Thread: Gear lube
Old 06-07-2013, 05:55 PM   #1
Default Gear lube
Can anyone link me to buy a good gear lube? I rebuilt my axles and want to lube it
natskiboy is offline   Reply With Quote
Old 06-07-2013, 07:18 PM   #2
torchedcycle's Avatar
Default Re: Gear lube
http://www.rccrawler.com/forum/tools...ar-oil***.html
torchedcycle is offline   Reply With Quote
Old 06-07-2013, 07:21 PM   #3
Hey Natski
I've been using a marine grease...it's green, sticky as hell and waterproof. Comes in a 16 OZ tub and can be found at your local auto parts store..about $7 and I've been re-building my axels lately and this stuff is still on my gears ...can't say you'll find anything better for the price.
Postclanker is online now   Reply With Quote
Old 06-07-2013, 11:23 PM   #4
Generally you can use any grease that you would use on your every day vehicle. I personally use a grease called krazy grease. It's green and tacky as h**l also very good water grease.
Sent from my GT-I9100M using Tapatalk 4 Beta
sidehiller is offline   Reply With Quote
Old 06-08-2013, 01:03 AM   #5
Proverbial threadkiller
Trubble's Avatar
Wheelworks Black & Tacky
I use a product called SuperLube, have been since the '80s. Found out a local Ace Hardware carries it.
Trubble is offline   Reply With Quote
Old 06-08-2013, 02:20 AM   #6
I use marine grease in my diffs/trans. cheap as chips
liljohn_92 is offline   Reply With Quote
Old 06-08-2013, 02:28 AM   #7
red and tacky seems o hold up better than the normal auto grease. And because it stays in place better - less is more.
doublej is offline   Reply With Quote
Old 06-08-2013, 06:53 AM   #8
In the band for now.
try " speed grease", waterproof . 3 bucks for a tub of it and you dont have to coat the entire axle with it ( newbie thing ,they dont know ant better and it just makes a mess) . just cover the gears with it and your good to go and it lasts forever. use it in all my rigs for several years without issue.
lemonhead is offline   Reply With Quote
Old 06-08-2013, 11:34 AM   #9
If your axles/gears have plastic parts make sure to use a lube that is compatible with plastic. Petroleum based lubes can weaken plastic parts.
AutoCrawler is offline   Reply With Quote
Old 06-09-2013, 12:00 PM   #10
should you grease the outer bearings to protect it from water getting in the actual ball bearings inside, like on the rear lock outs, chubs and knuckles? or the bearings are pretty well sealed?
Lava Crawlah is offline   Reply With Quote
Gear lube - Similar Threads
1/8 buggy gear lube racerfred Non Crawler RC's 1 08-07-2010 01:06 PM
axle gear lube, what do you use? tombs Redcat Crawlers 2 04-14-2010 02:59 PM
gear lube gearstripper Newbie General 19 01-28-2010 01:20 PM
Gear Lube!!! JeeperoManiako General Crawlers 3 04-14-2006 12:32 AM
Gear Lube? PastryLikeDood General Crawlers 3 03-30-2005 06:25 PM
