Thread: Berg Mod 0.6 pinions
Old 07-10-2013, 11:47 AM   #1
Default Berg Mod 0.6 pinions (Check last post)
PLEASE SEE MY THE LAST POST
I contacted TCS Crawlers about the Berg Mod. 0.6 pinions, Enroute 11T Berg Gear 0.6M #EBG101 - The Crawlers Store LLC , but can't get a straight answer. Can anyone tell me if they are made of steel, aluminum, are plastic?
Forgot to ask..... 1/8" shaft size right?
Thanks in advance.
KC5H is offline   Reply With Quote
Old 07-10-2013, 11:50 AM   #2
Default Re: Berg Mod 0.6 pinions
you might get better results asking in this section RCCrawler Brand Specific Tech - EnRoute Berg at RCCrawler.com
rangercat23 is offline   Reply With Quote
Old 07-10-2013, 11:57 AM   #3
Per the enRoute website they are STEEL and yes they're for the 1/8" shaft. You could also go with the Robinson Racing gears...the 11t would be part number RRP1111
ittybitty is offline   Reply With Quote
Old 07-10-2013, 12:10 PM   #4
Thanks for the info guys. I found what i needed at RC4WD.
Old 07-10-2013, 12:18 PM   #5
Wanna get? Gotta want.
Erik D_lux's Avatar
Got a part number or a link? I didnt know RC4wd sold Berg pinions.
Erik D_lux is offline   Reply With Quote
Old 07-10-2013, 12:22 PM   #6
I'm fairly certain they don't...and if they did...you paid twice as much for a single pinion as you should have.
Old 07-10-2013, 06:04 PM   #7
Eric D_Lux and all who have responded.....
Man I am sorry. I screwed the pouch on this one. I was thinking metric 48 pitch and looked at standard 48 pitch instead.
Also just found out that even though the 0.6 mod is sometimes referred as the metric 48 pitch. The mod 0.6 is actually a 43.2 pitch and is not compatible with the metric 48 pitch gears.
Again folks I am sorry to have wasted your time.
Flame away guys. I deserve it.
GOAT
After you guys are finished chewing my ass. Could someone recommend a motor T rating (say 35t-45t-55t) to go along with an 11t mod 0.6 pinion. I want good wheel speed and torque for my RS10 axles. (All steel gears, aluminum spur plate, and hardened pins) I will mostly be trail bashing but with a lot of good crawling thrown in.
Old 07-12-2013, 07:05 AM   #8
No worries man...
As far as a motor for your rig...I really don't know anything about the RS10. The best thing to do would be to take a few minutes to browse a few of the builds in the RS10 section and see what people are using and get their reviews on them.
Old 07-12-2013, 10:30 AM   #9
The Robinson part number is no longer good.
I called them a couple months ago and they are no longer making the custom pinions.
I need a set of 11t 0.6 mod pinions for my AL Fighters. You can only use 11t because of how the motor mounts work, etc. No others will fit.
I called Robinson and a bunch of other places. No one has them.
I was told there are a couple mini-cars that use the 0.6mod/metric 48 pitch gears, and you can have the pinions bored out to 1/8" to fit the 540 sized motors.
I'll be on the lookout. If I find some, I'll post it up.
Doesn't look good though.
bigstu is offline   Reply With Quote
Old 07-12-2013, 11:01 AM   #10
No worries man...
Ya, As for as motors go it's my intent to run through the red cat section to see what I can come up with.
Old 07-12-2013, 11:13 AM   #11
My LHS has the NOVAK 11T/12T/13T 0.6 MOD set. So i get lucky...this time. However they are aluminum....not so lucky after all.
http://gshobby.com/content/novak-nov...-set-11t12t13t
You can get them at TCS Crawlers. Backorder Ok if they are out of stock.
http://www.tcscrawlers.com/enroute-1...6m-ebg101.html
Old 07-12-2013, 12:11 PM   #12
http://www.hobbyking.com/hobbyking/s...ehouse%5F.html
http://www.ebay.com/itm/261245134580?redirect=mobile
Calderwood is offline   Reply With Quote
Old 07-12-2013, 12:16 PM   #13
That's crazy...I just saw this part listed on several sites "IN STOCK" several days ago when this thread cranked up.
Old 07-12-2013, 03:47 PM   #14
Maybe there was so much demand they are cutting them again, but when I called Robinson directly, they said they were no longer making the metric 48 pitch 11t pinion.
Sounds like I need to do some more detective work. Too bad about the Novak sets KC5H, if they were steel that would be perfect.
Aluminum would work, but you would have to replace them regularly, along with the grease....
Berg Mod 0.6 pinions - Similar Threads
mod for small pinions schiarelli Tamiya Clod Buster 7 10-21-2006 05:24 PM
