01-05-2008, 07:13 PM | #1 |
Quarry Creeper Join Date: Jun 2006 Location: Pinckney
| Scale shocks that don't suck! Help
Can anyone point me in the right direction here? tlt shocks look Ok, and the size looks ok, but bottom line they are damn near worthless.... There must be an alternative. Help.
01-05-2008, 07:18 PM | #2 |
Rock Crawler Join Date: Aug 2007 Location: Tucson
| Internal Spring Shock
IF YOU LOOK ON RC4WD.COM THEY HAVE INTERNAL SPRING SHOCK. THET DO LOOK VERY SCALE. THEY ALSO HAVE LITTLE SHOCK BOOTS TO ADD TO THE EFFECT. HERE IS A LINK http://rc4wdstore.com/product_info.p...roducts_id=638 |
01-05-2008, 09:34 PM | #3 |
Thanks for the link, I've seen those. Do they work? Looking for a testamonial, or a solid recomendation from someone who has used a good working scale shock |
01-05-2008, 09:38 PM | #4 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
Sadly tlt's are you're best bet, and yes they are worthless. I've been looking for some also and there is just nothing on the market. The closest thing I've found are losi shocks. They are slightly smaller in diameter than your standard shock and they are also the best performing shocks on the market, but they can get pretty pricey too. |
01-07-2008, 07:00 AM | #5 |
Quarry Creeper Join Date: Jul 2005 Location: In my shop
| tlt shocks
Yeah I hear ya,tlt shocks blow.I have tried to use them on every scaler I've built but never had any luck with them.I turned em down,put dual rate springs on em and still they suck.On my Bruiser Bronco I used a set of RC One 3.5" shocks.They really don't look all that scale but they work awesome.On a heavy scaler with a 4 link I find a light spring with heavy oil works good.On the Toyota truggy I'm building I would like to try a set of the rc4wd scale shocks w/remote reservoirs.Maybe ditch the external spring for an internal one?Anyone run these?Searching.........
01-07-2008, 08:36 AM | #6 |
~THE SCALE SHOP~ Join Date: Apr 2006 Location: KILLEEN TX
i love my turned down dual spring TLTs i will be using them on all my trucks.
01-07-2008, 09:52 AM | #7 |
Sinking with the ship Join Date: Mar 2005 Location: El Capitan...sole survivor and sinking fast
I run rc4wd scale shocks on the back of my Chino Clone, Sometimes they stick a lil bit, but I think thats because with the internal spring you dont run a full body of oil and I think the seals get a lil dry. Other then that, I think they work and look good. -Mike |
01-07-2008, 12:51 PM | #8 |
I had the hottest girlfriend at the MSD Nats Join Date: Dec 2006 Location: Hecho en Tejas
make your own. i made the ones on the bottom |
01-07-2008, 03:55 PM | #9 |
Thanks for the replys guys. Obijuan, Do you run oil in those? I made a few like that, but they were just friction. |
01-07-2008, 04:17 PM | #10 |
Pebble Pounder Join Date: Mar 2007 Location: Toto Land
01-07-2008, 05:09 PM | #11 |
yeah here you go guys, its really easy. parts: traxxas rod end X2 tlt silver thing stampede rear shock shaft(long) tlt black thingy tlt brass bushing ok its filled with wheel bearing/ujoint grease and leaks less than a regular tlt shock! but it still leaks out. first drill out that black thing so the brass bushing is a press fit, very tight. then press that black/brass bushing thing you just made into the shock body, set it on something and hammer it in, it will be tough with out that. then the pede shock shaft is two eclips and no piston on it. then insert the the shaft into the shock body, then squirt some grease in it. put the traxxas rod end in it and crimp it with some pliers. put the other rod end on it. cycle it a bunch to get it circulated or something. repeat! |
01-07-2008, 05:23 PM | #12 |
01-07-2008, 05:42 PM | #13 |
Pebble Pounder Join Date: May 2007 Location: Where Canadian bacon comes from!
| I just ordered 4 - 100mm and 2 - 80mm for a Hi Lift build. Should have them by the end of the week hopefully, boots don't ship until Jan 10. I can let you know how the quality seems then.
01-08-2008, 01:56 PM | #14 |
Quarry Creeper Join Date: Apr 2006 Location: MEDFORD
i made some shocks like that obijaun, but i just put enough oil in to lube it, then i found some springs for the inside. they work greeat.
01-09-2008, 01:06 PM | #15 |
RCC Addict Join Date: Jan 2007 Location: San Jose
01-09-2008, 01:17 PM | #16 | |
| Quote:
heres mine vid of them performing http://www.youtube.com/watch?v=RyQgPhx1kVw | |
01-09-2008, 03:03 PM | #17 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Been looking @ these Trinity Next fronts 2.75" http://www3.towerhobbies.com/cgi-bin...?&I=LXPDN6&P=Z and the rears 3" http://www3.towerhobbies.com/cgi-bin...?&I=LXPDP5&P=Z I had seen a set on one of Jason's scale projects...although I don't remember which one, there were a number to choose from. The Duratrax Vendetta ST shocks are more expensive but they look cool http://www3.towerhobbies.com/cgi-bin...?&I=LXRAG4&P=Z An Associated 18T shock is almost 2.5" eye to eye http://www3.towerhobbies.com/cgi-bin...?&I=LXJHU6&P=Z |
01-09-2008, 03:57 PM | #18 | ||
RCC Addict Join Date: Sep 2005 Location: Behind the torch!
| Quote:
I run both RC4WD shocks on my scaler. Internal spring(minus the spring) in the front and piggyback in the rear. The truck doesn't have much articulation, but the shocks cycle freely. The work good and look great! I just wish the piggybacks had softer springs. | ||
01-09-2008, 04:17 PM | #19 | |
Im Brandon Join Date: Feb 2005 Location: Colfax, CA
| Quote:
Only set I have seen hold oil was Chino's FJ, but the shocks were angled foward on the front of his bruiser frame, for whatever reason with the combo of that angle and leaf springs they didnt leak | |
01-09-2008, 05:10 PM | #20 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Quote:
