04-29-2019, 06:14 AM | #21 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Affordable, HAMMERJAW !
I ordered a couple sets of the cheap ebay AR60 CVDs to try cutting down to size. I haven't gotten around to installing them yet, but I'm skeptical that they'll work with the HSP lockers. The diameter of the CVD shafts is small enough that it won't fill the openings of the HSP lockers. Converting to Axial-compatible lockers will probably work, but that drives the cost up. If there's a Wraith CVD with a wider axle shaft diameter, it would probably work OK with the HSP lockers, but again, it drives the cost up. |
11-16-2019, 08:20 PM | #22 |
Newbie Join Date: Jul 2018 Location: LAVEEN
Just search Amazon for "ar60 axle" or "ar60 cvd" should be $10-12 dollars a set. For 2 trucks you will need 4 sets (2 sets per truck as you only can use the long side that needs to be cut down and ground into a tang), so you will be spending $40 to $50 to upgrade both front axles. Below are 2 examples of set on Amazon. I would also buy lockers as the plastic stock lockers are going to strip out after only few uses as well. HSP locker 180009 is a direct stock replacement for these axle housings (the 3rd and 4th links below). This upgrade requires doing some metal cutting and reshaping of the new long ends axle shafts. I hope this helps. https://www.amazon.com/RZXYL-Univers...%2C196&sr=8-12 https://www.amazon.com/Treal-Heavy-S...%2C196&sr=8-31 https://www.amazon.com/BQLZR-Silver-...S7JKZPCKVZXSSV https://www.amazon.com/Hobbypark-Alu...3960545&sr=8-1 |
Affordable, HAMMERJAW ! - Similar Threads | ||||
Where are all the affordable wheels? | redsawacs | Axial AX-10 Scorpion | 28 | 03-08-2014 07:13 PM |
Looking for an affordable Radio | TACORICAN | Electronics | 20 | 11-16-2010 08:17 PM |
affordable esc? | gearmonkey23 | Electronics | 4 | 01-04-2008 10:55 AM |
