Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: Venture gearing
Old 01-28-2019, 03:41 PM   #1
Default Venture gearing
Looking to gear down my venture.
Currently running av 550motor with a 5mm shaft, and cant go lower than a 17t pinion with that setup.
Wonder how low of a pinion you guys have fitted in it with a 3mm motor shaft, need to order some pinions if i can get it low enough with a motor swap.
Rcdood is offline   Reply With Quote
Old 01-29-2019, 12:26 PM   #2
Default Re: Venture gearing
Off the top of my head I think the smallest pinion you can fit is 15 tooth.
QuesoDelDiablo is offline   Reply With Quote
Old 01-29-2019, 12:48 PM   #3
Ty for the reply.
Seems abit pointless to change from a 550 to a 540 brushless motor if thats all i can gear down.
Maybe ill just order a range from 12-15t pinions and see what fits.
Old 02-02-2019, 03:36 PM   #4
Or get a massive turned motor. The venture is hardly walking pace and has a great drag brake stock, any slower and you'd be stationary?
crazee horse is offline   Reply With Quote
Old 02-02-2019, 08:11 PM   #5
My venture with a 3500kv on 3s and a 17t pinion is abit faster than i like my scalers. And i like abit of geardown.
Old 02-02-2019, 08:24 PM   #6
I"ve seen this issue first hand and I have plans to design a new front crossmember that allows for more room to gear down 550 motors, it seems possible. I'm just waiting on the Venture SBK to ship to get started. I'll likely have it up on Thingiverse so anyone can download and print it but I'm getting ahead of myself. Stay tuned.
I dont think the shaft diameter will effect this as a 17T pinion regardless of shaft size will be the same size.
HumboldtEF is offline   Reply With Quote
Old 02-02-2019, 08:36 PM   #7
The problem with a 5mm shaft is that it doesnt seem to be a lower 48p pinion than a 17t, that why im considering to put a 540 brushless in it, i really want a 12-13t pinion in it
Old 02-02-2019, 08:58 PM   #8
The issue I noticed is that you physically cant get the gears to mesh before the motor hits the front crossmember when gearing down a 550. My brother had a revolver which is close to a 550 diameter, he tried gearing down and found that smoke was emanating from the front crossmember as the revolver was rubbing it.
Selection of 48P pinions with 5mm hole is also a problem, I had to look into that as I dont run any 5mm shaft motors but I'm guessing the shaft diameter puts limitations on the tooth count thats possible.
A 540 sized motor will definitely give you more options
Old 02-03-2019, 07:07 AM   #9
How small of a pinion did your brother fit? Have roc412 i can put in.
Old 02-03-2019, 01:15 PM   #10
He was only able to get down to 16T
The Revolver has a 35.2 mm diameter while the ROC 412 has a 36MM diameter so the ROC 412 likely wont go as low as a Revolver, although maybe it can since it doesn't spin.
Old 02-03-2019, 03:09 PM   #11
Ok, think i might just settle for what i already have then.
My setup is butter smooth, but a gear ratio of 26:1 is abit higher than i generaly like in my scalers.
Old 02-03-2019, 09:26 PM   #12
R2j
SORRCA Committee Member
R2j's Avatar
I'm running a Holmes Trailmaster 3300kv and 14t pinion with no issues.
R2j is offline   Reply With Quote
Old 08-18-2019, 09:24 AM   #13
the problem i have is i want a few more mph, i dont want to run 3s and bend stuff, but not quite sure how high i could gear her. was thinking 23t. also what turn can the stock esc go down to.............?
Old 08-18-2019, 12:16 PM   #14
From their website:
Motor Limit: 2S LiPo or 6 cell NiMH: 540 or 550-size motor great than or equal to 12 turn, RPM over 30,000 at 7.2v
Motor Limit: 3S LiPo or 9 cell NiMH: 540 or 550-size motor great than or equal to 18 turn, RPM over 20,000 at 7.2v
https://www.hpiracing.com/en/part/114712
I've had zero issues running 3S though I'm not using any of the RTR electronics, I built the Kit.
Old 08-18-2019, 12:31 PM   #15
Yeah I read that, Ive seen a few people twist shafts with 3s. Think I may go down to am 18 turn motor or something close.
Old 08-19-2019, 05:21 PM   #16
I've done donuts with my SBK and still no breakage (on 3s). Don't know why, just wondering when it will happen. I am used to it though as an OG Ascender owner, I always carry spare front axle shafts. Natedog will understand that.
M1tch is offline   Reply With Quote
Old 08-22-2019, 03:22 PM   #17
Originally Posted by Natedog View Post
3s, 550 motor 21 turns should be ok per their site and been fine in Wraith, Honcho, Ascender.
Driveshaft, CVD or?
Cvd!
Old 02-10-2020, 03:10 PM   #18
Off topic a bit but wouldn't the optional 56t idler gear provide more speed?
Sent from my SM-G965U using Tapatalk
FormallySkullking is offline   Reply With Quote
Old 02-10-2020, 04:56 PM   #19
Yeah the smaller the spur gear the faster it will be. I think stock is a 60T spur gear.
Hot Racing makes spur gears that work on the Venture and Savage.
Old 02-10-2020, 05:53 PM   #20
Yeah they list the 56t as an option so I'll probably go that route and see what difference it makes.
Venture gearing - Similar Threads
MT Venture TAT76 HPI Venture 51 01-29-2020 12:32 AM
All out venture hoghead5150 HPI Venture 5 11-25-2018 10:03 PM
Dabbler got a Venture FJ! johnnyluv HPI Venture 24 10-08-2018 04:14 PM
The venture is here! Jfrisch01 HPI Venture 127 03-06-2018 07:34 PM
Another venture. aubie Chit Chat 6 12-25-2005 05:35 AM
