09-20-2022, 10:08 AM | #101 |
| Re: Coming soon Yikong crawler |
09-20-2022, 05:41 PM | #102 | |
Pebble Pounder Join Date: Feb 2022 Location: Batam Island, Indonesia
| Re: Coming soon Yikong crawler Quote:
What options are available? What do you use for inside your crawler tires ? I see on YouTube Hair bun ... Does that work better? I have no idea... Sent from my CPH1937 using Tapatalk Last edited by BP6666VR; 09-20-2022 at 07:10 PM. | |
09-20-2022, 08:49 PM | #103 | |
1. The tires are very soft & sticky apparently they are very good quality & super good grip 2. Cockpit is all seperate items as per picture 3. Grease i use car SYNTHETIC LITHIUM GREASE in the 2 axels & two speed gearbox, and some SINGER sewing oil 4. I changed to aluminum parts: pinion mount ( i stripped a tread) motor mount (it flexed), shock mounts, bumper bracing (it broke), steering ARM was plastic & i broke it 5. I broke the following items already: receiver & remote ( my fault ), 4WD servo 19 gram, steering servo ( maybe coz i did not set the endpoint at first ), lost a driveshaft ( my fault i should have checked), I stripped the C-knuckle plastic thread, i ordered many brass steering parts but kept the plastic axels, i will order 4mm helicoil to repair the damage thread just for fun 6. I just ordered 10 bearing of each size i could find in the manual, coz of rust & water in the future 7. i changed 90% of the black bolts to stainless steel bolts due to rust already It's a very capable RC, but how do I know, it's the only RC i have, hi hi Sent from my CPH1937 using Tapatalk Last edited by BP6666VR; 09-21-2022 at 02:21 AM. | |
09-22-2022, 12:58 AM | #104 | |
The sewing oil i put a few drops inside my fully filled axel / gear box with synthetic grease.... To make it a bit runnier or softer I bought my yk4082 on AliExpress website for $ 550 usd, this included shipping from china to Indonesia i installed a 32 Kg brushless steering servo, of a 100$ but i ordered 35 kg brushed servos that are super cheap ( also a aluminum bracket ) as the stock plastic flexed also, seems the 32 brushless is not strong enough... We will see It seems i keep on breaking this darn RC but i will get to the point that it's indistuctable hi hi I have to order everything online coz I live on a small island 3s / 6400 mah / 70c is a bit fast to crawl, so that is more for bashing, 2s / 9000 mah / 45c is more controleble for crawling Sent from my CPH1937 using Tapatalk Last edited by BP6666VR; 09-22-2022 at 01:03 AM. | |
09-22-2022, 07:27 AM | #105 |
ive always herd just a drop of oil is all that is needed on a bearing packing them with greese just creates drag on the bearing then the greese gets hard and crunchy then you toss them if you use oil to lube the bearing just reaply oil and your good |
09-23-2022, 01:56 AM | #106 | |
The created drag by grease will be gone within a few minutes, synthetic grease will never go hard I will try it out next time i open the RC up to install all the brass steering stuff Smile Sent from my CPH1937 using Tapatalk | |
09-23-2022, 04:51 AM | #107 |
There is a new YiKong € 618,69 YIKONG DF7 1/7 Rear Straight Bridge Desert Short Card Remote Control Electric Model Car 6S Brushless 4WD Adult Toy Car https://a.aliexpress.com/_mMCFgac Sent from my CPH1937 using Tapatalk |
09-23-2022, 06:10 AM | #108 | |
Yet again i am in need of information and help, about tires, i found something i like .... Original YK4082 sizes i have now on the RC Tires Size: 135/50mm Hex: 12 mm Shaft: M4 ( so 4.5 mm diameter? ) What rims i like as per below 1. The tires i like are only diameter 128 mm not 138 mm = is this bad or stupid or looks wrong? 2. The Hex is 12 mm so that is a fit 3. The inner rim / shaft hole is M4 , so the rim is center hole of 5 mm, is that a problem? I understand you can order "inserts or bushings" to make them fit ? How does that work ? Guys please give your opinion regarding the looks / sizes of the tires & rim below ... will it look good or bad ? Also look the last picture 138 * 62 tires, would it fit better? Does anybody installed 10 mm smaller tires as stock before? But there not as cool as the super swampers... Sent from my CPH1937 using Tapatalk Last edited by BP6666VR; 09-23-2022 at 07:25 AM. | |
09-23-2022, 08:40 AM | #109 | ||
about ten years ago i did the bearing packing trick too but after picking dry greese chunks out of my bearings i stoped the oiled bearings outlasted the greesed bearing and the battery lasted longer and ran smoother Last edited by ferp420; 09-23-2022 at 08:52 AM. | ||
09-23-2022, 04:54 PM | #110 | |
10-02-2022, 11:41 PM | #111 |
Gentleman, New brass steering & rear portals has arrived, beautiful quality Only the wheel weights there are 6 holes not drilled trough, I will install all items without the wheel weights, waiting for me to fix it, ha ha Do i have to paint or clear laquire spray paint them against weather? Sent from my CPH1937 using Tapatalk Last edited by BP6666VR; 10-02-2022 at 11:58 PM. |
10-03-2022, 07:58 AM | #112 |
that is alot of brass i would only install alittle at a time and test it there is a point were the extra weight will hurt your performance
10-03-2022, 06:26 PM | #113 | |
10-05-2022, 05:27 AM | #114 |
It was a lot of work, and the quality is amazing, perfect fit It seems it's better handling, high speed turns do not flip over the crawler, etc .... Sent from my CPH1937 using Tapatalk |
10-27-2022, 01:11 AM | #115 |
I just reread my above post, THE PICTURES ARE UPSIDE DOWN, hahahah Soryyyyyy Sent from my CPH1937 using Tapatalk |
10-27-2022, 02:53 PM | #116 |
Rock Stacker Join Date: Nov 2015 Location: Chilton County
10-27-2022, 09:15 PM | #117 |
10-27-2022, 11:05 PM | #118 |
10-28-2022, 02:57 AM | #119 |
01-13-2023, 04:55 PM | #120 |
I bought rims, foam & tires and installed them now no more water into my tires ( i hope ) I did NOT super glue them yet, 2.2 " tire 128 mm Rims 217 grams per piece YouTube video of fitting them, hi hi https://youtu.be/mOpgShWhdPo Sent from my CPH1937 using Tapatalk Last edited by BP6666VR; 01-30-2023 at 02:11 AM. |
Coming soon Yikong crawler - Similar Threads | ||||
crawler coming in from Arizona. | Catlover3178 | Alaska | 5 | 07-06-2013 05:25 PM |
New crawler course coming !! | BUGGYBOY | General Crawlers | 5 | 08-28-2009 10:50 PM |
Crawler Get Together Coming Up!!!!!!!!! | Dickie691986 | General Crawlers | 0 | 09-09-2008 06:18 PM |
future crawler coming soon | clodstall | Chit Chat | 92 | 09-16-2007 06:34 AM |
coming soon WK crawler. | hairba11 | Newbie General | 5 | 04-04-2007 05:26 PM |
