05-25-2007, 02:12 PM | #61 |
| No matter how light the spring is it's made to pull up on the shock. Which is attached to the axle. Thus taking away from the full weight of axle and tire. It doesn't magically disappear the shock it taking away from it. This is going no where. I take what I got and go from there.
05-25-2007, 02:15 PM | #62 | |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Bingo... I limit the unloading with a zip tie from the chassis to the axle. Here is another curve ball for you. I only run springs in the front shocks. And yes, the only comparison I am making between the drrop and torsion is the ability to carry a tire. Now... I can increase the amount of articulation on my droop rig, while limiting unloading at the same time. With a torsion you could only increase flex with tire weight, and if you do that you will also increase the effect of unloading. Same with a stick chassis or a sprung rig. The droop also alows the axles to fall away from the chassis to gain traction in a high center situation. Another thing that is impossible with all of the other designs. I'm *trying* to answer your questions, let me know if it's working. | |
05-25-2007, 02:22 PM | #63 |
05-25-2007, 02:25 PM | #64 | |
My Hustler has MORE belly crearance than my stick did, while maintaining a much lower CG. | |
05-25-2007, 02:29 PM | #65 | |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
If the spring is pulling the extended tire upward that gives the opposite tire push. think of a tetor toter. That is what I'm getting out of it.? | |
05-25-2007, 02:36 PM | #66 | |
So by adding the Zip Tie/ Limiting strap to the axle you are just limiting the down travel. Correct. How does that help with unloading. It will still unload just not as far. Kind of answer my own question in a way I guess. On the high centering thing I guess I don't come across that as much running a Pimp Cane. But it does still happen, but not as much. All in all thats where driving comes into play. The way you approach that rock that might High Center you. On that curve ball. Why do you nor run springs in the rear? Do you just run thicker oil? | |
05-25-2007, 02:49 PM | #67 |
Here is a Side pic of a Hustler. And now one of a Stick. How does it have more ground Clearance? And the tube chassis as more weight up high then the stick does. The internal springs are what helps keep it tight to the axles. Which would help on a Tube chassis, but I would still think it would hurt on a Light alumn plate chsssis set up. |
05-25-2007, 02:49 PM | #68 | |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
R2J, this is what I meant by PRECISE ADJUSTSMENTS with droop. You could never get away with this setup with springs. If theres anyone who knows and understands droop, that would be Rockpiledriver, IMO, I'm pretty sure he's got it down. Your questions are good, I think everyone learns something new everyday, I learned a few things from you in re: to the advantage of running a sprig suspension chassis and the comparision to 1:1 suspension. This is a good discussion, I must say. ~John Last edited by KRAWLR4life; 05-25-2007 at 02:51 PM. | |
05-25-2007, 02:50 PM | #69 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
The added ground clearance is when the rig gets high centered, and the axles drop down...
05-25-2007, 02:53 PM | #70 |
| Ok...Thats where you get the ground clearance. Say your pulling up to a Rock Wall. Before you front tires try to climb up. Won't the suspension shorten and change your wheelbase. Seems a little funky to me. I have seen it happen with that set up.
05-25-2007, 02:57 PM | #71 |
Like Cole said, not all setups shorten much. And with mine when I do climb, the front does not extend out very much that I have noticed. you just need to dial in your oil and springs in the shocks, and link setup is important as well.
05-25-2007, 02:59 PM | #72 | |
below V Quote:
05-25-2007, 03:02 PM | #73 |
| Exactly, on the ground clearance. If the rig is unloading that much when approaching the wall it is not set-up correctly.
05-25-2007, 03:07 PM | #74 |
| You should try a Pimp Cane then. If you are looking for a good mix of Side hilling capability and Climbing ability. A Torsion design like the Pimp Cane is less likely to lift a tire then a Stick style set up on Climbing hills. Same goes on side hills. The Pimp Cane and the stick react way different. The only thing they really share are the fixed joints on the axles and ground clearance. The only thing with a Pimp Cane style set up is you need more driving time under your belt. I plan on buying a Hustler, just for the fact That I want everything that goes with Crawlers and I'm greedy like that. I'm working on a New 2.2 Stick type chassis with Double J that should be pretty cool. It kind of combines all three chassis into one. Stick, Tuber, 4 Shocks, Links all of it. Just something different it all.
05-25-2007, 03:08 PM | #75 |
This should almost be a sticky with all the info about every set up being thrown back and forth. I think we have almost nailed the pos and Neg of every set up there... |
05-25-2007, 03:13 PM | #76 | |
Stop piming the pimp Was this a sales pitch...J/k Actully, I'd be intrested in trying a 2.2 pimp, but not for comps, I like my comp rig... Your right, this is a very good suspesion thread, I know I learned alot. ~John | |
05-25-2007, 03:18 PM | #77 |
| It is definately nice to have a discussion like this without attitudes or loyalties to a certain product or vendor getting in the way. I have learned quite a bit from this myself. Mabey I do need to try a Pimp Cane. |
05-25-2007, 03:29 PM | #78 | |
~John | |
05-25-2007, 03:30 PM | #79 |
05-25-2007, 03:37 PM | #80 |
