12-06-2012, 04:42 PM | #21 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
| Re: How do I make my SCX less "jumpy"
Just some general thoughts: Get stick-on 1:1 wheel weights, and wrap your wheels with them. Put about 6 - 8 oz. on each front wheel and about 3 oz on each rear wheel. Mount your battery in the front of the truck, as low as possible. Use light or extra light springs on your shocks. If you do these three things, it'll help a lot. One other thing is a larger pinion, smaller spur gear, or a motor with more turns. You might be geared on the high side. All of this being said, if you're stuck and you give it a lot of throttle, it'll hop around no matter what. But these mods will help reduce the hopping. My class 3 rig weighs between 8 and 9 lbs, it has vented wheels and all of the above things I mentioned. But if the obsticle is bad enough, it'll hop until it gets traction. |
12-07-2012, 06:48 PM | #22 | |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Re: How do I make my SCX less "jumpy" Quote:
Do you have any weight in the wheels now? What is your suspension setup? Which springs? Can you max out the articulation by just lifting one tire or do you have to hold one down and lift? You may just have springs that are too stiff... | |
12-12-2012, 06:25 PM | #23 |
Newbie Join Date: Sep 2011 Location: montevideo
My scx10 honcho lurches with little to no throttle. Called axial they suggested for my purposes ( scale crawling) that I ditch the 27t stock motor and go to 55 turn. Less speed, more torque. Perhaps this is what you meant by jummpy. If not, sorry.
12-12-2012, 06:35 PM | #24 |
| Re: How do I make my SCX less "jumpy" Wonder if recalibrating the esc would help.
12-14-2012, 01:06 AM | #25 |
Pebble Pounder Join Date: Feb 2009 Location: here
body off pic's may help.
How do I make my SCX less "jumpy" - Similar Threads | ||||
Will the xr10 make a good "mini clod" monster truck? | rocresq | Axial XR10 | 3 | 11-25-2011 12:35 PM |
HRCC's #3 comp "Da Make-Up", august 31st.....kahalu'u pond | RydeFab | Hawaii | 25 | 09-16-2008 01:13 AM |
HRCC's #3 comp "Da Make-Up", august 31st.....kahalu'u pond | RydeFab | Competitions | 0 | 08-18-2008 03:27 AM |
