08-16-2019, 08:12 AM | #21 |
| Re: New rig The flat spots get worked out of the tires & foams pretty quickly and I run good shocks so they don't bleed out while sitting.
08-16-2019, 08:32 AM | #22 | ||
| Re: New rig Quote:
im moving away from tire foams so i dont get flat spots anymore ive never noticed any differance in the shocks there cheapos so they dident have any performance to start with so aslong as im not distorting th3 lexan body i dont worry about how there stored | ||
08-16-2019, 09:56 AM | #23 | ||
Quarry Creeper Join Date: Mar 2019 Location: Low CG
| Re: New rig Quote:
08-16-2019, 10:01 AM | #24 |
| Re: New rig |
08-16-2019, 10:03 AM | #25 |
| Re: New rig |
08-16-2019, 10:13 AM | #26 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: New rig |
08-16-2019, 10:16 AM | #27 |
| Re: New rig |
08-16-2019, 10:19 AM | #28 |
| Re: New rig |
08-16-2019, 10:50 AM | #29 |
| Re: New rig |
08-16-2019, 11:42 AM | #30 | |
| Re: New rig Quote:
Sent from my LM-G710VM using Tapatalk | |
08-16-2019, 12:00 PM | #31 | |
| Re: New rig Quote:
08-16-2019, 12:01 PM | #32 | |
Newbie Join Date: Sep 2018
| Re: New rig Quote:
Here are the two rigs in question.... Sent from my iPhone using Tapatalk | |
08-16-2019, 12:06 PM | #33 | |
| Re: New rig Quote:
Both the 10.2 and TRX4 have a little bit of brass, AXE systems, strong servos, droop/semi droop shocks, aluminum panhard/ shock mounts and the 10.2 has overdrive gears in the front... 10.2 TRX4 TRX4 I’m building for my wife... Sent from my iPhone using Tapatalk | |
08-16-2019, 12:11 PM | #34 | |
| Re: New rig Quote:
08-16-2019, 12:27 PM | #35 | |
| Re: New rig Quote:
08-16-2019, 01:01 PM | #36 | |
| Re: New rig Quote:
Straight axles typically have less ground clearance but better steering angle and are more prone to torque twist due to higher gearing in the axles. The single biggest advantage to a trx4 is the unlocking rear differential. On climbs you can unlock the rear and it almost acts like a front dig to pivot the rig around. I use that constantly on my trx4 rigs. Conversely my class 2 has 60* steering angle so it doesn't need the rear to be open to make a sharp turn. | |
08-16-2019, 01:09 PM | #37 | |
| Re: New rig Quote:
08-16-2019, 01:36 PM | #38 |
| Re: New rig |
08-16-2019, 01:53 PM | #39 |
| Re: New rig Sure. Remove the locker and install the associated parts needed to make the remote lockers functional. I pulled the front switchable locker out of my class 3 in place of a locked up spool. Not a big deal but you'll need a radio to control the servo. |
08-16-2019, 02:39 PM | #40 |
| Re: New rig
No doubt about it, that 60* steering angle is pretty sweet. While not nearly as good, but still pretty good, is the improvement in steering gained on the X4 by using the OD/UD combination. My friend runs OD/UD and I prefer just UD. Side by side the improvement in turning radius is very clear - the combination is better and a certain improvement over stock. I just started to wonder while writing this, and thinking about the SSD portal delete kit, how much of an improvement in steering might be gained with the delete? Hmmm...
New rig - Similar Threads | ||||
Tonka tow rig 4wd conversion recovery rig and trailer | NissanNut | 2.2 Scale Rigs | 4 | 02-13-2015 02:36 PM |
