12-19-2019, 02:35 PM | #61 |
| Re: Cantilever Suspension
I concur with Crawlinwithacat, great advice! Cantilevers are more sensitive to small changes too. |
12-19-2019, 02:48 PM | #62 |
| Re: Cantilever Suspension |
12-20-2019, 02:31 AM | #63 |
Newbie Join Date: Sep 2019 Location: UK
Thanks everyone. More options for tuning and adjustment was about what I thought. Hopefully I can get a chance to switch them over and do some testing over xmas, then I'll report back |
12-20-2019, 04:09 AM | #64 |
Look for touring and drift car shocks/springs to tune with.
12-20-2019, 08:57 AM | #65 |
Pebble Pounder Join Date: May 2017 Location: El Dorado Hills
10-05-2021, 02:19 PM | #66 |
Quarry Creeper Join Date: Dec 2009 Location: Central IL
I figured I'd bump this thread rather than making a new one. I'm in the planning stages of a 1.9 build and I think a canitlever rear suspension would work awesome for my application, which is a fairly lightweight scaler build. Likely around 5lbs once complete. 60-70mm shocks would likely be best. That has me looking at the Losi Mini T shocks and the Revo stuff. I don't know much about either shock but I do know that spring kits exist for the Mini T so there would be a decent chance of getting the spring rate dialed in. Rocker geometry and preload are also variables I have to work with, I just want to make sure I don't miss the mark off the bat. What's the go-to canti shock? Will the Losi's be too soft? Last edited by Bray D; 10-05-2021 at 02:27 PM. |
10-05-2021, 02:30 PM | #67 | |
| Re: Cantilever Suspension Quote:
10-05-2021, 02:54 PM | #68 | |
I pulled the servos, tires/wheels, axles, and trans from grabcad.com. Can't remember where I got my body model from, but I've had it for years and used it for building my 1:1. I stripped it down and scaled it for this 1.9 build. Frame rails (measured and modeled from existing parts), crossmembers, brackets, and links are all me. | |
10-07-2021, 01:21 PM | #69 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
ProLine makes some shorter shocks too. I have them on one of my builds (not cantilever) and they are very nice. They can be built 70 or 75 mm. https://www.amainhobbies.com/proline...axqsyqyzqxactz |
10-08-2021, 02:52 AM | #70 |
Quarry Creeper Join Date: Apr 2011 Location: Germany
Hi Bray-D, nice work on the 3d-modelling. I have used Vaterra canti-shocks from a Twinhammer. The HR / Dinky-RC seems a bit small for a SCX-10 based truck (in my opinion). I plan on using the Dinky-RC cantis on a Losi MRC based build. Keep the canti-ratio in mind: a ratio 2:1 will require a 2x higher spring rate and damping ability as well as 1/2 of the desired travel. So using standard shocks in a canti setup will require more tuning. Keep the good work going! |
10-08-2021, 11:49 AM | #71 |
Thanks for the replies guys. I thought I’d try to use what I have so I started modeling around the 100mm shocks. A frame extension off the back frees up the real estate, and I was able to stuff a 1:1 rocker in there so spring rate should be pretty similar to a traditional vertical shock setup. I tied it all together with a massive crossmember to stiffen it up. Luckily all of this fits under my body too. I’m currently 3D printing for a real world mock up. Full stuff > ride height > full droop |
10-09-2021, 09:09 PM | #72 |
I thought through how I wanted to do the physical pivot and landed on a fixed pin that the rocker rotates on. I had some 1/4” round stock handy that I had already machined into long 3mm spacers. Perfect for a pivot pin. That forced me to make my rocker pivot pretty big, but it feels robust. The 100mm shocks I had ‘on hand’ are actually coming in the AR45 axle kit and they’re not here yet. Here it is mocked up with an old Stampede shock body. It’s pretty close. Looks like I may have some issues at full droop due to the large rocker pivot. That interference will be worse once I have springs installed. Back to the drawing board (or internally limit the shocks, haha). |
10-17-2021, 06:38 PM | #73 |
Modified rocker seems to work fairly well, but I’m still struggling to get full travel out of the shock. Things are a bit ‘hitchy’ at full droop and the angles get crazy at full compression. I think a massive rocker would solve these issues, but I don’t want to give up the space yet. Either way, I have a functional prototype using existing parts right now so that’s a win. |
10-24-2021, 08:41 PM | #74 |
Last post then I’ll stop hijacking this thread. I printed some temporary electronics trays and got it running under its own power. My only gripe with the 1:1 rocker is that the lever arms get pretty short at the limits of travel. So much so that the friction in the pivot prevents it from settling down into ride height unless acted on by an outside force. I threw some pen springs in the shocks and that did the trick. I prefer to run internal springs anyways, so it’s a win all around. Ride height is dialed and the suspension is controlled. No immediate desire to move away from the stock 100mm shocks. I’m stoked to get my body and finish this build. |
02-09-2022, 09:36 AM | #75 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
Hey guys, working on the CODYBOY trx-6. I'm most definitely going to use a cantilever setup. I'm trying to use the shocks I have which are 90mm limited to 80mm. I have a demo set of 1:1 rockers my buddy printed for me. I'm noticing that I might need to go with a 2:1 rocker. I'm thinking the twin hammers rockers are going to be my best bet. From reading everything here I have a couple questions for you guys. What's your thoughts on running the full size shock? How are things holding up after use? Would you do it differently? Just trying not to do a bunch of trial and error due to low budget and little tinker time available. Thank you guys for any help and advice!!! Have a great day!!! |
02-10-2022, 07:51 PM | #76 |
If you use shorter shocks with stiffer springs and oil, I would imagine you can shorten the top of the triangle and solve some problems. Sent from my SM-N986U using Tapatalk |
Cantilever Suspension - Similar Threads | ||||
Cantilever Suspension | triggerhapy | Axial SCX10 II | 6 | 01-03-2017 04:03 AM |
E-revo cantilever suspension | derrick.johnston | 1.9 Scale Rigs | 2 | 06-19-2015 06:49 PM |
cantilever suspension | ROGI77 | Axial Wraith | 9 | 08-16-2014 11:14 AM |
rear cantilever suspension | mp3ranger | 1.9 Scale Rigs | 2 | 01-24-2011 03:56 PM |
cantilever suspension | Wicked_Jester | General Crawlers | 8 | 06-09-2007 01:52 AM |
