03-31-2019, 08:55 PM | #241 | |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: A new AXIAL Quote:
Pretty sure it’s 5 volts from the AE5. | |
03-31-2019, 09:29 PM | #242 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: A new AXIAL
I haven't had much luck with the Micro Xs in the past, but this truck is lighter weight and does not have OD/UD so hopefully it wont overheat or let the magic smoke out. I am going to try to make it to finals at Logandale next weekend. I guess if it survives that, it should be good for By The Fire. Doubt I'll do anything else to it for now except maybe adding a little bit of lighting.
03-31-2019, 09:38 PM | #243 | |
I’ll bring the wraith too so we can compare the bone stocker to yours. Here’s some side and front pics for whomever was asking (Dude?) lmk if you need a different angle/shot. In the last one you can see the steering links hitting before full compression. | |
04-01-2019, 04:19 AM | #244 | |
Pebble Pounder Join Date: Jan 2017 Location: @scaleobsession on instagram
I'm so glad im not the only one who felt this way. For the price point, there should have been at least universals involved, if not the original AR44s. I'm not a fan of these one piece housings. I felt like potentially metal links could have been included as well. The 10.2 cherokee RTR is the exact same price at tower. I will me making changes soon. It has tons of potential, and its a lot of fun to drive. Edit- I must add, that right out of the box, mine was missing the front bumper. Apparently, someone was napping during assembly HA! | |
04-01-2019, 07:51 AM | #245 | |
Newbie Join Date: Jan 2019 Location: Cupertino
Right on. I ran it for s couple hours yesterday. Had to use another radio. Used stock tires then later heavy wheels with Proline Hyrax. It’s tough. Top heavy, links drag a lot, suspension not good. Approach angles are good. | |
04-01-2019, 11:11 PM | #246 |
| Re: A new AXIAL
Mine is officially in transit. With any luck I'll be prototyping parts this weekend. |
04-02-2019, 04:19 AM | #247 |
| Re: A new AXIAL
I made big changes to mine last night. I swapped to the original AR44s, added trx4 shocks, samix brass spring perchs. Links will be here in a few days. I will be adding a Hobbywing 1080, savox 1230 and a holmes 21t. I also swapped on a set of SSD assassins.
04-02-2019, 10:16 AM | #248 | ||
04-02-2019, 11:45 AM | #249 | |
04-02-2019, 12:09 PM | #250 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
| Re: A new AXIAL
Got mine apart already... |
04-04-2019, 04:33 AM | #251 |
| Re: A new AXIAL I used scx10.2 kit links. I wanted to stretch to a 12.3 WB. Anyone else have a clicking noise in their front end? Right out of the box, my front driveshaft was rubbing the spur cover. Had to clearance that a good bit. They run this trans flipped 180 in the RTR scx10ii , and the rear is at a far less severe angle, than the front and doesn't rub. |
04-04-2019, 11:31 AM | #252 |
| Re: A new AXIAL
Mine does it too when the suspension is compressed.
04-04-2019, 12:42 PM | #253 | |
Oh Axial... | |
04-04-2019, 09:46 PM | #254 |
| Re: A new AXIAL |
04-05-2019, 09:19 AM | #255 |
| Re: A new AXIAL |
04-07-2019, 09:28 PM | #256 |
| Re: A new AXIAL
Womp womp womp... IMG_20190407_110037193_HDR by James Sanders, on Flickr Today was the finals for the local comp series and they set up a 100+ gate adventure course. I hit the trail with Pant Danza and about 20-30 minutes in, the C-Hub broke while I was going down a hill. No impact, just down a hill. Luckily, I had a set of OG AR44 housings in the truck so a little bit of surgery and I was able to get it going again. The Stubby seems about perfect for what I want out of this build. The Micro X handled it great and did not even get warm. Smooth startup, great torque, great wheel speed. The 2290 was a beast of course. IMG_20190407_105254383_HDR by James Sanders, on Flickr IMG_20190407_122819403_HDR by James Sanders, on Flickr Torque twist was a bit more than I'd like. Shocks will be the next upgrade. SSD Pro 44 front might also be coming up soon, as I noticed one of the C-Hubs had twisted when I got home. I'm liking the rock rash that the body gets. |
04-08-2019, 01:53 PM | #257 |
| Re: A new AXIAL
I was shocked that your chub broke on that downhill slide. Definitely not expected. I dig your electronics set up. Wheel speed seemed about perfect for the wraith. I saw another wraith break this weekend too, but that one I thought would have been much worse than it was. A good 20-25 feet down a fairly steep rock face and it ripped a link. Otherwise it seemed to have held up surprisingly well with the whole chassis being plastic. |
04-08-2019, 02:11 PM | #258 | |
So far this rig isn't doing anything to help me regain confidence in Axial... The rig looks great with those wheels and tires! | |
04-08-2019, 05:45 PM | #259 |
| Re: A new AXIAL
The second one may have simply been because I didn't torque it down enough and that allowed it to twist on the splines. I got a little distracted with everything going on. I ran one of my 10.2s pretty hard for a while with the stock multi piece housings and plastic C-Hubs without any problems. It wasn't until I swapped over to aluminum C-hubs that I started having them twist around. I'm trying to keep this rig relatively lightweight so I didn't really plan on swapping out the axle housings. Might just add a dab of CA glue to keep them from twisting in the future. Then again, money tends to burn holes in my pockets and I cant leave anything alone. |
04-08-2019, 10:36 PM | #260 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: A new AXIAL
I'm just glad your chassis didnt snap behind your front bumper. If it makes you feel any better I destroyed 3 chubs in a week when I first got my yeti haha SSD ALL THE THINGS!!! |
A new AXIAL - Similar Threads | ||||
fun day at the (axial wraith rock race - scalers axial honcho - axial discovery) | gionata78 | Scale Videos! | 1 | 08-06-2013 11:52 AM |
