Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: My review of RC4WD’s “OEM Steel 1.9/2.2 Stock Beadlock Wheels”
Old 12-01-2009, 12:24 PM   #1
Default My review of RC4WD’s “OEM Steel 1.9/2.2 Stock Beadlock Wheels”
Pros:
-Cheap ($39.99)
-White or Black coating is pretty scratch resistant
-Looks super scale
-Never had a issue with a tire coming un-beaded
Cons:
-Hex pin pocket is machined to deep, rim nut/rim may come loose.(Fix: make the pocket more shallow)
-Nuts and bolts are low quality, they easily strip
My overall rating is "4", out of 5 stars.
**My bigger question is, When are more "1.55" beadlocks going to be available?
justinart24 is offline   Reply With Quote
Old 12-01-2009, 11:54 PM   #2
I second the hardware being cheap. I'm now missing a nut from it stripping the bolt.
Wild Snapper is offline   Reply With Quote
Old 12-03-2009, 07:21 PM   #3
Are they 3 mm bolts, and nuts?
NWDave is offline   Reply With Quote
Old 12-03-2009, 11:49 PM   #4
M2.5 i think. At least the 1.55" ones
VanDongen is offline   Reply With Quote
Old 12-04-2009, 06:51 AM   #5
I need to replace a whole wheels worth of stripped hardware.
pardonmyn00b is offline   Reply With Quote
Old 12-04-2009, 09:04 AM   #6
I found a hobby shop here in Czech, and bought out their entire stock of 1.5mm and 2.5mm hardware. I have such a hard time finding it at home, and am missing a few screws/nuts on my set.
Another thing to note is that the stock SCX10 hubs do not fit these wheels.
On the plus side I bought unpainted wheels and they are already rusting for the desired look.
Drunk
DrunkDriver is offline   Reply With Quote
Old 12-04-2009, 01:01 PM   #7
I joined the Band!
Just email RC4WD about the cheap bolts/nuts and they will fix it for you. I bought a set and had 3 bad bolts/nuts and RC4WD fixed the problem for me. The Bolts had some of the white powder coating on them and when you tried to tighten the nut down over the powder coating it would strip the Bolt.
If your not contacting RC4WD about this then they will never know it's a problem and never fix it.
The white ones look great! They also come in 1.9's
grimgard is offline   Reply With Quote
Old 12-04-2009, 03:29 PM   #8
They look good in 1.55 on a mini scaler too
Coop980 is offline   Reply With Quote
Old 12-04-2009, 07:37 PM   #9
There really nice but hardware comes loose
http://
CUSTOMHILUX is offline   Reply With Quote
Old 12-07-2009, 02:08 PM   #10
I joined the Band!
Thats why you use just a dab of blue Lock Tight on the threads...at least thats what I did.
Old 12-07-2009, 02:32 PM   #11
i put the plastic washers that came with my AX10 kit between the lock nut and the rim so the mini bolts dont come off(fits perfectly and looks like warn hubs AXA1090). http://www.tcscrawlers.com/Axial-Rac...0-p-17031.html
Cationmoted is offline   Reply With Quote
Old 12-07-2009, 03:00 PM   #12
Can the holes be drilled up to 3mm, and still have enough edge margin (a.k.a. meat/material around the holes) to keep the wheels strong?
I'm wanting to buy an FJ-40 CC-01 kit here soon, and these wheels look the best on those rigs.
Old 12-08-2009, 06:54 PM   #13
I joined the Band!
I assume you could make the holes bigger. Mine hold the tire and rim together just fine stock. All I had to do was use some lock tight. If your having problems with the screws/nuts that came with the rims contact RC4WD. I did and they replaced the
Old 12-08-2009, 07:49 PM   #14
I emailed RC4WD a polite and straight forward message about the 3 stripped nutz and bolts that came with my 1.9 wheels and they email me back suggesting I buy a pack of their new ones for $9.00.
Not to impressed from these guys. I then emailed them back and they told me to send all the wheels back if I want to get anything replaced. The emails they send are not very friendly and it kinda pissed me off especially since they know that these nuts and bolts are having issues.
Like I'm gunna tear down my rig and spend $ shipping back the wheels because I need 3 nuts and bolts. Great service RC4WD .
Most of the time these guys make great products. I don't know whats going on.
Old 12-09-2009, 02:59 PM   #15
I was super carefull when tightening my hardware and still managed to strip one nut on each wheel. After closer inspection I noticed that there was a huge amount of slop in the nuts/bolts. Changed them all to Dubro 2.5m hardware, much tighter fit and no problems. Even stay tight without locktite and the nuts have a nice nickle finish!
I love RC4WD stuff but they always seem to cheap out a bit on the hardware, I guess they get good bulk deals from china lol.
Ax-hole is offline   Reply With Quote
Old 12-10-2009, 07:33 PM   #16
S ARR T 8's Avatar
will the 2.2 fit on the venom creeper I have a 12mm hex woul I have to take it off for them to fit.Also what about the back spacing will it widen or narrow the width thanks I really like the wheels and would like to use them on my creeper I am going to start turning in to a scaler thanks.
S ARR T 8 is offline   Reply With Quote
Old 12-10-2009, 11:12 PM   #17
I stripped some hardware, but I didn't bother with emailing them or buying their replacements. I just went to mcmaster and got 100 nuts and bolts. Lifetime supply for the same price they charge. No stripped ones yet!
Old 12-10-2009, 11:28 PM   #18
R.I.P. Chip
jason's Avatar
In your pics you have them mounted on an SCX-10, can you give me an overall width on it? Trying to figure out if they make it narrower since they don't use the hex.
jason is offline   Reply With Quote
Old 12-10-2009, 11:35 PM   #19
'08 2.2 National Champ
Just Zach's Avatar
With Rok Lox on they are 9 1/8" wide. As a comparison stock Axial 1.9 wheels with Rok Lox are 9 1/8". They are within 1/32" or less.
If you are looking for something to give you a narrower track width the RC4WD Hummer beadlocks are the most inset beadlocks I have found. They are an absolute pain to put together with all those tiny screws but they look amazing!
Just Zach is offline   Reply With Quote
Old 12-10-2009, 11:40 PM   #20
R.I.P. Chip
jason's Avatar
Awesome thanks Zach. I am wanting to put these on my Toyota Tuggy build, just wanted to make sure they didn't narrow the track width.
