Go Back   RCCrawler.com Bulletin Board > Vendors > Holmes Hobbies
Thread: Holmes Hobbies TorqueMaster P-94 Pro Handwound
Closed Thread
Old 12-10-2008, 02:48 PM   #1
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Default Holmes Hobbies TorqueMaster P-94 Pro Handwound
**Discontinued product**
When you have a need for power that isn't satisfied by normal brushed motor, it is time to step it up a notch with a precision built Pro Handwound! The Holmes Hobbies P-94 Pro is a Professionally hand built 540 with all of the features found in a Mod motor.
* Hand-Wound Armature – Our pro-level armatures feature a pattern hand-wound team wind with specific wire sizes developed for today’s high-output LiPo or Ni-MH batteries. All armatures are soldered using high-tech solder and then are epoxy coated with the latest state-of-the-art epoxy resin. All armatures are then pro-spec precision drill balanced and the commutator is diamond trued. All armatures are stamped with wind.
* 2 Magnet Can – The 1.4mm thick can features high-power FB9 wet magnets.
* Dual Ball bearings
* Adjustable timing
* On board Capacitor PCB installed
Custom Winds available upon request
JohnRobHolmes is offline
Old 12-10-2008, 03:16 PM   #2
Practicing my launchs >:)
Robbob's Avatar
are you using the standard P94 hoods or changing them to the normal stand ups?
Robbob is online now
Old 12-10-2008, 03:21 PM   #3
Standard P94 stuff, the big brushes.
It should be nearly identical to the Ti build TorqueMasters I have been building, maybe a touch lower rpm.
Old 12-10-2008, 03:24 PM   #4
hitman46mod's Avatar
I may get one for the scaler need some wheel speed. I think a 35t will do.
hitman46mod is offline
Old 12-10-2008, 04:18 PM   #5
Robbob's Avatar
Thanks.
Old 12-10-2008, 06:29 PM   #6
Keep it real
Tanis's Avatar
These are due in stock on august 26?:-P Feel free to delete my post when you fix it
Tanis is offline
Old 12-11-2008, 02:43 AM   #7
felsenfest
EGRESSor's Avatar
whats the comm size ?
EGRESSor is offline
Old 12-11-2008, 05:14 AM   #8
Thanks! Due in two weeks.
7.5mm on these.
Old 12-11-2008, 06:42 AM   #9
On the lookout for Rocks
constantmotion's Avatar
Are these to replace the Torquemaster Pro HW 540s?
constantmotion is offline
Old 12-11-2008, 08:28 AM   #10
For the short term, yes. I am getting the regular TM Pro version re manufactured, but it will take many months to complete. The performance differences will be small between the two builds, but they will use different replacement parts.
Old 12-11-2008, 11:52 AM   #11
Just thought that by just some chance they were gonna getting here early....:-(
Old 12-11-2008, 12:05 PM   #12
I am hunting for a nice 45t Hand Wound motor, I noticed that every 45t is out of stock on your site.
Any idea when you might get any in?
~John
jtice is offline
Old 12-11-2008, 05:50 PM   #13
Keep it real
Tanis's Avatar
~John
Due in two weeks
Tanis is offline
Old 12-11-2008, 09:26 PM   #14
I see the P-94 build available as preorder on the site, more than 10 left.
Old 12-11-2008, 09:39 PM   #15
Default yEs!
Just picked up a 45t. Can't wait. Thanks
carver is offline
Old 12-12-2008, 12:33 AM   #16
TEAM RCC
bcrofts's Avatar
just got a few 45t
bcrofts is offline
Old 12-12-2008, 09:57 PM   #17
Sh1T, pay day come, pay day come.
Hey John, can you reserve a 45T for me and I will order Monday?!?!
O.C.D. is offline
Old 12-16-2008, 07:53 PM   #18
Still have a few of the 45t left, and about 20 of the 35t left. I appriciate your support of the new build, it is a good one that you will enjoy.
Old 12-19-2008, 12:34 PM   #19
I've been strongly wanting a Cobalt 7T for my comp rig running 3S Lipo, but I just preordered a 35T, mostly because it's less expensive. Did I make the right choice? Does the 7T have more torque and wheelspeed than the 35T? What advantages are there with the 35T compared to the Cobalt 7T? I know the 7T is longer, but it fits in the stock AX10 chassis, so that's not a concern.
XPLORx4 is offline
Old 12-19-2008, 12:37 PM   #20
The 7t does have more torque and Wheelspeed, but it comes at a sacrifice to runtime. The 35t is still quite the powerful motor, gets you better runtime, and is a bit lighter.
Closed Thread
You may edit your posts
