01-24-2007, 05:55 AM | #101 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Weighed the rig this morning, 8lbs, 15 oz. |
01-24-2007, 05:58 AM | #102 |
Quarry Creeper Join Date: Jan 2006 Location: colchester
do you run foams in the all ts or no?
01-24-2007, 07:29 AM | #103 |
Rig looks 10x better in the OD green Really nice pictures Jason, how the new hood (if you would call it that) coming?
01-24-2007, 08:11 AM | #104 |
XJwalt, running cut foams. 1BJB, no hump. I decided to relax last night. |
01-24-2007, 08:15 AM | #105 | |
01-24-2007, 08:18 AM | #106 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
DAMNIT JASON HENSEL!!! I can not get that fawkin song out of my head Rig looks great JIA My lovely lady lumps, check it out |
01-24-2007, 08:59 AM | #107 |
what RPM Revolvers is your dad running ? I looked on tower and they have different sets of rear wheels.
01-24-2007, 09:04 AM | #108 |
I wanna be Dave Join Date: Sep 2005 Location: *
Jason, give me the dimensions and how wide you want the hump and I could do one at our Hot Rod shop...We have a machine that puts nice beads in flat steal or aluminum...I think it goes up to 1'' wide...
01-24-2007, 12:05 PM | #109 |
eric, I'm running 82053 on Ralph, Dad is running 82063 on his. I was running the 63s on Ralph with the TLT axles but wanted to run the 53s to bring the width down so he'd fit on the trailer. I put my old 63s and All-Ts on Dad's truck. K9, thanks, but I can make it if needed. |
01-24-2007, 09:10 PM | #110 |
What ya guys running pinion wise for that 450 ? Did ya turn the shaft down or ?? just get 4mm pinions ??? Does make for good wheel speed ?
01-24-2007, 09:16 PM | #111 |
12 tooth pinion, 93 tooth spur. Wheel speed is good but it seems the 450 is a tad too small for a 9lb rig. There are times when it seems to not have enough bottom...like when the fronts are against a vertical face and you push the truck into and up the vertical. Since we're running 3300s I'm guessing it's not the batteries. A larger stator size would probably help. |
01-24-2007, 09:20 PM | #112 | |
01-24-2007, 09:37 PM | #113 |
Six cells are all that'll fit under the steering wheel. This truck was light during the build but we added a good bit of steel and lead to keep it planted. It'll creep through climbs that the comp rigs struggled with. This past week has been a frantic build/drive/build/drive test and tune. A larger outrunner will no doubt cure things. The motor stays cool to touch but seems to wimp out at times...even with gearing pushed as far as we could physically go. |
01-24-2007, 09:40 PM | #114 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
would one of rc4wd's plantery reducers fit?
01-24-2007, 09:42 PM | #115 |
Rock Crawler Join Date: Nov 2004 Location: Lost in Florida
hrummm....do i see an order being placed for brushless?
01-26-2007, 12:09 PM | #116 |
ScG he has a brushless setup as it is. I might order a larger motor for his truck, still debating which motor to use. Dad is happy with it as is...plenty of truck for him. |
01-26-2007, 12:11 PM | #117 | |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
01-26-2007, 12:29 PM | #118 |
Which? "My Hump" or MC Hammer's "Humps and a bump?" Or is it Gravy? |
01-26-2007, 01:44 PM | #119 |
01-26-2007, 01:58 PM | #120 |
RCC Addict Join Date: May 2006 Location: Roseville
LOL, that is a riot...
