05-17-2018, 01:27 AM | #1 |
Quarry Creeper Join Date: May 2017 Location: Devon
| Stiffer springs or thicker oil
Hi, hoping I can get some advice guys. Recently bought a U4 racer (FTX Outlaw) to bash with my son's Wraith, it's a cheap rig but loads of potential. Now first tests show the front end really diving in hard corners and the shocks are very soft when depressing the front end. Back end is aok. The shocks themselves are probably cheap but there's no evidence of leakage at all and they're nice and smooth so I don't want to swap them out of I don't need to. So, my question is, should I get stiffer springs for the front or try a thicker oil first off? I'd prefer to try the spring route first as its way easier and less likely to have a negative impact if I rebuild incorrectly when doing the oil. Anyone have an opinion on this they'd care to share please? Thanks for looking. Sent from my Pixel using Tapatalk |
05-17-2018, 05:26 AM | #2 |
Rock Stacker Join Date: Aug 2017 Location: Lost in
| Re: Stiffer springs or thicker oil
I've been tweaking my suspension all week. I tried softer springs first come to find out I wanted to give light oil a try as well. If you have adjust-ability or a way to pre-load your springs, you can try that for free. I'd go with shock oil first (I went lower weight for my purpose), then if you can, adjust pre-load if you can to stiffen it more if you need to. If that doesn't work, I'm sure a combo of thicker oil and slight stiffer springs will work. I went for the opposite, soft springs and thin oil for a droopy setup; for a most scale simulation when trailing. |
05-17-2018, 08:57 AM | #3 |
springs support vehicle weight, shocks control the speed of weight transfer ~Carroll Shelby
05-17-2018, 11:27 AM | #4 |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
Based on Mr. Shelby’s quote above, I would say try thickening the oil first.
05-17-2018, 12:06 PM | #5 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
If you have multiple mounting points, moving them outboard will make them effectively stiffer (both spring and damping-wise).
05-17-2018, 01:01 PM | #6 |
| Re: Stiffer springs or thicker oil |
Stiffer springs or thicker oil - Similar Threads | ||||
I need stiffer springs for my XD 103mm shocks. | Stray | Axial RR10 Bomber | 2 | 03-26-2018 08:40 PM |
Stiffer springs needed. powerstrokes. | tinyT1m7 | Axial RR10 Bomber | 2 | 11-30-2016 06:10 PM |
Stiffer Springs | chino | Axial SCX-10 | 4 | 02-26-2015 11:00 AM |
Need Much Stiffer Springs for Trail Trekker Mod | rampa202 | Losi Micro-Rock Crawler | 11 | 04-28-2012 07:01 PM |
Stiffer high lift internal springs? | 1BadJeepBruiser | General Scale Talk | 15 | 04-11-2007 07:48 PM |
