
Old 02-17-2012, 07:11 PM   #7
Jacob awnserd that question above.
ctrwannabe is offline   Reply With Quote
Back wheel steering - Similar Threads
low power on left back wheel.. jonnylocktong Losi Mini-Rock Crawler 5 05-15-2010 11:31 AM
1.9 Wheel Back Spacing . INFERNAL 1.9 Scale Rigs 2 04-19-2010 09:11 PM
independant throttle/steering for back Bknight General Crawlers 6 05-01-2006 06:51 PM
steering at the back of the axle screwloose General Crawlers 7 12-05-2004 04:54 AM
