09-21-2013, 09:33 PM | #121 |
Rock Stacker Join Date: Nov 2012 Location: South East Michigan
| Re: Carter Fab & Machine Custom Scaler Axle Housings
All I have to say is that with these axles you build the rig around them. They look great, can't wait to see where you go next.
10-01-2013, 03:15 PM | #122 |
Metal shaper Join Date: Dec 2008 Location: Hog Eye, Texas
Customer wanted a setup like we built for Showcase but w/a suck down winch to hide the servo. Showcase's setup With winch We started with a VP housing as usual then machined a new long side steel tube. Used a Dinky Rc "s" link again and proceeded with chromoly tube to build the winch mount and skid |
10-02-2013, 11:23 AM | #123 |
Rock Stacker Join Date: Apr 2013 Location: Sacramento
What size chromoly tubing do you use? And where do you get it?
10-02-2013, 03:29 PM | #124 |
10-02-2013, 03:30 PM | #125 |
Finished product. |
10-02-2013, 03:34 PM | #126 | |
10-21-2013, 12:51 PM | #127 |
Xr10 width Ar60 w/shaved and plated diff. |
10-22-2013, 12:38 PM | #128 |
Rowdy wanted to go further with the shave mod. Was able to get another .100" out of the diff. Any further will compromise gear integrity. These now have .200" more clearance than a stock housing before plating. Removed .180" off the OD of the under drive ring gear. I don't have any countersunk 2-56 hardware for the skid but it's ready to accept them when they arrive at their destination. |
10-22-2013, 01:44 PM | #129 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Clay, you are awesome at what you do bro!
10-30-2013, 08:19 PM | #130 |
Rock Crawler Join Date: Jun 2013 Location: Cincinnati
Just curious, do you do anything that is more narrow than a stock scx10 axle?
10-30-2013, 08:36 PM | #131 |
10-30-2013, 08:58 PM | #132 |
You have a PM sir!
10-30-2013, 09:10 PM | #133 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: Carter Fab & Machine Custom Scaler Axle Housings |
11-14-2013, 10:48 PM | #134 |
SCX width passenger side front drop and centered rear with solid tubes/no lockouts. Also has re machined upper VP truss and a VP pan hard mount. |
11-20-2013, 09:56 AM | #135 |
Wraith width, OCP. |
11-20-2013, 09:56 AM | #136 |
Pre paint centered diff Wraith width |
11-20-2013, 10:00 AM | #137 |
These two are for sale. This one is Wraith width hybrid(plastic center, aluminum VP tubes) This one is .750" wider than SCX and uses 2 short side XR shafts and is also a hybrid(plastic center, aluminum RC4wd tubes |
11-20-2013, 05:58 PM | #138 | |
Quarry Creeper Join Date: Mar 2009 Location: martinez
Xr shafts and what else for the bottom ones? With they use wraith knuckles and rear lock outs and what internals? Quote:
11-20-2013, 07:25 PM | #139 | |
| Re: Carter Fab & Machine Custom Scaler Axle Housings Quote:
Carter Fab & Machine » Custom Width Hybrid AR60 Axle Housing | |
11-20-2013, 08:31 PM | #140 |
| Re: Carter Fab & Machine Custom Scaler Axle Housings So this is basically the same width as a XR modded AX-10 axle? |
Carter Fab & Machine Custom Scaler Axle Housings - Similar Threads | ||||
Carter Fab & Machine T-Shirts | CarterFab | Vendors Miscellaneous | 4 | 01-19-2013 10:07 AM |
