01-12-2017, 07:20 AM | #1 |
Newbie Join Date: May 2016 Location: Gold Canyon
| Wraith problems help!
Last night I held my wraith in my left hand and spund the tires with my right hand. I noticed than when i spin them they stop for a split second. Why are they doing that? I did that do my bomber and they wheels didnt stop at all.
01-12-2017, 07:45 AM | #2 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
| Re: Wraith problems help!
If you spin the tires fast by hand the drag Brake will kick in even if your battery isn't connected and the truck is off. Probably what you are experiencing.
01-12-2017, 08:12 AM | #3 |
ok yes but i did that same thing to my bomber and the tires still didnt stop for a split second.
01-12-2017, 09:25 AM | #4 |
Newbie Join Date: Dec 2016 Location: Citrus Heights
I would move the motor and pinion away from the spur gear and try it. If you have a bad tooth in a diff or trans it could be causing a mesh problem momentary. or like mine a hd pinion and standard ring gear. Sent from my iPhone using Tapatalk Pro |
01-12-2017, 12:57 PM | #5 |
yeah i thought i needed to break it all down and look at it thanks for the reply!!!!!!
01-12-2017, 01:41 PM | #6 |
I was going to try to get mine together without pulling the diffs apart but after feeling the lack of smooth ness changed my mind. Would have had many problems. Trying to get things sorted out now during all the rain we have been getting. Sent from my iPhone using Tapatalk Pro |
01-12-2017, 08:01 PM | #7 |
sweet. Would changing all the trans gears to steel quiet down the noise??????
01-12-2017, 08:30 PM | #8 |
I would think changing to metal would make more noise going on my automotive experience. Not sure with RC Sent from my iPhone using Tapatalk Pro |
01-12-2017, 08:35 PM | #9 |
ok cuz i took it all apart the trans and i didnt see anything wrong except my SSD driveshaft screws were loose. Guess i need to put super glue or locktite on them!!
01-12-2017, 09:48 PM | #10 |
Blue locktite Sent from my iPhone using Tapatalk Pro |
01-13-2017, 01:23 PM | #11 |
yup ill ask my dad where it is. besides i am second guessing why i got them. The SSD steel driveshafts have too much play and they need a slip yoke elimator but this isn't 1:1 lol. THinking about buying the "famous" MIP's
01-13-2017, 03:50 PM | #12 |
Does yours use a set screw or a pin through the shafts? Mine had old style set screw gears with a pin style shaft and I had slop in mine. Sent from my iPhone using Tapatalk Pro |
01-14-2017, 07:45 PM | #13 |
it has a thread at the top then just looks like a pin the rest of the way down.
01-14-2017, 10:11 PM | #14 |
I wouldn't think there would be too much slop with that setup. Sent from my iPhone using Tapatalk Pro |
01-14-2017, 11:40 PM | #15 |
what do you mean slope. I was talking about the bad play in my SSD drivehshafts. I dont think they are long enough. They are too wobbly.
01-15-2017, 12:15 AM | #16 |
Yes, too much play - also known as "slop"..... Not anything to do with "slope". |
01-15-2017, 03:50 PM | #17 |
Oh ok sorry I misread it
01-18-2017, 09:17 AM | #18 |
i ran my wraith again the other day and i broke 3 times. First the front right tire came off, then the front tires wouldnt spin because the knuckles and steering came loose. then my shocks came loose. (too excited to go out and didnt did a pre run check). I broke the transmission down last night and i think that the problem was not only was the driveshafts loose but the outer and innter steel slipper plate screws were loose completely. I used a enormous amount of blue loctite(for how i drive) to hold the screws in place. Could this have been the problem of the tires not spinning at all????
Wraith problems help! - Similar Threads | ||||
Wraith Problems | 1fast67 | Axial Wraith | 22 | 01-02-2013 09:22 PM |
Wraith problems.. HELP!** | Trentenowns | Axial Wraith | 10 | 12-17-2012 09:42 PM |
problems with wraith please help | kauai808 | Axial Wraith | 5 | 09-10-2012 06:27 PM |
wraith problems.. | demonut | Axial Wraith | 9 | 05-21-2012 05:37 PM |
wraith problems | popeye123 | Axial Wraith | 13 | 01-13-2012 01:18 PM |
