11-14-2019, 06:23 PM | #1 |
Rock Stacker Join Date: Oct 2019 Location: Saugerties
| Cms hits servo under 3/4 compression.
I have a Remo 1093-st Honcho clone. I bought a a new stronger steering servo but if I mount it from top down on the chassis the servo horn hits the frame rails. So I mounted it from underneath and now it smacks the axle stopping full compression. Anyone have any tricks or ideas that may help. Sent from my GM1917 using Tapatalk |
11-14-2019, 06:31 PM | #2 |
| Re: Cms hits servo under 3/4 compression.
You might try looking for a servo horn that has an offset to it similar to this one https://www.amainhobbies.com/ruddog-...p-0085/p538043 If you can get some measurements from where the old servo locates the servo horn compared to the new servo you should be able to figure out which offset you'll want to look for. Also pay attention to the spline count on the horn to make sure it fits your servo, some are 24T and some are 25T. |
11-14-2019, 06:41 PM | #3 |
Thanks I'll check the link out Sent from my GM1917 using Tapatalk |
11-14-2019, 07:37 PM | #4 |
What I linked is just to get the idea, its not actually what I think you need. I'd recommend checking the measurement I mentioned above and then look for the right servo horn. Last edited by HumboldtEF; 11-14-2019 at 07:51 PM. |
11-24-2019, 01:38 PM | #5 |
You can make custom and rod ends that bend around the pumpkin. You can Rais the servo up in the chassis with spacers. You can buy different axles with smaller pumpkins (maybe scx10 2 axles? Might not help) Longer shocks (probably not what you want.) Sent from my SM-N950U using Tapatalk |
Cms hits servo under 3/4 compression. - Similar Threads | ||||
Chassis hits servo-horn while compressing | CanZaDK | Axial Wraith | 12 | 05-04-2018 06:36 PM |
Compression Socks | RANOVRU | Chit Chat | 24 | 04-09-2015 09:37 PM |
VP panhard hits servo and axle... | Wacki | Axial Wraith | 14 | 12-15-2013 10:19 PM |
bgr fab front trailbar with winch hits servo horn | Dusty_G | Axial Wraith | 7 | 07-22-2013 10:54 AM |
PLEASE HELP...steering servo hits "everything"??? | XFITCRAWLER | Axial SCX-10 | 14 | 05-21-2013 09:33 PM |
