11-04-2020, 03:30 PM | #1 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Steering Tie Rod Question
Has anyone ever done something like this, use two tie rods? What are the pros and cons of it. Does it work better then having the drag link going from one wheel to the other? Sent from my LM-G710VM using Tapatalk Last edited by MaX-D; 11-04-2020 at 04:16 PM. |
11-04-2020, 03:35 PM | #2 |
| Re: Steering Drag Link Question
I don't see any drag links in that pic. I do see what looks to be two half length tie rods. With a center mounted servo on axle this setup makes perfect sense.
11-04-2020, 05:49 PM | #3 |
| Re: Steering Tie Rod Question
Are there any cons to running this type of setup? Would it make the steering more efficient? Sent from my LM-G710VM using Tapatalk |
11-04-2020, 06:18 PM | #4 |
Ive tried that years ago on a Wraith. Its hell on servos cause now each tire is trying to twist the horn seperately. It also results in ever so slightly different ackermann when at full lock from left to right. Wouldn't be be my first choice.
11-04-2020, 06:31 PM | #5 | |
| Re: Steering Tie Rod Question Quote:
Sent from my LM-G710VM using Tapatalk | |
11-12-2020, 06:34 AM | #6 |
Rock Crawler Join Date: Feb 2020 Location: Fort Leonard Wood
I have two Wraith 2.2s. One setup with the two piece link and the other just one. Both are 4link, with servo on axle. The set up with 2 steering links does not turn NEARLY as well. |
11-12-2020, 07:11 AM | #7 | |
Steering Tie Rod Question - Similar Threads | ||||
Wraith TEAMSTRC steering link/drag link???? | SwampDawg | 2.2 Scale Rigs | 1 | 07-02-2012 04:03 PM |
double drag link steering | shemesh | Axial AX-10 Scorpion | 33 | 05-26-2012 12:04 PM |
Steering link and drag link - what's the best bang for the buck? | Matthewboerner | Axial Wraith | 29 | 10-25-2011 10:25 AM |
Longer Steering Drag Link vs. Shorter Drag Link? | mann0mann | Newbie General | 7 | 05-08-2008 04:14 PM |
