11-21-2017, 03:09 PM | #1 |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
| Most capable scale crawler chassis? - Shoot me now..
Hey up... I realise this is a can of worms, but what is the most accomplished and capable (in action not looks) scale crawler kit / chassis? This will be with coil springs not leafs. I realise that driver skill and tyre choice probably make the largest difference in most cases but which chassis is winning comps the most and generally considered the best platform?. My question comes as i am performance minded and am trying to work out which chassis / kit to base my next project on. The choices currently sit between; TRx4, SCX10 2 or Ascender. I know the Axials have been around the longest and will probably have the strongest following... Thanks... |
11-21-2017, 04:50 PM | #2 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: Most capable scale crawler chassis? - Shoot me now..
Performance wise ( personal preference) SCX10 II Kit version Sent from my iPad using Tapatalk |
11-21-2017, 05:17 PM | #3 |
All 3 work fine. You just gotta pick one and go.
11-21-2017, 05:32 PM | #4 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
Scx10 ii
11-21-2017, 07:59 PM | #5 |
RCC Addict Join Date: Sep 2014 Location: Alberta
If you are strictly performance driven then build your own, I’d likely start with a Toyzuki V2 SCX10 2 chassis and go from there.
11-21-2017, 08:00 PM | #6 |
Rock Stacker Join Date: Feb 2005 Location: Medford
traxxas. best bang for the buck
11-21-2017, 08:17 PM | #7 |
ToyZuki if you want a performance scale chassis.
11-22-2017, 06:02 AM | #8 |
Thanks lads. I did see the Toyzuki chassis and fell in love "thumbs". And of course I realise to get the best performance you need to build your own but just looking at which platform to start with. I do have some old AX10 axles on a half built shafty project I could use. These already have upgrades including the XR10 front mods and overdrive front gears... Don't know how these stack up against the SCX10 version 2 axles? Looks to mostly be the pumpkin size as a limit.. |
11-22-2017, 07:51 AM | #9 |
Those axles are old technology, if you are doing a new build I'd go with the latest & greatest. The Toyzuki chassis has the option built in to overdrive the front axle. I'd go with some Vanquish F9's, or Rock Jocks for the SCX10-II, filled with all of their goodies (gear set, locker, axles, knuckles). Another option is SSD's latest offerings for the SCX10-II, which have metal axle tubes and plastic housings, which would slide over rocks better than the VP's and are a hell of a lot cheaper.
11-22-2017, 12:20 PM | #10 | |
| Re: Most capable scale crawler chassis? - Shoot me now.. Quote:
11-22-2017, 12:22 PM | #11 | |
The pumpkins on the SCX10 II versions are small, but the SSD are a very good budget friendly option! | |
11-22-2017, 05:09 PM | #12 | |
May I know, Beside Toyzuki V2 has build in overdrive or else makes overdrive trans or bevel and ring gear for SCX10 II? Sent from my iPad using Tapatalk | |
11-22-2017, 05:13 PM | #13 |
| Re: Most capable scale crawler chassis? - Shoot me now.. |
11-22-2017, 05:32 PM | #14 |
11-22-2017, 05:53 PM | #15 |
11-22-2017, 07:28 PM | #16 |
Newbie Join Date: Nov 2017 Location: Reno
I don't like the portals on the TRX-4, they keep you from using the inner sidewall to pull a wheel up an obstacle Sent from my Nexus 6P using Tapatalk |
11-24-2017, 03:55 AM | #17 | |
I can also see it hanging on stuff easier..... | |
11-25-2017, 01:23 AM | #18 | |
(I'm also envious of their 2spd, but I'll be rectifying that.) Sent from my Nexus 6P using Tapatalk | |
11-25-2017, 08:06 AM | #19 | |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Traxxas parts are higher quality than Axial. The diff locks and 2 speed on the TRX-4 are fun to play with but that is extra weight and complexity. OUT OF THE BOX I think the 10.2 is a better performer but ditch the heavy Land Rover body, add some brass portal covers, and get smaller bumpers and its going to be extremely close in performance. Quote:
11-25-2017, 09:48 AM | #20 |
Portals require a bit different line, vs the pumpkin down low. I know when I switched from a R1 to the wraith, totally different lines were needed. While I miss the portals, I learned different lines and have few issues. I do use a tall shock package for extra clearance Hang up and Drive |
Most capable scale crawler chassis? - Shoot me now.. - Similar Threads | ||||
Tamiya M03 M05 M06 TT01 TT02 HPI WR8 1:10 scale M-chassis shoot out at Punggol East H | boolean21 | Scale Videos! | 0 | 08-15-2014 10:14 PM |
Crawlerado Scale Photo Shoot | TwistedXT | Colorado | 34 | 10-29-2009 07:38 AM |
Scale but still Capable | bnoland | Axial AX-10 Scorpion | 15 | 08-19-2008 06:36 PM |
Most Capable scale chassis | rcdudegermy10 | Newbie General | 30 | 02-08-2008 08:27 AM |
How much stock parts are used an a capable crawler. | aussie_N_B | Tamiya TLT Crawlers | 7 | 09-10-2006 02:54 PM |
