09-18-2007, 09:28 PM | #21 | |
Pixel Pusher Join Date: Feb 2005 Location: Kansas City
One of our many Cad/Solidworks gurus does the design (I nominate Harley0706 ) One of our many machinist gurus builds the mold/molds. Then we're off and running. As I said, I think I could get the molds done and the first shots for under $3K. That being said, if the cost is a bit more, it may be possible to spread the total amount over a few orders. Maybe we could get some one to draw up a few items to get the interest peaking? | |
09-18-2007, 09:32 PM | #22 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
09-18-2007, 09:49 PM | #23 |
Rock Stacker Join Date: Feb 2007 Location: Portland
sounds like quite a bit of time as well. One of the guys I know at the shop was making two compound skateboard wheels and from CAD to a finished set it was under 8 hours of work, if he cut the cad and milling out of the equation, it was only about 2 hours of molding. I would see if I could get the shop owner to mold these, but his machine is a low capacity designed for single smaller parts. I don't think it has the pressure or the volume needed to mold a sprue. Could the molds be tested by having someone hand pour a test? Like how armature bronze is cast? Just to check the mold? Last edited by sudo; 09-18-2007 at 09:51 PM. |
09-18-2007, 09:52 PM | #24 | |
09-18-2007, 10:05 PM | #25 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
not to discount any talented rccrawler members but designing molded parts and designing a mold are two very different things, not to say is can't be done but there is alot to be considered: molds are designed specifically per the injection molding machine that they are run on, you need the machine specs like tie bar opening, clamp pressure, barrel size, etc another thing to think about is mold life, an aluminum mold won't last as long as a tool steel mold (thousands of cycles vs hundered of thousands to millions of cycles). a good compromise between mold cost and cycle life is a hybrid aluminum-steel mold the placement of the part cavity in the mold is very crucial, you need to consider where mold parting line would be to get a "straight pull", avoid undecuts in the direction of mold opening so you don't need slides or "side actions", you must decide the size and locations of the gates and runners as well as locations for mold heaters even desiging the parts isnt as easy as seems you need to consider ur wall thickess and design with consistant cross sections to that you avoid sinks mark, put draft on long pull sections so cores don't stick, and what about ejectors pins? man i could go on forever sorry i will shut up now |
09-18-2007, 10:12 PM | #26 | |
This is not an infinate market yet, Im betting 300 gas cans will be the max sold per year | |
09-18-2007, 10:26 PM | #27 |
Glad to see some guys stop in with some experience here. Let me clarify, I am NOT an expert, just another idiot with an idea My thoughts were a sprue with multiple items on it, or should I say several different items on it. That way we would be getting more bang for the buck, so to speak. If you have (as an estimate) $3K in total cost I sprue at $10=300pcs for break even. I would guess 500 units wouldn't be out of the question over a 3-6 month period. I agree that we are a small corner of the hobby still, but my thought was: "If someone made it, I'd want at least 3 of them!" so now we're down to 297... lol As far as possession of the molds, they would be community property amongst the people who put up the cash, until such time as someone wanted to buy out the others. Not really a need to worry as anyone who needed parts could simply order off the molds as needed. They would in reality never hit US shores unless being retired. Thanks for your time and interest guys, I truly appreciate the discussion here. Freq Last edited by FreqEsKinz; 09-18-2007 at 10:29 PM. |
09-18-2007, 10:32 PM | #28 | |
09-18-2007, 10:36 PM | #29 | |
if you went with protomold all you need for CAD is 3D models . for most of the parts listed in the first post I bet it would take at least 30-40 hrs most of the parts on list won't fit on one spru (one mold) so I estimate 3 NC'd aluminum molds at $1500 - $2500 each, i bet the cycle life on these molds would be 5-10k pcs protomold owns the molds so they charge a per piece price to cover them running the parts and material costs this is usually $1-5 each depending on part size worst case with $7500 toolling and a sale price of $10 a spru you'd have to sell 750 sprus to get ur money back, not bad submit a moldel below and they will quote in less than 24hrs, id do it but i only have machined parts on my hard drive http://www.protomold.com/ OK so now my consulting bill will be in the mail, or maybe I go into business for my self (MadDogRC baby!) | |
09-18-2007, 10:45 PM | #30 |
freq and rockwerks, all our indepent estimates are very close and seem resaonable, i believe this is in reach of the average joe so vendor support may not even be required i love this forum, where else can work and play mingle |
09-18-2007, 10:53 PM | #31 |
| LOL this is what free enterprise is all about |
09-18-2007, 11:03 PM | #32 |
the only down side is there is plenty of competition withl the wild willy sprus witch have a winch and jerry can and also many of the scale shops have hi lifts, shovels etc some one should add up how much it would cost to buy one of each parts from the current sources so we can decide if its worth is to compete ^^^ man if i knew how to spell i would have never become and engineer |
09-19-2007, 12:00 AM | #33 | |
Pebble Pounder Join Date: Jul 2007 Location: SinCity
This is what i've found so far: RCP Axe: 3.49 Shovels & fork set: 10.99 TCS High Lift Jack: 29.95 ORCRC Jerry Can (solid): 5.00 RPP Scale Dash: 10.95 HPI Bumper Set: 8.50 Aluminum Light Buckets (2): 22.00 Total So far: 90.88 Even at $10 or a little more a parts tree with this proposal, there will be a large chunk taken away from the comp. I so support this. Last edited by dznutz; 09-19-2007 at 12:06 AM. Reason: Updated list | |
09-19-2007, 06:26 AM | #34 |
Pebble Pounder Join Date: Jun 2007 Location: Upstate, NY
Also a suggestion. Maybe set up a Paypal account for people that are willing to donate to the cause.
09-19-2007, 07:59 AM | #35 | |
| Don't say the "W" word.... eek! Free enterprise at its finest. I love it. Quote:
Not yet on the PayPal, but we may do something like that soon if needed. | |
09-19-2007, 08:47 AM | #36 | |
RCC Addict Join Date: Sep 2005 Location: Beaver County, PA
I too think it would be awesome to see these parts molded in Styrene. There certainly is a long list of items I would like to see made, complete roof racks, light buckets for 5mm leds, coolers, jacks, fire extinguishers, etc.... etc.... | |
09-19-2007, 12:15 PM | #37 |
| So true... Maybe I was thinking way outside the box. I am hoping for the suppliers of the vendors to step-up and offer an cheaper solution. Kinda like how Walmart supports its customers. If that even makes sense. Okay back to my hole.
09-19-2007, 01:36 PM | #38 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
I also have a few connections that can help out. I have some connections to factories in China and can get in on shipping crates to lower that cost as well. All they need is the CAD files and 1/4 to 1/2 the money up front. I'd be more geared towards axles and that sort of thing than the smaller items like jerry cans. The way I figure the mold cost for smaller parts would run us around $2-5K total for multiple parts and then you looking at ordering for around $4-8 per unit shipped, in quantaties of 1000. Spred out 300 unites per vendor for retail. But this is all based on past experiances and could be different depending on the parts wanted and current price of materials. |
09-19-2007, 02:09 PM | #39 |
scale cases for TLT axles> gas cans |
09-19-2007, 04:46 PM | #40 |
amen stang
